  3. SilverFox Controller C 1
83 Posts 9 Posters 80.2k Views 6 Watching
    @Jay-Salvo Hello Jay, I am using the controller on a Android mobile phone.
    The My Route App needs to be in F2 Mode
    The panning Joystick (on the right) allows me to move the map in every direction.
    The control Joystick ( on the left) allows me to zoom in and to zoom out, by moving forward or backward the Joystick.
    I can switch the moving direction of the control Joystick ( means you can decide by your self whether zoom in or out when moving the Joystick forward or backward.
    By clicking up the Controller Joystick, the Map is re- centering.
    For Google Maps you need to be in F1 Mode
    It is mandatory to install the Button app from the SilverFox Webste.
    I also recommend to do the firmware update , explained on the SilverFox Website as well.
    I will make a short video today and will provide it here.
    Peter
    Jay Salvo
    Jay Salvo
    Jay Salvo
    @Peter-Zehentreiter Thanks Peter, I look forward to the video.
    • Jay Salvo Jay Salvo
      @Jay-Salvo Hi Jay, please find the video here
      https://1drv.ms/f/c/94b7ec629bb8bee5/EvfwBuww8BpLmoF32H5NurABfok3Ae1s7EZ6WcZvUGx-Aw?e=eu5KqF
      BMW R 1250 GS
      DMD-NOR7E 7"
      SPC Universal mount
      Motorola Edge 40 "offline"
      Sena SLR 3
      Sena 50 R
      Jay Salvo Arjan de Vries 2 Replies Last reply
        Jay Salvo
        Jay Salvo
        Jay Salvo
        @Peter-Zehentreiter said in SilverFox Controller C 1:
        Thanks Peter, I've seen the video really appreciated. I will give it a try tomorrow.
        Kenny Thierens 1 Reply Last reply
          Kenny Thierens
          Kenny Thierens
          Kenny Thierens
          @Jay-Salvo I bought the T865x recently and currently in doubt to order the C1 controller. MRA works flawless and much better and cleaner than on my previous AA device. But a BT controller would make the combination just that extra little bit more convenient and safer. I'll wait for Corjan's test before I'll decide.
          I have read that previous Silverfox controllers had more input options, such as holding down a button for longer, for example, but I'm curious to read your experiences so far. TIA
          '07 BMW R1200RT
          DMD² T865x tablet
          Silverfox C1 controller
          Samsung S24+
          Cardo Spirit HD headset
          Jay Salvo Peter Zehentreiter 2 Replies Last reply
          • Kenny Thierens Kenny Thierens
            Jay Salvo
            Jay Salvo
            Jay Salvo
            @Kenny-Thierens Hi Kenny, well I had a play today , I couldn't get it to zoom in using either F1 or F2., tried everything, my C1 uses the wired connection, it works brilliantly in DMD2 and you do have 4 separate options on the left joystick and 4 on the right since the update but only the right joystick works currently for panning in MRA. In Waze, Googlemaps it has full functions on both joysticks. Even on Kurviger it had 7 way controls and it states on the website it would be just follow mode and panning. I'm not sure who needs to implement something to address the problem, either Silverfox of MRA.
              @Kenny-Thierens said in SilverFox Controller C 1:
              The C1 Controller has also additional input option like press and hold.
              F2 Mode
              Control Joystick up => letter 'C' for centering the map​
              Control Joystick up and hold => letter 'D' extra functions on some apps
              Control Joystick forward => character '-' and KEY_NUM_MINUS
              Control Joystick forward hold + => letter 'A'​
              Control Joystick backward => character '=' and KEY_NUM_PLUS​
              Control Joystick backward and hold - => letter 'B'​
              Control Joystick downward => letter 'E'
              Control Joystick downward and hold => jumps to F1 mode and send letter 'X'
              I am impressed by the precise operation, also the pressure points of the joystick controller are absolutely top.
              But of course I am also curious what Corjan has to say
              BMW R 1250 GS
              DMD-NOR7E 7"
              SPC Universal mount
              Sena SLR 3
              Sena 50 R
                @Jay-Salvo Hi Jay, I don't know if this is relevant for you, I had to install the Button App to get Apps of the F1 Mode running "Google Maps" Riku from SilverFox told me, I have to make sure that the cable connection has to be disabled.
                You are writing, that you are using the cable connection maybe that is causing some problems on your side ?
                BMW R 1250 GS
                DMD-NOR7E 7"
                SPC Universal mount
                Sena SLR 3
                Sena 50 R
                Jay Salvo 1 Reply Last reply
                  Jay Salvo
                  Jay Salvo
                  Jay Salvo
                  @Peter-Zehentreiter Hi Peter, as Im using the DMD2 tablet it already has the button app when shipped, I've updated it and the C1 works in Googlemaps with cable connection as do Waze, Kurviger and DMD2 but MRA won't. I can't easily disconnect it to try the C1 with bluetooth on MRA so I will have to wait and see how Corjan gets on when he receives his C1.
                  Kenny Thierens Guzzist 2 Replies Last reply
                    Kenny Thierens
                    Kenny Thierens
                    Kenny Thierens
                    @Corjan-Meijerink Sorry to bother you. Have you had a chance to test your new C1 controller? Once I am sure all functions work in MRA Navigation, I will order this controller.
                    Thank you in advance.
                    '07 BMW R1200RT
                    DMD² T865x tablet
                    Samsung S24+
                      @Jay-Salvo said in SilverFox Controller C 1:
                      ...Im using the DMD2 tablet it already has the button app when shipped, I've updated it...
                      Please, how could you update the Button App? Which version do you have on your device now?
                      Jay Salvo Peter Zehentreiter 3 Replies Last reply
                      • Guzzist Guzzist
                        Jay Salvo
                        Jay Salvo
                        Jay Salvo
                        @Guzzist Hi they sent me an email, this it it pasted(im just trying to work out how I can pass you the zip file they sent:
                        Hi,
                        We have done integration work with DMD2 app and Firmware update for C1 controller is needed.
                        After this update, F-mode toggle is implemented by "pinching" the joysticks: The Control (left) joystick to right and The Panning (right) joystick to left.
                        After this update in F1 mode, you can define all Controller joystick moves (4 of them) into action in DMD2 app. As well the cable connection is now fully supported in DMD2 and Buttons app.
                        Please follow the link https://www.silverfoxcontrollers.com/c1update for installation instructions.
                        The update file is attached on this email
                        Sama suomeksi:
                        Olemme tehneet integrointityötä DMD2 ohjelman kanssa ja Firmware päivitys C1 ohjaimeen on tarpeen.
                        Tämän päivityksen jälkeen F-moodit vaihtuu "puristamalla" joystickeja toisiaan kohden: Vasenta oikealle ja Oikeaa vasemmalle.
                        Päivityksen jälkeen F1 tilassa voit määritellä kaikki 4 suuntaa DMD2 toiminnoiksi. Myös kaapeliyhteys (serial connection) on täysin tuettu DMD2 ja Buttons -ohjelmissa.
                        Seuraa linkkiä https://www.silverfoxcontrollers.com/c1update
                        Päivitys tiedosto on liitetiedostona tässä sähköpostissa.
                        Best Regards
                        Riku Pasanen
                        tel+358 40570 2779
                        www.facebook.com/SilverFoxcontrollers
                        • Guzzist Guzzist
                          Jay Salvo
                          Jay Salvo
                          Jay Salvo
                          wrote on last edited by Jay Salvo
                          #23
                          @Guzzist You can download it from their site here:
                          Guzzist 1 Reply Last reply
                            @Jay-Salvo thank you very much for detailed information. But I just wondered how to update the Button App. I don't intend to use SilverFox controller.
                            • Guzzist Guzzist
                              @Guzzist Do not know whether it is helpful for you.
                              I have the Button App installed as a single app on my Android.
                              To update the app I have just top open the app and if there ist an update available, the app ist asking me if I want to update.
                              BMW R 1250 GS
                              DMD-NOR7E 7"
                              SPC Universal mount
                              Sena SLR 3
                              Sena 50 R
                                @Peter-Zehentreiter ah - ok, understood. But it sounds, the Button app was used on DMD device - therefore I have asked, because on DMD you should not use Playstore for updates.
                                • Guzzist Guzzist
                                  @Guzzist My button app isn't from the Play Store either. You can find the app as an "APK file" either in the DMD forum or on the SilverFox website.
                                  BMW R 1250 GS
                                  DMD-NOR7E 7"
                                  SPC Universal mount
                                  Sena SLR 3
                                  Sena 50 R
                                    @Kenny-Thierens @Peter-Zehentreiter confirmed it worked as expected! So I trust that is the case 🙂
                                    I did receive the new SilverFox controller but have not yet connected it to power. Hopefully I get around doing that next week.
                                    Jay Salvo Peter Zehentreiter José Fernando 3 Replies Last reply
                                      Jay Salvo
                                      Jay Salvo
                                      Jay Salvo
                                      @Corjan-Meijerink Hi, ive update everything but I cant zoom in and out with the joystick on the C1, The left joystick does nothing in MRA but works in other apps. I have a wired connection. Look forward to seeing if you have the same problem and cant resolve it. Thanks.
                                        Kenny Thierens
                                        Kenny Thierens
                                        Kenny Thierens
                                        @Jay-Salvo did you already tried bluetooth connection instead of wired?
                                        '07 BMW R1200RT
                                        DMD² T865x tablet
                                        Samsung S24+
                                        Peter Zehentreiter Jay Salvo 2 Replies Last reply
                                          @Kenny-Thierens I also mentioned that issue 15 days ago to him......I also think, that could be an issue.
                                          BMW R 1250 GS
                                          DMD-NOR7E 7"
                                          SPC Universal mount
                                          Sena SLR 3
                                          Sena 50 R
                                          • 4
                                          • 5
                                          Arjan de Vries
                                          Arjan de Vries
                                          Kenny Thierens
                                          Kenny Thierens
                                          José Fernando
                                          José Fernando
                                          Jay Salvo
                                          Jay Salvo
                                            Nick Elsom 0
                                            Nick Elsom 0
                                          • 0 van 15 klaar
                                            Mark Vroomen
                                            Mark Vroomen
                                            Bart van de Griendt
                                            Bart van de Griendt
                                          • Routelijn transparantie
                                            Mark Vroomen
                                            Mark Vroomen
