  3. [App-Beta] Announcements
  4. Update 5.0 - major app overhaul!
65 Posts 22 Posters 557 Views 11 Watching
  • Jörgen
    Display problem!
    The German word for quickest is not displayed.
    I would change the translation from "Am schnellsten" into "Schnellste".
    Then it would be displayed correctly, as well as "Kürzeste" (shortest)
    • Jörgen
      CarPlay start, the arrow is not centred correctly.
      It will move later, after 1-2km to correct position.
      • richtea999
        Very nice! Good work, MRA dev team.
        Minor irritations:
        1. Android Back button doesn't exit the app.
        2. Forcing users to step through all the features on first starting is unnecessary. A single popup asking if they want to see the latest changes is sufficient.
        • Jörgen
          #29
          It is not possible to move the menu more up, to see more options.
          You also do not see a bar on the side, to make you aware that there are more options.
          Only if you move your finger at this area, you see more options and a bar.
          • Steve 2v
            Steve 2v
            Steve 2v
            Loving the new UI, same minor issues as others have posted about. In relation to the options piece in the post above, it would be great if we could change the travel mode here as well as part of the navigation options. I frequently swap between bike and car and forget to swap it over in the settings.
            • Dave J 0
              Great work with the new UI - top job. A couple of issues I experienced today on a quick test route I made with the new planner on the phone (worked well).
              Same Point Navigation. The route was deliberately planned with only Via points to see what would happen with recalculation etc. The navigation worked well apart from how the app managed a return to the same point (Waypoint 1 and Waypoint 3) after navigating elsewhere. Regardless of what I did to route to Waypoint 3, the app said Waypoint 1. Videos show me selecting Waypoint from the Waypoints’ list and also manually skipping the Waypoint to 3 with the top right Waypoint Icon. Each time the app went back to showing Waypoint 1!
              Car Play Manual Zoom Button. Tested on 2 different devices with the first screenshot on my car’s system through wired connection showing overlapping icons for zoom in and zoom out. Moreover, selecting these buttons made no change on the CarPlay screen.
              When trying the same on me Chigee on the bike through wireless connection, the same thing happened but I noticed that the zoom was changing on the iPhone but not on the CarPlay Screen until exited the manual zoom function and then reselected the manual zoom again. This may have also happened on the wired connection:
              Exit and re selection of manual zoom:
              iPhone 18 Pro
              Google Pixel 6 Pro
              • Edwin_M
                Edwin_M
                Edwin_M
                De app is op Android niet te stoppen vanuit de App zelf. Een quit app optie zou wel prettig zijn. Of na een paar keer terug drukken de App af kunnen sluiten
                • Hubert Thoring
                  #33
                  Sorry: 🫣 but through Hamm nobody drives voluntarily with his motorcycle !!!
                  The update should also please make the topic of routing (curvy route without driving through cities) better or why is routed with the MRA directly through Hamm to get from Winterberg to Münster via Curvy route from A to B.
                  Unfortunately or why other apps can do that better, or are more successful on route from A to B in curvy ...
                  Sorry: 🫣 aber durch Hamm fährt keiner freiwillig mit seinem Motorrad !!!
                  Das Update sollte auch bitte das Thema Routing (kurvige Route ohne Städte zu durchfahren) besser machen oder warum wird mit der MRA direkt durch Hamm geroutet um von Winterberg nach Münster über Kurvige Route von A zu B zu kommen.
                  Leider oder warum können andere Apps das besser, bzw. sind bei Route von A zu B in kurvig erfolgreicher …
                  Curvy example same A to B task!
                  Kurviger Beispiel gleiche A zu B Aufgabe !
                  An Hamm vorbe !!
                    Indeed, the placement of waypoints is way off in planning mode. I (we) missed that completely in our alpha testing, because we were unaware that anything concerning the changed GUI would impact the (as we thought unchanged) planner module. This proves the value beta testing 😉
                    On my tablet (Samsung Galaxy Tab S8 5G, Android 15, One UI 7.0) it's working perfect to place waypoints by MRA-Routeplanner - in portrait orientation. But in landscape orientation, I recognise same issues.
                    • Bart De Medts
                      Really put the MyRoute-app beta to the test today: 315 km ridden and every single instruction was spot on.
                      This one’s going to be a winner! 💛
                      • Guzzist
                        It's not an issue of new app version 5.0.0 - 418 - it's also in app version 4.4.1 - 410:
                        Now, route planning and navigation is going over a street, which is actually closed for roadwork. The map does not longer show the icon for road closed, but only for roadwork!
                        I'm sure some months before it was correct: route planning and navigation was using a detour. By the way: GoogleMaps is presenting as road closed and is navigating by detour.
                        • Guzzist
                          Because now, the selection buttons on start page of MRA-Routeplanner are organised as flat list (before, the buttons were in 2 columns) - now I need to scroll down to enter a target destination. It's at 4th poition.
                          Ok, to scroll is not a big thing - but if developers wanted to make it more easy (less clicks) to start navigation - it could be shorter.
                          It would be more than nice, if developers could make, the position of list entries could be rearranged in list by user.
                          • Dave J 0
                            I use both Android and iOS versions. There is a difference between Start and Finish icons. Really like the Android version with the flags instead of via icons:
                            iOS 26 - iPhone 15 Pro
                            Android 16 - Pixel 6 Pro
                            iPhone 18 Pro
                            Google Pixel 6 Pro
                            • Dave J 0 Dave J 0
                              @Dave-J-0 that’s probably a setting on your side. I guess you enabled track navigation on the Android 😉
                              Dave J 0 1 Reply Last reply
                              • Guzzist Guzzist
                                @Guzzist it’s actually there already, the search icon which is literally the first option 😆
                                Guzzist 1 Reply Last reply
                                  An Hamm vorbe !!
                                  @Hubert-Thoring we will check this but it’s not really part of the beta 😉
                                  This issue would be there in the website and the current release version.
                                  • Erik Plaggenborg
                                    Erik Plaggenborg
                                    Erik Plaggenborg
                                    Ik zie mijn eigen POI's niet meer tijdens navigeren sinds de nieuwe update. Voorheen zag ik deze tijdens navigeren altijd op de kaart voorbij komen als ik daar in de buurt was.
                                    Nu zie ik in de app als ik een route kies nog wel deze POI's staan maar zodra ik ga navigeren zijn deze persoonlijke POI's niet meer op de kaart te zien.
                                    Dit is best lastig omdat ik deze gebruik oa om POI's die niet op de route liggen toch te kunnen zien en daar eventueel naar toe te rijden.
                                    Is dit al een bekend issue? Zo niet dan zou het een zeer wenselijke optie zijn om terug te laten komen.
                                    Groet Erik.
                                    BMW R1250 GSA Ultimate Edition
                                    Garmin XT3
                                    Samsung S25+
                                    Enthousiast MRA/MRA Next gebruiker
                                    MotoCon Erik Plaggenborg 2 Replies Last reply
                                    • Erik Plaggenborg Erik Plaggenborg
                                      Groet Erik.
                                      @Erik-Plaggenborg, Ik zie ze nog wel hoor, Misschien heb je ze p/o uitgezet in de planner?
                                      Erik Plaggenborg 1 Reply Last reply
                                        Erik Plaggenborg
                                        Erik Plaggenborg
                                        Erik Plaggenborg
                                        @Con-Hennekens Ik heb het gecontroleerd staan aan maar op moment van indrukken knop
                                        navigeer zijn ze verdwenen..
                                        Garmin XT3
                                        Samsung S25+
                                          Erik Plaggenborg
                                          Erik Plaggenborg
                                          Erik Plaggenborg
                                          Poi's staan volgens mij dus in de planner aan.
                                          Garmin XT3
                                          Samsung S25+
                                          • 4
                                          Edwin_M
                                          Edwin_M
                                          Peter Schiefer
                                          Peter Schiefer
                                          PeterKerkhof
                                          PeterKerkhof
                                          Giuseppe Marino
                                          Giuseppe Marino
                                          Erik Plaggenborg
                                          Erik Plaggenborg
                                          Steve 2v
                                          Steve 2v
                                            Nick Elsom 0
                                            Nick Elsom 0
                                          • 0 van 15 klaar
                                            Mark Vroomen
                                            Mark Vroomen
                                            Bart van de Griendt
                                            Bart van de Griendt
                                          • Routelijn transparantie
                                            Mark Vroomen
                                            Mark Vroomen
