  3. [App] Announcements
  4. Android only update! (4.4.1)
28 Posts 10 Posters 15.1k Views 2 Watching
  • ginogino ginogino
    I tested the new app yesterday on a route of about 250km and disabled route recalculation. When I arrived in Rezzoaglio, instead of having me take the road I had traced, where there was also a waypoint (no. 8), it wanted to make me take a shortcut (red line), which although shorter is less beautiful to travel by motorbike. Knowing the road well, I took the road I intended to take. When I took the road I had chosen, all the information about how far I was from the destination, the next turns, etc. disappeared. However, the route to follow was clearly visible on the map but in white. Once I rejoined the road marked in red, all the information reappeared.
    @ginogino, My guess is that in Rezzoaglio you wandered off route and had the app recalculate a few times, after which it skips WP8, thinking it is unreachable. It then goes to WP9, for which the the red line is exactly the right way. In your example, what is the distance between Waypoints 7, 8 and 9? Maybe a bit too big. Skipping then can have a big impact too. You would have easily corrected that, by long-pressing WP8, which forces to recalculate from there.
    ginogino 1 Reply Last reply
      @ginogino of you share the url of the route and make shure its set to public maybe we can help you
      ginogino
      ginogino
      ginogino
      @Marinus-van-Deudekom said in Android only update! (4.4.1):
      link text
        ginogino
        ginogino
        ginogino
        @Con-Hennekens said in Android only update! (4.4.1):
        In Rezzoaglio, I didn't deviate from the route because when the app pointed me in the wrong direction, leading to waypoint 9 and skipping waypoint 8, knowing full well the route I had chosen to get to waypoint 9 via waypoint 8, I took the right direction for me, not for the app, which would have taken me to waypoint 8, then to waypoint 9, and then on.
        I keep route recalculation disabled because there are no warnings (like "make a U-turn") if you take the wrong turn, and if the route is recalculated without me realizing it, I risk (as has already happened several times) taking too much distance or not taking the route I intended.
        • ginogino ginogino
          @ginogino said in Android only update! (4.4.1):
          Do you mean that you've kept on going on the route that you planned or did you like @Con-Hennekens stated diviate a bit in Rezzoaglio.
          If I look at your route there should not have been any reason why the app would try to get you to skipp shapingpoint 8. No roadblocks or seasonal blocking.
          I don't know why you would disable recalculation.
          As I look at you route I would have put in more shapingpoints to prevent unexpected deviation of your route.
          I would certainly put shapingpoint 7 a bit more in the direction of 8
          Now it's almost on the crossing where things went wrong for you.
          Have you enabled the white original route in your settings. That way you can see when you're about to deviate from your route.
          ginogino JP d 2 Replies Last reply
            ginogino
            ginogino
            ginogino
            Yes, I continued on the route I had planned, which turned white, but the information about the next turns disappeared, I was not alone and I was unable to stop to take a photo of the display.
            In the options I don't seem to have found the possibility to change the color of the roads.
            • ginogino ginogino
              @ginogino maybe you can put in a service ticket and include the log file. By pressing long on the version number.
              What you experienced shouldn't have happened
              • richtea999
                Still one minor layout problem left, Corjan - the sync screen.
                Probably not worth a release, but worth a fix:
                  ginogino
                  ginogino
                  ginogino
                  Thanks, I didn't know how to extract the log file. I'll open a ticket reporting the error.
                  • ginogino ginogino
                    @ginogino, to be honest, if the app skipped to 9 and you still followed the original route to 8, there really is no error. Having no turn by turn instructions is what happens if you disable recalculation and leave the blue line. Of course you can ask why the app skipped 8. Could it be an accidental touch on the phone's display?
                      ginogino
                      ginogino
                      ginogino
                      There was no problem because I knew perfectly well the road I had selected when I planned the motorcycle tour, but instead I worry when I have to take roads that I don't know well or that I'm doing for the first time.
                        JP d
                        JP d
                        JP d
                        wrote on last edited by JP d
                        Exactly always ensure your waypoints are a good distance from a junction, intersection, roundabout or adjacent road. If you use the (expand) add waypoints option you have to check every single one.
                        I've also had MRA take me left onto a single track lane shortcut even though my friend's MRA was showing straight ahead which was the correct way.
                        I didn't have (show original route) turned on which would have helped but previously the white line (show original route) didn't follow the road correctly so I turned it off. Looks like it has been fixed now but I'll find out for sure on my trip on the 20th.
                        ginogino Brian McG 2 Replies Last reply
                        • JP d JP d
                          ginogino
                          ginogino
                          ginogino
                          @JP-d said in Android only update! (4.4.1):
                          I used to use the "expand" function, until I realized it was introducing a lot of errors, and I haven't used it since.
                          • ginogino ginogino
                            @ginogino I would not use the expand waypoint function but simply add a couple manually
                            • JP d JP d
                              not sure if it is the same issue you are refering to but just so you know before your trip there is still an issue with the "original route" line not exactly "following the road" if you are navigating in offline mode
                              there are a couple of workarounds, details are here https://forum.myrouteapp.com/post/66551
                              JP d 1 Reply Last reply
                              • Brian McG Brian McG
                                JP d
                                JP d
                                JP d
                                #22
                                @Brian-McG You're right mate! My mistake I had forgotten to turn WiFi and Data off πŸ€¦πŸ»β€β™‚οΈ.
                                I navigate with my old phone (no SIM) using offline maps.
                                So you're saying if I open a route offline and then click on the (pen) πŸ–‹οΈ edit route icon, then go to (Menu) scroll down and select (Navigate) the white line original route would follow the blue navigation line correctly?
                                Thanks for your reply 🍻
                                Brian McG 1 Reply Last reply
                                • JP d JP d
                                  @JP-d that sounds about right
                                  you can test it at home & see the white line not fitting correctly
                                  I think it is easier to see on longer routes with more points as somewhere MRA are limiting the number of track points for the track calculation, so longer routes deviate away more from the road
                                  the other work around is start the navigation while your old phone is still connected to the hotel wifi then the white line is calculated correctly as it is online & MRA allows more points for the track caclulation
                                  then go offline & close the wifi
                                  • Banshees
                                    Banshees
                                    Banshees
                                    The latest update made the bouton barely distinguished when riding, on Android Auto.
                                    I know where is the zoom and the POI option (to remove one waypoint while driving). But i can't see correctly the bouton.
                                    -oOOo-()-oOOo---------------------------------------------
                                    Banshees
                                    MRA Gold & Nav - Life
                                    --------------Oooo-----------------------------------------
                                    oooO ( )
                                    _)
                                    • Banshees Banshees
                                      @Banshees maybe you can share a screenshot
                                      • Thomas Neumeyer
                                        Thomas Neumeyer
                                        Thomas Neumeyer
                                        Hi, just out of curiosity. When is the next big update planned? Any teaser available?
                                        Thomas
                                        • Thomas Neumeyer Thomas Neumeyer
                                          Thomas
                                          @Thomas-Neumeyer it’s in beta since yesterday!
                                          Expected release end of the month.
                                          Thomas Neumeyer
                                          Thomas Neumeyer
                                          JP d
                                          JP d
                                          ginogino
                                          ginogino
                                          Banshees
                                          Banshees
                                            36
                                          • Using MyRoute-app Navigation Next module in Apple CarPlay on Goldwing Question
                                            Sam Kramer
                                            Sam Kramer
                                          • Routenplaner on iPad
                                            Risto Motorcycling
                                            Risto Motorcycling
                                          • Missing info from CarPlay
                                          • Rondrit generator ervaring
