  4. Navigation
Navigation
12 Posts 4 Posters 2.6k Views 1 Watching
  • Marinus van Deudekomundefined Do not disturb
    The trial version has no limitations.
    When your friend started at the first viapoint that was probably the issue. I dont know where the scip waypoint knob is on a iPhone
    • Nick Dawsonundefined Offline
      Nick Dawson
      Thank you for your response.
      I suspected as much.
      The skip waypoints looks to be at the top right but it didn't appear to work properly ( I could choose the next waypoint and thought all was well but the software then tried to route back to the start).
      Always difficult to troubleshoot properly when you are out in the field and it is not your device.
      Frustrating too as it was me who recommended MRA to him!
      We will see how we get on in a few weeks time but have a backup plan in place as again, I don't have time to troubleshoot whilst on a trip.
        Go to https://www.myrouteapp.com/support for the user manuals videos etc.
          When I stop for a break or lunch I always stop the navigation. Restarting after the break should have you an option to Navigate or stop. Choose Navigate to continue. As for selecting your next waypoint, simply display the route (or waypoints) and long press on the waypoint you wish to continue from.
            Nick Dawson
            That sounds rather straightforward!
            Thank you!
              Nick Dawson
              I wonder if the problem was caused because he didn't actually import the route but rather used the link I shared with him (from MRA).
              To open the route again once we closed it we had to go to WhatsApp and take the link again.
              For our three day trip I have sent him the files (gpx format) and told him to import to MRA.
              I should see him before the trip and will look at what he has done. We can load the route to make sure it goes to the first viapoint and hopefully all will be good.
              Thank you for your assistance.
                There is no need to import gpx files when you are both using MRA. If you set him up as a friend, he will be able to see your routes (at least the ones shared to friends or public). He can navigate the route directly from your routes or he can "use the route" which makes a copy in his routes.
                  Nick Dawson
                  I tried that but it didn't seem to work hence sending the files and then the link (which I think is the problem).
                    What do you mean by it didn't seem to work?
                    • Nick Dawsonundefined Nick Dawson
                      @Nick-Dawson said in Navigation:
                      The skip waypoint button can be used in 2 ways:
                      1. tap it, and tap "confirm" in the popup. If you do not do the latter, it will not skip anything.
                      2. long-press it, and it immediately skips to the next waypoint, without any confirmation.
                      I have much experience with Streetpilots and Zumos, and they all need an equal of amount of troubleshooting different things. You just need to get acquainted with your device (and app in case of a smartphone).
                      Nick Dawson
                        Herman Veldhuizenundefined
                        1.0k
                        314
                      • Unknown symbol
                        Rob Verhoeffundefined
                      • v5.2 (473) Feedback
                      • Permanent afgesloten wegen voor motorrijders
                        Paul Borghoutsundefined
                        Paul Borghouts
                        7.7k
                      • MRA 5.2.1 - 486 CarPlay Display Issue When route started on iPhone
                        GT JWRundefined
