  3. SilverFox Controller C 1
83 Posts 9 Posters 76.0k Views 6 Watching
    @Arjan-de-Vries invoerinstelling in de app op “SilverFox” gezet? 😉
    @Corjan-Meijerink je moet ook in de T865X EERST de Bluetooth connectie met de C1 maken. De Silverfox remote doet het icm MRA ALLEEN in de Bluetooth mode. De H1 werkt in MRA in de F2 mode. Door van mode te wisselen komen de MRA functies beschikbaar. Ik ga ervan uit dat dat in de C1 remote hetzelfde is.
    Arjan de Vries 1 Reply Last reply
      Arjan de Vries
      Arjan de Vries
      Arjan de Vries
      @Marinus-van-Deudekom klopt helemaal.
      Niet helemaal intuïtief overigens. Moest echt wel een aantal dingen doen.
      • Jay Salvo
        Jay Salvo
        Jay Salvo
        It works the same as the C1. Will it ever work with cable? @Corjan-Meijerink. I use several apps for different situations and the MRA is the only one I have to switch off cable to use with bluetooth. It’s not a quick switch from one to the other. Thanks Jay
        • Jay Salvo Jay Salvo
          @Jay-Salvo like I wrote in another topic. The Devs of DMD will not change the programming in the DMD2 devices even though they have been asked several times to do so by Silverfox Devs
          So most likely it will stay the same.
          The Devs of DMD are convinced that the cable connection is better even after they have been explained that Silverfox works differently
          Jay Salvo 1 Reply Last reply
            @Arjan-de-Vries fijn dat het werkt en ik ben benieuwd hoe hij jou bevalt
              Arjan de Vries
              Arjan de Vries
              Arjan de Vries
              @Marinus-van-Deudekom ik ga er mee spelen en maak een update.
                Jay Salvo
                Jay Salvo
                Jay Salvo
                @Marinus-van-Deudekom It doesn't make any sense why kurviger which is third party works with the Silverfox but MRA won't?
                  @Jay-Salvo hi Jay
                  SilverFox will work with MRA but only in Bluetooth mode.
                    @Kenny-Thierens @Peter-Zehentreiter confirmed it worked as expected! So I trust that is the case 🙂
                    I did receive the new SilverFox controller but have not yet connected it to power. Hopefully I get around doing that next week.
                    José Fernando
                    José Fernando
                    José Fernando
                    @Corjan-Meijerink said in SilverFox Controller C 1:
                    Hola .
                    Supongo que debido al tiempo transcurrido desde la adquisición del mando silverfox C1 ya habrás tenido ocasión de probarlo con myrouteapp . ¿ Qué tal ha ido ? , ¿ funciona todo bien ? , ¿ primeras impresiones ? Supongo que sigue siendo por conexión bluetooth y en la función 2 ? me interesa sobre todo la el pasar al punto siguiente de la ruta ( saltar waypoint )
                    Gracias de antemano .
                    Un saludo .
                    Hello.
                    I assume that due to the time that has passed since you purchased the Silverfox C1 controller, you've already had a chance to try it with myrouteapp. How did it go? Is everything working properly? Any first impressions? I assume it's still connected via Bluetooth and in function 2? I'm especially interested in skipping a waypoint.
                    Thanks in advance.
                    Best regards.
                    Kenny Thierens 1 Reply Last reply
                      #76
                      The C1 connected with bluetooth works absolutely amazing!
                      I love the controller.
                      Skipping waypoints and all other stuff is easy.
                      Especially with the new firmware (from SilverFox) where a long press does not trigger a short press anymore.
                      • José Fernando José Fernando
                        Hola .
                        Un saludo .
                        Hello.
                        Thanks in advance.
                        Best regards.
                        Kenny Thierens
                        Kenny Thierens
                        Kenny Thierens
                        @José-Fernando it's well worth the money. High quality piece, easy to operate (just 2 joysticks) and flawless MRA integration. Very fast bluetooth connection also.
                        '07 BMW R1200RT
                        DMD² T865x tablet
                        Samsung S24+
                        Cardo Spirit HD headset
                        José Fernando 1 Reply Last reply
                        • Kenny Thierens Kenny Thierens
                          José Fernando
                          José Fernando
                          José Fernando
                          @Kenny-Thierens said in SilverFox Controller C 1:
                          Con el mando C1 , ¿ como se salta al waypoint siguiente en modo navegación ? en la aplicación myrouteapp .
                          Using the C1 controller, how do you jump to the next waypoint in navigation mode? In the myrouteapp app .
                            @José-Fernando Hold up the joystick upwards long, then you’ll skip the waypoint😉
                            BMW R 1250 GS
                            DMD-NOR7E 7"
                            SPC Universal mount
                            Motorola Edge 40 "offline"
                            Sena SLR 3
                            Sena 50 R
                              I indeed still need to update the manuals 🙂
                              Peter Zehentreiter Arjan de Vries 2 Replies Last reply
                                @Corjan-Meijerink ,🤣
                                BMW R 1250 GS
                                DMD-NOR7E 7"
                                SPC Universal mount
                                Sena SLR 3
                                Sena 50 R
                                  Arjan de Vries
                                  Arjan de Vries
                                  Arjan de Vries
                                  How do I skip a waypoint with the C1?
                                  Is there a resent update from silverfox?
                                    Arjan de Vries
                                    Arjan de Vries
                                    Arjan de Vries
                                    That would be great
                                    • Peter Zehentreiter Peter Zehentreiter referenced this topic on
                                    • 4
                                    • 5
                                    Arjan de Vries
                                    Arjan de Vries
                                    Kenny Thierens
                                    Kenny Thierens
                                    José Fernando
                                    José Fernando
                                    Jay Salvo
                                    Jay Salvo
                                    • MRA Studio export speed
                                    • Hiya from UK
                                      Russ Nattrass 1
                                      Russ Nattrass 1
                                    • geeft routepunt niet weer
