New update! (4.3.9)
Nice! Looking forward to 4.0!
5.0 .....
@Arjan-de-Vries said in New update! (4.3.9):
That would be looking backward
5.0 .. -
Update is live for iOS & Android as of now
Henk van Rijn
Corjan bedankt voor de heldere uitleg van de Update! -
Looking forward to the improved audio on Android. Adjusting audio, always too quiet and a need to fiddle with the phone to correct this, it seems the case on every time I use Nav Next. Awkward as using an Android Auto panel with phone in my tank bag.
Drove today using AA and made multiple stops along the route, without touching the phone. I started the route from AA and every time I got back in the car, MRA would suggest to Resume navigation and everything worked just fine ! Seems that things are on the right track now !
I planned a 11 days trip in July, on Austria's Grosssglockner, Swiss Alps, Italian Alps, Slovenia, and I hope MRA Next will not disappoint ! -
Na mijn stap van iPhone naar Android weet ik nog steeds niet hoe ik de beta's kan krijgen en of ik die heb. Heb je een suggestie?
@Dikke-Wim
Corjan heeft je vier dagen geleden geantwoord, hij zei dat je contact moest opnemen met support over het worden van een Android BETA-tester of kijk naar je vorige supportticketnummer (#56007) voor instructies.
Corjan replied to you four days ago, he said contact support regarding becoming an Android BETA tester or look at your previous support ticket number (#56007) for instructions.
Hi all!
After quite some time, we now a nice little update for you all!
Nothing truly impressive but nonetheless still an important update to solve some common issues. This update will be available within the range of a few hours / days. Keep an eye on this forum thread to see if it has gone live for iOS or Android.Audio stability
There were quite some issues where users reported that sometimes the selected voice would not work, there wouldn't be any audio or that it would be very low. Now there is the possibility that it is a user error but we've also identified some problems on our side
We've also added a slider in the audio settings to adjust the system volume of your device. After these changes, we hope the audio experience has significantly improved in this version!MapBox update
Map what? It's the engine used to show the maps when you launch the app. We've updated this to the latest version which will definitely contribute to the app stability.Minimum iOS version
You are now required to have at least iOS 14 - no worries as all phones supporting iOS 13 (the previous requirement) also support iOS 14.Zoom behavior
We discovered the cause for some incorrect calculations regarding zoom level. The result of this was that the zoom behavior wasn't always what you'd expect. Especially on CarPlay / Android Auto. By fixing this we expect an improved behavior while using CarPlay / Android Auto in all camera modes.Minor changes
- SilverFox C1 support
- Fixed some typo's
- Resolved 2D HERE maps not loading on start screen
- Landscape modus shows option to recalculate route when you've disabled automatic recalculation and you deviated from the route
- Fullscreen mode actually dismissed correctly when exiting navigation (only applies when you've enabled fullscreen mode)
- Resolved position indicator alignment issue when switching between apps (we think)
Now that's it really
We are working on a major overhaul of the app. Completely revamping the experience and ensuring the app feels premium. This all together with some core architecture improvements. It's a lot of work and takes a while
Therefore we haven't had a lot of public releases lately.Besides that we are also improving our scenic routing algorithm / server and as nice extra we want to add custom overlay maps to help you plan by showing where scenic / RouteXpert routes are. More on that later!
Cheers,
Corjan@Corjan-Meijerink The audio volume for the Android version (DMD T865X) is MUCH better. Thanks!!!
Steve
I planned a 11 days trip in July, on Austria's Grosssglockner, Swiss Alps, Italian Alps, Slovenia, and I hope MRA Next will not disappoint !@Adrian-Avram awesome!
Steve
@Steve-Jarrell that’s what we were going for!
Thanks for letting us know. -
@Dikke-Wim
@Nick-Carthew thanks mate
@Dikke-Wim inderdaad via die manier even contact opnemen
