  3. SilverFox Controller C 1
83 Posts 9 Posters 76.0k Views 6 Watching
  • Guzzist Guzzist
    @Peter-Zehentreiter ah - ok, understood. But it sounds, the Button app was used on DMD device - therefore I have asked, because on DMD you should not use Playstore for updates.
    @Guzzist My button app isn't from the Play Store either. You can find the app as an "APK file" either in the DMD forum or on the SilverFox website.
    BMW R 1250 GS
    DMD-NOR7E 7"
    SPC Universal mount
    Motorola Edge 40 "offline"
    Sena SLR 3
    Sena 50 R
    • Kenny Thierens Kenny Thierens
      @Corjan-Meijerink Sorry to bother you. Have you had a chance to test your new C1 controller? Once I am sure all functions work in MRA Navigation, I will order this controller.
      Thank you in advance.
      @Kenny-Thierens @Peter-Zehentreiter confirmed it worked as expected! So I trust that is the case 🙂
      I did receive the new SilverFox controller but have not yet connected it to power. Hopefully I get around doing that next week.
      Jay Salvo Peter Zehentreiter José Fernando 3 Replies Last reply
        Jay Salvo
        Jay Salvo
        Jay Salvo
        @Corjan-Meijerink Hi, ive update everything but I cant zoom in and out with the joystick on the C1, The left joystick does nothing in MRA but works in other apps. I have a wired connection. Look forward to seeing if you have the same problem and cant resolve it. Thanks.
        Kenny Thierens 1 Reply Last reply
        • Jay Salvo Jay Salvo
          Kenny Thierens
          Kenny Thierens
          Kenny Thierens
          @Jay-Salvo did you already tried bluetooth connection instead of wired?
          '07 BMW R1200RT
          DMD² T865x tablet
          Silverfox C1 controller
          Samsung S24+
          Cardo Spirit HD headset
          Peter Zehentreiter Jay Salvo 2 Replies Last reply
            @Kenny-Thierens I also mentioned that issue 15 days ago to him......I also think, that could be an issue.
            BMW R 1250 GS
            DMD-NOR7E 7"
            SPC Universal mount
            Sena SLR 3
            Sena 50 R
              Jay Salvo
              Jay Salvo
              Jay Salvo
              @Kenny-Thierens no it’s wired, I can’t easily disconnect the wiring to try Bluetooth as it’s buried in the bike. All other navigation platforms work with a wired connection
                @Jay-SalvoI In our Button app we can disable cable connection, do you have the same possibility in your Button app?
                BMW R 1250 GS
                DMD-NOR7E 7"
                SPC Universal mount
                Sena SLR 3
                Sena 50 R
                Jay Salvo Arjan de Vries 2 Replies Last reply
                  @Corjan-Meijerink The only thing I´d like to know... is there a possibilty to skip waypoints with the controller, if yes please be so kind and explain how to do.
                  Thanks in advance
                  Peter
                  BMW R 1250 GS
                  DMD-NOR7E 7"
                  SPC Universal mount
                  Sena SLR 3
                  Sena 50 R
                    Jay Salvo
                    Jay Salvo
                    Jay Salvo
                    @Peter-Zehentreiter Thank you Peter, just gone and tried it and it works via the Bluetooth although as soon as power is lost I have to reconnect bluetooth again and deselect cable in the buttons app.
                      @Jay-Salvo I am glad to read that you can celebrate at least a partial success
                      BMW R 1250 GS
                      DMD-NOR7E 7"
                      SPC Universal mount
                      Sena SLR 3
                      Sena 50 R
                      Jay Salvo 1 Reply Last reply
                        Jay Salvo
                        Jay Salvo
                        Jay Salvo
                        @Peter-Zehentreiter If you sort skipping waypoints easily Id be interested in that too😀
                        Peter Zehentreiter 2 Replies Last reply
                          @Jay-Salvo I'll keep you informed 😉
                          BMW R 1250 GS
                          DMD-NOR7E 7"
                          SPC Universal mount
                          Sena SLR 3
                          Sena 50 R
                            @Jay-Salvo Hi Jay, I got it 🙂
                            This link leads to the SilverFox Bluetooth controller commands:
                            According to the commands listed in the table, the code "D" is the relevant command for skipping waypoints.
                            On the SilverFox website: https://www.silverfoxcontrollers.com/motorcycle-navigation-installation, you can find further information about which commands the two joysticks can execute.
                            According to this description, you need to push the control joystick up and hold it briefly.
                            I've tested it; it works for both via and shaping points.
                            BMW R 1250 GS
                            DMD-NOR7E 7"
                            SPC Universal mount
                            Sena SLR 3
                            Sena 50 R
                              Jay Salvo
                              Jay Salvo
                              Jay Salvo
                              @Peter-Zehentreiter That's Brilliant, a huge thank you, I will have a play this weekend to see it working.👍
                                Kenny Thierens
                                Kenny Thierens
                                Kenny Thierens
                                @Jay-Salvo so, the combination T865x with C1 controller is working well for you now that it's BT connected? All major functions are working? If so, I'll order one too. Just need to adjust it a bit to fit on my R1200RT handlebar.
                                '07 BMW R1200RT
                                DMD² T865x tablet
                                Samsung S24+
                                Arjan de Vries Jay Salvo 2 Replies Last reply
                                  Arjan de Vries
                                  Arjan de Vries
                                  Arjan de Vries
                                  Would you prefer c1 above h1? Why or why not?
                                    @Arjan-de-Vries It depends what bike do you have and how much space do you have on your handlebar.
                                    I checked the specs on the SilverFox Website and came to the solution that all controller can do almost the same.
                                    For my GS 1250 the C1 was the best solution (in my opinion)
                                    BMW R 1250 GS
                                    DMD-NOR7E 7"
                                    SPC Universal mount
                                    Sena SLR 3
                                    Sena 50 R
                                      Jay Salvo
                                      Jay Salvo
                                      Jay Salvo
                                      @Kenny-Thierens Hi Kenny, I can get it to work with bluetooth connection but still not working with cable connection. After every update the tablet receives (which seems like 1 every other day) I have to go back in and reset the button configuration. It's a great system when working but very buggy. I can get it to work brilliantly with Kurviger though which isn't listed as a supported app so I will be using that until MRA sort the cable issue. I've messaged Joao on the DMD2 forum about it and he replied its on his Todo list but I can't see him rushing to sort as it doesn't effect their app. I think it will require a collaboration of MRA, Silverfox and users to nag him to move it along.
                                        Can confirm the C1 controller will have full support starting the 4.3.9 update. In F1 mode you can use MRA.
                                        Manuals will be updated accordingly.
                                        Compared to B8J / H1 controller you have one extra feature, the "fit route".
                                        Kenny Thierens Guzzist Peter Zehentreiter 4 Replies Last reply
                                          Kenny Thierens
                                          Kenny Thierens
                                          Kenny Thierens
                                          wrote on last edited by Kenny Thierens
                                          #46
                                          @Corjan-Meijerink heel leuk om te horen. En toevallig net vandaag heb ik de C1 controller op m'n RT gemonteerd en gekoppeld met de tablet. Dikke merci voor je moeite en doe zo verder🙌
                                          '07 BMW R1200RT
                                          DMD² T865x tablet
                                          Samsung S24+
                                          • 4
                                          • 5
                                          Arjan de Vries
                                          Arjan de Vries
                                          Kenny Thierens
                                          Kenny Thierens
                                          José Fernando
                                          José Fernando
                                          Jay Salvo
                                          Jay Salvo
                                          • MRA Studio export speed
                                          • Hiya from UK
                                            Russ Nattrass 1
                                            Russ Nattrass 1
                                          • geeft routepunt niet weer
