  4. Route does not follow the actual Tom Tom map
13 Posts 4 Posters 3.8k Views 3 Watching
  • Kenneth de Miranda Kenneth de Miranda
    @Nick-Carthew Thanks!! So now i feel a bitlike an idiot 🙂
    But how come, when i created the route and used the TomTom map it appearenly kees using the Here map... o wait...maybe because thats my standard Map? You can change that to TomTom correct? But thanks mate!!
    @Kenneth-de-Miranda Your planning map is the TomTom map. You can set that as your default planning map by clicking: Always use this map for new routes.
    The planning map is the map that makes all of the calculations.
    The overlay maps do not affect any route calculations. Think of the overlay maps as clear sheet with extra information that you lay over the planning map.
    The system will remember the last overlay maps as that you used.
    • silberfuchs67
      silberfuchs67
      silberfuchs67
      May be I have the same issue. I am planning all my routes in the route planner with TomTom maps as I am also using the CRN. Opening the Navigation map the route uses Here Maps …. where do I have to change this?
      • silberfuchs67 silberfuchs67
        @silberfuchs67
        The planning maps are in the blue menu bar, if you do not see the blue bar, all of the same options can be seen after clicking Page menu.
        • silberfuchs67
          silberfuchs67
          silberfuchs67
          wrote on last edited by silberfuchs67
          Hi Nick, thanks for your support. It seems that I had exactly this issue …. thanks!
          • silberfuchs67
            silberfuchs67
            silberfuchs67
            I just understood that MRA Next has only Here maps to navigate. In case my routes are planned for BMW CRN the planning needs to be done with TomTom maps. If I want to use the Navigation App in parallel I would like to know how to handle this difference ? Thanks for the support.
              @silberfuchs67 When planning your route using the planning map from TomTom, turn on the Compare route with HERE tool. This will show an additional green route line (the HERE route) place enough route points so that the green line from HERE follows the black TomTom line.
              When you navigate this route with MRA Navigation Next, because it has not been planned on the HERE map, the app will navigate it as a track so you will need to be online.
              • silberfuchs67
                silberfuchs67
                silberfuchs67
                Hi @Nick-Carthew Thanks for explanation and your quick support!
                  @silberfuchs67, What @Nick-Carthew says 😉 . I just want to add, that after you equalled the routes with the compare tool, you can easily switch your route to the HERE map and navigate the route as rout (not as track). This makes no difference for TomTom users, since the routes are equal, and they usually import the route with a GPX.
                    @Con-Hennekens A good point well made 👏🏼
                    • silberfuchs67
                      silberfuchs67
                      silberfuchs67
                      @Con-Hennekens Thanks for this great hint!
                      silberfuchs67
                      silberfuchs67
                      Kenneth de Miranda
                      Kenneth de Miranda
                        guenniguenzelsen
                        guenniguenzelsen
                        Emanuele 5
                        Emanuele 5
                      • Club routes public/private
                      • Bollard trouble
                      • de connector app Windows
