  4. Waypoints (Again!)
Waypoints (Again!)
9 Posts 5 Posters 2.3k Views 2 Watching
  • stevemoriarty.co.zaundefined Offline
    stevemoriarty.co.za
    I've been using MRA for years and have successfully used waypoints to shape my routes, which I then export as tracks and navigate these.
    I would now like my waypoints to appear in my exported file. I read that tracks can only display the start and end waypoints. Is this correct? If so, why?
    I've tried exporting as 1.1 with & without track as well as 1.2.
    I've just moved to DMD2 which I believe can show an imported track and route at the same time.
    I've scanned many threads here but can't find a definite answer as to if it is possible, and if so, how?
    Thanks
    Travellexxieundefined Guzzistundefined Marinus van Deudekomundefined 3 Replies Last reply
    • stevemoriarty.co.zaundefined stevemoriarty.co.za
      Thanks
      Travellexxieundefined Offline
      @Stephen-Moriarty gpx 1.2 IS a route based on tracks, with the advantage of having waypoints (not shapingpoints!) between the beginging and the end. Both 1.1 and 1.2 export track and route in the gpx-file.
      What kind of device did you use before the dmd2?
      MRA Lifetime Gold
      nomkoundefined stevemoriarty.co.zaundefined 2 Replies Last reply
        Thanks
        Guzzistundefined Offline
        @Stephen-Moriarty if you save your MRA-ROUTEPLANNER route as gpx, please be carefully, because in the list of possible formats for download, there are gpx options "only track" as well as "track and route".
        Next, you need to know about the "nature" of a track: it's typically, navigation devices populates only start point and end point on screen. The "nature" of a route is: additionally to start- and end point, there can be more dedicated route points, which will be populated on screen of navi devices.
        If you are using DMD device / DMD2 app, you can load a gpx 1.1 file, which contains track and route. In DMD2 App, you can select the track and choose a color (I'm using light green for tracks). Then select the route and choose a different color (I'm using purple for routes). And set the option, to make both - track and route - visible on screen.
        By this, you can see, if routing algorithm of DMD2 App is really following your planned route. If purple route line is exactly on light green track line.
        At least: DMD devices are based on Android, means: you can additionally to DMD2 App also MyRoute-App run on the device. For MyRoute-App, it's not necessary to handle with gpx files, because there is an option you can select, to activate a ongoing synchronisation between MRA-Routeplanner and MyRouteApp.
        stevemoriarty.co.zaundefined 1 Reply Last reply
        • Travellexxieundefined Travellexxie
          nomkoundefined Offline
          @Lex.Kloet.RX said in Waypoints (Again!):
          Please keep in mind that the gpx 1.2 format is not an official format! It is made by MRA to add some extra features whch is not included in the official 1.1 format. So, best is to use the gpx 1.1 format since this is the official format. Read here more about the gpx 1.1 format: https://www.topografix.com/gpx.asp
          You can save your route as a 1.1 format gpx file includin routte, track and POI.
          | MRA Gold Member |
          | MRA Next + Kawasaki Z650 |
          Travellexxieundefined stevemoriarty.co.zaundefined 2 Replies Last reply
          • nomkoundefined nomko
            wrote on last edited by Travellexxie
            @Nomko-Nomden where did I write, that the 1.2 is an official gpx format? I just mentioned it, because TS mentioned, that he wanted to navigate on tracks with waypoints between start and finish and already downloaded 1.2. And that is exactly what the 1.2 export does for the Garmin Zumo's (that's why I asked what his last device was). And therefore it is, in my opnion, the finest choice for my XT.
            MRA Lifetime Gold
              Thanks
              Marinus van Deudekomundefined Do not disturb
              @Stephen-Moriarty of you have a DMD device you can also run MRA from that device. Works beter voor on road routes
                stevemoriarty.co.za
                @Lex.Kloet.RX Many thanks. I will experiment with this. I was previously using a Montana 680 which is a brilliant device and will remain my backup device. Looking forward to see what the DMD2 T665 can deliver.
                  stevemoriarty.co.za
                  @Nomko-Nomden Many thanks. Your comments are well noted.
                  • Guzzistundefined Guzzist
                    stevemoriarty.co.za
                    @Guzzist Thanks for your advice. I will look further into these options shortly.
                    nomkoundefined
                    stevemoriarty.co.za
                      Massimo Cardoneundefined
                      Massimo Cardone
                      -3
                      20
                      364
                    • Testrit met AA ivm tracklog
                      Tom Balmerundefined
                      Tom Balmer
                    • Fout in route bibliotheek
                    • Differently sighted…
                    • Waze warnings...
                      Leike Lodiersundefined
