  4. Fully automated tracklog
8 Posts 7 Posters 2.1k Views 5 Watching
  • Makroundefined Offline
    Makro
    Sometimes it's nice to see where I have been. Tracklogs can do this, but I often don't get to start it manually. And having to save it manually in the end, is tedious.
    My old Zumo automatically started recording every time it was turned on, and saved the track log upon shutdown, or upon some max size reached. No questions asked, the file name was a combination of date and time.
    It would be nice to get the same in the MRA.
    After track recording, it should be possible to rename selected tracks.
    Best regards, Makro
    Nick Carthewundefined Jörgenundefined 2 Replies Last reply
    • Makroundefined Makro
      Nick Carthewundefined Offline
      @Makro If you are following a route from your library, you can choose the setting in - Navigation settings > Functional > Navigation features. To automatically start tracklog, you need to save it manually and you can change the name at any point.
      Léon Hassingundefined Adrian Avramundefined 2 Replies Last reply
        Léon Hassingundefined Offline
        Léon Hassing
        @Nick-Carthew That's true, but only for route or track navigation. Not for A to B navigation. And it will not start automatically when you use CP/AA and start your navigation from there.
          Jörgenundefined Offline
          @Makro I don't always want everything to be recorded.
          You could certainly program it so that you set it in the setup. E.g. always record or start manually .
          TomOnTourundefined Makroundefined 2 Replies Last reply
          • Jörgenundefined Jörgen
            TomOnTourundefined Offline
            TomOnTour
            @Jörgen Same here. Normally I only record tracks if I realy had used a route in a specific area.
            But yes: Sometimes I do some scouting tours, where I just drive wherever the roads lead me to and then I also record a track, becasue I want too have a chance to use some of the nicest areas I have driven to be used on future tours in the same region.
            MyRoute-APP Navigation Next (V5.2.0 - 474) on DMD T665 Navigation phone and on DMD T781
            using iPad Pro (iPadOS 26.5) and Macbook Air (macOS 26.5.1)
              Adrian Avramundefined Offline
              @Nick-Carthew unfortunately it doesn't start automatically if you are using Android Auto and CarPlay (I tested on both).
              You have to take the phone out of the pocket and manually start track record ...
              Adrian
                The issue with CarPlay / Android Auto will be resolved in a future update!
                  Makro
                  @Jörgen said in Fully automated tracklog:
                  Yes, a simple option in settings to always start and save logging.
                  Best regards, Makro
                  Léon Hassing
                  TomOnTourundefined
                  TomOnTour
                  Makroundefined
                  Makro
                  • erratic routing instructions
                    John S Parryundefined
                  • how to view pictures of a structure or intersection
                    Jim O'Dowdundefined
                    Jim O'Dowd
                  • Is It Me?
                    D A Wakefieldundefined
                    D A Wakefield
                    304
                    Martin Garandundefined
                    Martin Garand
                  • Herberekenen werkt niet.
                  • Seasonal closures
                    MotorMakkers 0undefined
                    MotorMakkers 0
                    5.1k
                    526
