  4. function EXPAND
function EXPAND
35 Posts 8 Posters 18.7k Views 3 Watching
  • Jörgen
    Yes, contact the support.
    • Jörgen Jörgen
      I am a bit confused? I usually use the same process with open street maps. I have no idea why you get a totally different route when you expand with more waypoints.
      @Jörgen said in function EXPAND:
      I am not so sure. This is not my method of creating routes, but isn't it so that Curvy options have some kind of randomness in it, exactly to prevent always getting the same roads? I am not surprised that this happens, I would be surprised about how it worked before when it did not change the route 😉
        @Con-Hennekens I've created a route using that tool in the TomTom map and couldn't get rid of the algorithms when I extended the route with a piece of highway. The way out was then to export the curvy part as a gpx track with I then uploaded in MRA. Yep a bit complicated
        • Karel76
          Karel76
          Karel76
          So I found a bug. when I perform the same action on the base of TOM TOM maps, the "EXPAND" function works as I want. On the OSM base it generates a different route. I attach a video of the creation on TOM TOM
          video TOM TOM (there is OK):
          https://k00.fr/n1vrs605
          video OSM (wrong route):
          https://k00.fr/kvxz2d3t
          Erdna 1 Reply Last reply
          • Jörgen
            @Con-Hennekens that is also not my usually method.
            But when I create a curvy route (with what ever map) it should be possible to use them in MRA navigation as created.
            So, why is the exported gpx file already total different to what was seen on the screen?
            And why do I get a totally different route, when I expand what I see on the screen?
            • Karel76 Karel76
              Erdna
              Erdna
              Erdna
              @Karel76 said in function EXPAND:
              That is not a bug. TomTom and OSM use different card material and different algorythms for calculation of the route. Compared with different setting like cury route, restrictions like don´t use highways, etc. that behaviour is absolutely normal.
              • Jörgen
                @erdna, you may be right. But this is not the point. Why is MRA making a totally different route when waypoints are added (with openstreet map)?
                WP should be added to the route that was created with OPM as well as it is done with TT map.
                • Jörgen Jörgen
                  Seemingly that is due to a randomize function in the automatic creation of scenic routes. A curvy route between 2 points can be different from a curvy route between three points, even when the middle point is on the original 2-point route. That does not sound completely illogical to me.
                  Remember that routes are calculated by the map-providers, not by MRA. Each map provider does things differently. That is nothing new.
                  Jörgen Travellexxie 2 Replies Last reply
                  • RainerT
                    RainerT
                    RainerT
                    OK,
                    I'll leave MRA and a software problem aside for now.
                    Adding loads of shaping points seems impractical to me.
                    There is <Compare route calculation with>.
                    Then you set shaping points to make the routes congruent. Incidentally, that was one of the parts involved in the creation of MRA 🙂
                    Or you can display the route as an overlay (on the left side of the menu). This would also work with a track log. Or simply the desired route. And on this basis, you then create a new route with the route engine of your choice.
                    I find the first alternative nicer and faster.
                    Interesting topic, maybe I'll add it to my to-do list for the next video conference.
                    RT
                    Translated with DeepL.com (free version)
                      @Con-Hennekens said in function EXPAND:
                      Ok, I understand that different maps generate different routes. The curvy function in OSM and TT are fine. And with TT generated routes, I can take them nearly 1:1 when I add WP to use with HERE (and navigation).
                      But why does it not work with OSM (nearly like in TT)?
                      If I can not use the generated route, what sens does this function make?
                      Or, how to solve this issue easily? (ok, you could add WP manually
                        Sorry Con, but it is totally illogical. With this tool, one expects MRA maintains the route. The route is already calculated, why not put the new added points on the route "as is", that would be logical. There is no use of a "new calculation" because the parameters for calculating the route didn't change.
                        MRA Lifetime Gold
                        • Travellexxie
                          By the way, I was there in that area, it is very nice!
                          https://routes.lexwill.cyou/cabriotour-tsjechie-2025/
                          MRA Lifetime Gold
                          • Travellexxie Travellexxie
                            #27
                            @Lex.Kloet.RX said in function EXPAND:
                            Sorry Lex, but MRA maintains nothing except a web planner tool. Calculations are done by mapproviders. Each adding of a waypoint triggers recalculations. Rest assured: I really don't know whether OSM has randomize functions in it's curvy routes calculations or not. But what happens here makes me think so. And it would have a purpose. No one wants the exact same route each time they create a roundtour from home.
                            But I agree completely that the difference shown by in the first post are pretty dramatic.
                              Saved for later! 😉
                              Thanks!
                                @Con-Hennekens I didn't wrote, that MRA calculate the route, only that the route has been calculated, and therefore the gray line is somewhere stored. The only thing MRA has to do with the expand, is follow that line and put shapingpoints on that line 😉
                                MRA Lifetime Gold
                                  @Lex.Kloet.RX, the grey line is not stored, it gets calculated each time. Only waypoints are stored.
                                  MartinW 1 Reply Last reply
                                    MartinW
                                    MartinW
                                    MartinW
                                    The calculated route must be stored in some way. If I calculate a route with OSM, I can navigate "route as track" in the original shape, regardless of how HERE calculates the route.
                                    • MartinW MartinW
                                      @Martin-Wilcke, Yes, a low resolution track is stored with each route for use with the "route as track" feature. This has been added pretty recent. It is however NOT used in any planning features though, and that is only logical because we are talking routes and not tracks. The web planner is a route planner not a track planner.
                                        MartinW
                                        MartinW
                                        MartinW
                                        Ahh, thanks, got it. But the "low resolution" track looks pretty detailed 🙂
                                        • MartinW MartinW
                                          Erdna
                                          Erdna
                                          Erdna
                                          wrote on last edited by Erdna
                                          #34
                                          @Martin-Wilcke said in function EXPAND:
                                          Don´t rely on it looking pretty detailed. It isn´t. 🙂
                                          For 1.5 seasons now, I´m using route as track navigation for all of my tours. Yet, there are deviations that I still cannot explain. Yeah, to rise the challenge, I´m also doing it in offline mode, too. I got into some situations, yet always managed to by any obstacles. The point is: use more points! Shaping points, Via points, just use them.
                                          There have been good hints like comparing the route to the other map suppliers, too. Or saving a .gpx from TT, one from OSM, one from HERE or an existing tracklog and adding them to blend in and see what´s really going on. The more effort one puts into planning (and using given tools), the more satisfying the final route will be...
                                          Anyway, have a great (rest of) the season! 🙂
                                          By the way: if anybody is interested in my routes and tracklogs, just send me a friendship request. The routes are pretty well described, why many tracklogs are not. My apologies, lack of time b/c I prefer riding. But I guess that I have some interesting stuff available I did through the last years. Covering mostly Italy, France, northern Spain, some Austria, Germany and Czech, too.
                                          MartinW
                                          MartinW
                                          RainerT
                                          RainerT
                                          Karel76
                                          Karel76
                                          Erdna
                                          Erdna
                                            guenniguenzelsen
                                            guenniguenzelsen
                                            Emanuele 5
                                            Emanuele 5
                                          • Club routes public/private
                                          • Bollard trouble
                                          • de connector app Windows
