  4. function EXPAND
function EXPAND
35 Posts 8 Posters 18.7k Views 3 Watching
  • Karel76
    Karel76
    Karel76
    At this point, this function does not make sense to me. so to keep the same route as in picture 1 (created by OMS) and HERE does not recalculate it according to its algorithm, I have to manually click another 100 points. otherwise HERE recalculates the route according to picture 2 as I do not want it. I thought that "EXPAND" would make this manual work easier. Too bad
    • Jörgen
      Usually it should, but your sample is strange. it creates a total different route.
      Can you share the first route?
      • Karel76
        Karel76
        Karel76
        Yes of course.
        I tried this function three times and every time I put "EXPAND" the route changed.
        https://www.myrouteapp.com/en/social/route/11663717?mode=share
        • Marinus van Deudekom
          I’ve looked at your route.
          You’ve got a couple restrictions active and most important you’ve set the OSM to use the curvy road option
          You Said the route was a gpx file to start with.
          What does the original gpx route look like.
          If you expand while use curvy road is active you’ll get a different route
          • Karel76
            Karel76
            Karel76
            I did not create it directly in OSM, but in MRA through the OSM layer, see picture. Yes in the settings it was zigzag, out of town, off highway. I liked the route and that's why I wanted to add more waypoints, so that the navigation (MRA) would navigate me exactly along this route, because I know that MRA follows HERE and it has a different algorithm for creating routes and would guide me differently. Unfortunately after adding 50 points it created a completely different route. I kindly assumed that it would add the points to my original route. Now I hastily made a second route and the same result.
            • Karel76
              Karel76
              Karel76
              there is link on second route
              https://www.myrouteapp.com/en/social/route/11665201?mode=share
              • Karel76
                Karel76
                Karel76
                there is video for example how created route
                https://k00.fr/kvxz2d3t
                  2 possibilitys
                  When you’re done like in the first video, try to export that as a gpx track
                  Then upload that gpx to MRA and open it while Here is your standard map
                  2 put a lot shapingpoints, I mean a lot, by hand in that first route and then change the map to Here
                  Jörgen 1 Reply Last reply
                  • Jörgen
                    I am a bit confused? I usually use the same process with open street maps. I have no idea why you get a totally different route when you expand with more waypoints.
                      2 possibilitys
                      @Marinus-van-Deudekom said in function EXPAND:
                      2 possibilitys
                      I tried this as well and was surprised that the gpx file (the track) is different when you export (save) it from the original.
                      Whats wrong here?
                      I made routes with open street maps by using sections and curvy roads and filled it as well with waypoints to use it for navigation with Here map. I can't remember having this problem.
                      • Karel76
                        Karel76
                        Karel76
                        So probably a bug, because I used this feature once and it worked as it should. Now it's unusable. Thank you for your efforts. Is there any way to send this bug to the developers?
                        • Jörgen
                          Yes, contact the support.
                          • Jörgen Jörgen
                            @Jörgen said in function EXPAND:
                            I am not so sure. This is not my method of creating routes, but isn't it so that Curvy options have some kind of randomness in it, exactly to prevent always getting the same roads? I am not surprised that this happens, I would be surprised about how it worked before when it did not change the route 😉
                              @Con-Hennekens I've created a route using that tool in the TomTom map and couldn't get rid of the algorithms when I extended the route with a piece of highway. The way out was then to export the curvy part as a gpx track with I then uploaded in MRA. Yep a bit complicated
                              • Karel76
                                Karel76
                                Karel76
                                So I found a bug. when I perform the same action on the base of TOM TOM maps, the "EXPAND" function works as I want. On the OSM base it generates a different route. I attach a video of the creation on TOM TOM
                                video TOM TOM (there is OK):
                                https://k00.fr/n1vrs605
                                video OSM (wrong route):
                                Erdna 1 Reply Last reply
                                • Jörgen
                                  @Con-Hennekens that is also not my usually method.
                                  But when I create a curvy route (with what ever map) it should be possible to use them in MRA navigation as created.
                                  So, why is the exported gpx file already total different to what was seen on the screen?
                                  And why do I get a totally different route, when I expand what I see on the screen?
                                  • Karel76 Karel76
                                    Erdna
                                    Erdna
                                    Erdna
                                    @Karel76 said in function EXPAND:
                                    That is not a bug. TomTom and OSM use different card material and different algorythms for calculation of the route. Compared with different setting like cury route, restrictions like don´t use highways, etc. that behaviour is absolutely normal.
                                    • Jörgen
                                      @erdna, you may be right. But this is not the point. Why is MRA making a totally different route when waypoints are added (with openstreet map)?
                                      WP should be added to the route that was created with OPM as well as it is done with TT map.
                                      • Jörgen Jörgen
                                        Seemingly that is due to a randomize function in the automatic creation of scenic routes. A curvy route between 2 points can be different from a curvy route between three points, even when the middle point is on the original 2-point route. That does not sound completely illogical to me.
                                        Remember that routes are calculated by the map-providers, not by MRA. Each map provider does things differently. That is nothing new.
                                        Jörgen Travellexxie 2 Replies Last reply
                                        • RainerT
                                          RainerT
                                          RainerT
                                          OK,
                                          I'll leave MRA and a software problem aside for now.
                                          Adding loads of shaping points seems impractical to me.
                                          There is <Compare route calculation with>.
                                          Then you set shaping points to make the routes congruent. Incidentally, that was one of the parts involved in the creation of MRA 🙂
                                          Or you can display the route as an overlay (on the left side of the menu). This would also work with a track log. Or simply the desired route. And on this basis, you then create a new route with the route engine of your choice.
                                          I find the first alternative nicer and faster.
                                          Interesting topic, maybe I'll add it to my to-do list for the next video conference.
                                          RT
                                          Translated with DeepL.com (free version)
                                          MartinW
                                          MartinW
                                          RainerT
                                          RainerT
                                          Karel76
                                          Karel76
                                          Erdna
                                          Erdna
                                            guenniguenzelsen
                                            guenniguenzelsen
                                            Emanuele 5
                                            Emanuele 5
                                          • Club routes public/private
                                          • Bollard trouble
                                          • de connector app Windows
