  4. function EXPAND
function EXPAND
35 Posts 8 Posters 18.1k Views 3 Watching
  • Marinus van Deudekom
    2 possibilitys
    When you’re done like in the first video, try to export that as a gpx track
    Then upload that gpx to MRA and open it while Here is your standard map
    2 put a lot shapingpoints, I mean a lot, by hand in that first route and then change the map to Here
    Jörgen 1 Reply Last reply
    • Jörgen
      I am a bit confused? I usually use the same process with open street maps. I have no idea why you get a totally different route when you expand with more waypoints.
        2 possibilitys
        @Marinus-van-Deudekom said in function EXPAND:
        2 possibilitys
        I tried this as well and was surprised that the gpx file (the track) is different when you export (save) it from the original.
        Whats wrong here?
        I made routes with open street maps by using sections and curvy roads and filled it as well with waypoints to use it for navigation with Here map. I can't remember having this problem.
        • Karel76
          Karel76
          Karel76
          So probably a bug, because I used this feature once and it worked as it should. Now it's unusable. Thank you for your efforts. Is there any way to send this bug to the developers?
          • Jörgen
            Yes, contact the support.
            • Jörgen Jörgen
              @Jörgen said in function EXPAND:
              I am not so sure. This is not my method of creating routes, but isn't it so that Curvy options have some kind of randomness in it, exactly to prevent always getting the same roads? I am not surprised that this happens, I would be surprised about how it worked before when it did not change the route 😉
                @Con-Hennekens I've created a route using that tool in the TomTom map and couldn't get rid of the algorithms when I extended the route with a piece of highway. The way out was then to export the curvy part as a gpx track with I then uploaded in MRA. Yep a bit complicated
                • Karel76
                  Karel76
                  Karel76
                  So I found a bug. when I perform the same action on the base of TOM TOM maps, the "EXPAND" function works as I want. On the OSM base it generates a different route. I attach a video of the creation on TOM TOM
                  video TOM TOM (there is OK):
                  https://k00.fr/n1vrs605
                  video OSM (wrong route):
                  https://k00.fr/kvxz2d3t
                  Erdna 1 Reply Last reply
                  • Jörgen
                    @Con-Hennekens that is also not my usually method.
                    But when I create a curvy route (with what ever map) it should be possible to use them in MRA navigation as created.
                    So, why is the exported gpx file already total different to what was seen on the screen?
                    And why do I get a totally different route, when I expand what I see on the screen?
                    • Karel76 Karel76
                      Erdna
                      Erdna
                      Erdna
                      @Karel76 said in function EXPAND:
                      That is not a bug. TomTom and OSM use different card material and different algorythms for calculation of the route. Compared with different setting like cury route, restrictions like don´t use highways, etc. that behaviour is absolutely normal.
                      • Jörgen
                        @erdna, you may be right. But this is not the point. Why is MRA making a totally different route when waypoints are added (with openstreet map)?
                        WP should be added to the route that was created with OPM as well as it is done with TT map.
                        • Jörgen Jörgen
                          Seemingly that is due to a randomize function in the automatic creation of scenic routes. A curvy route between 2 points can be different from a curvy route between three points, even when the middle point is on the original 2-point route. That does not sound completely illogical to me.
                          Remember that routes are calculated by the map-providers, not by MRA. Each map provider does things differently. That is nothing new.
                          Jörgen Travellexxie 2 Replies Last reply
                          • RainerT
                            RainerT
                            RainerT
                            OK,
                            I'll leave MRA and a software problem aside for now.
                            Adding loads of shaping points seems impractical to me.
                            There is <Compare route calculation with>.
                            Then you set shaping points to make the routes congruent. Incidentally, that was one of the parts involved in the creation of MRA 🙂
                            Or you can display the route as an overlay (on the left side of the menu). This would also work with a track log. Or simply the desired route. And on this basis, you then create a new route with the route engine of your choice.
                            I find the first alternative nicer and faster.
                            Interesting topic, maybe I'll add it to my to-do list for the next video conference.
                            RT
                            Translated with DeepL.com (free version)
                              @Con-Hennekens said in function EXPAND:
                              Ok, I understand that different maps generate different routes. The curvy function in OSM and TT are fine. And with TT generated routes, I can take them nearly 1:1 when I add WP to use with HERE (and navigation).
                              But why does it not work with OSM (nearly like in TT)?
                              If I can not use the generated route, what sens does this function make?
                              Or, how to solve this issue easily? (ok, you could add WP manually
                                Sorry Con, but it is totally illogical. With this tool, one expects MRA maintains the route. The route is already calculated, why not put the new added points on the route "as is", that would be logical. There is no use of a "new calculation" because the parameters for calculating the route didn't change.
                                MRA Lifetime Gold
                                • Travellexxie
                                  By the way, I was there in that area, it is very nice!
                                  https://routes.lexwill.cyou/cabriotour-tsjechie-2025/
                                  MRA Lifetime Gold
                                  • Travellexxie Travellexxie
                                    #27
                                    @Lex.Kloet.RX said in function EXPAND:
                                    Sorry Lex, but MRA maintains nothing except a web planner tool. Calculations are done by mapproviders. Each adding of a waypoint triggers recalculations. Rest assured: I really don't know whether OSM has randomize functions in it's curvy routes calculations or not. But what happens here makes me think so. And it would have a purpose. No one wants the exact same route each time they create a roundtour from home.
                                    But I agree completely that the difference shown by in the first post are pretty dramatic.
                                      Saved for later! 😉
                                      Thanks!
                                        @Con-Hennekens I didn't wrote, that MRA calculate the route, only that the route has been calculated, and therefore the gray line is somewhere stored. The only thing MRA has to do with the expand, is follow that line and put shapingpoints on that line 😉
                                        MRA Lifetime Gold
                                          @Lex.Kloet.RX, the grey line is not stored, it gets calculated each time. Only waypoints are stored.
                                          martin-phogel.de
                                          martin-phogel.de
                                          RainerT
                                          RainerT
                                          Karel76
                                          Karel76
                                          Erdna
                                          Erdna
                                          • Here Terrain maps style
                                            Paul Scott
                                            Paul Scott
                                            128
                                          • Migration of my data
                                            Gary Clark
                                            Gary Clark
                                            148
                                          • MRA AI Routeplanner credits
                                            112
                                          • Synchronisatie tussen bèta en classic
                                            Henk Nuijens
                                            Henk Nuijens
                                          • Map viewing options
                                          • Map layers
                                            Peter Schiefer
                                            Peter Schiefer
                                          • Auf den ersten Blick bin ich sehr enttäuscht
                                            Heinz-Bernd
                                            Heinz-Bernd
