  4. Single beep before it's too late
5 Posts 4 Posters 1.6k Views 3 Watching
  • Mathijscoundefined Offline
    Mathijsco
    Hi,
    I love the feature to alert me when there is an exit I need to take, instead of speaking full instructions. But when I enable beep, it triggers 3 alerts, each at a certain distance from the exit.
    I only need one, so I set it to one.
    But now it will beep when I need to take the exit right away, that is way too late which makes the feature quite useless. It should notify me some distance ahead to check the navigation for upcoming exit.
    Is there any plan to have a feature that I can choose which single alert to get? So e.g. on the highway 2 km ahead instead 0 meters.
    Thank you!
    Mathijs
    Leike Lodiersundefined 1 Reply Last reply
    • Mathijscoundefined Mathijsco
      Hi,
      Thank you!
      Mathijs
      Leike Lodiersundefined Offline
      @Mathijsco When you go to you're settings and to audio you can set spoken instruction to beep and bellow that you can set the number of spoken messages to 1,2,3 or 4 mesages
      Mathijscoundefined 1 Reply Last reply
      • Leike Lodiersundefined Leike Lodiers
        Mathijsco
        @Leike-Lodiers Yes, I used this setting and set it to 1.
        However I get the single beep on the moment when to take the exit. So it is too late.
        Even setting it to 2 beeps are both too late as the first is 350m before the exit and then the second on the moment when to take the exit. There is too little time to change lanes if there is a bit of taffic.
        Stanisławundefined 1 Reply Last reply
          Stanisławundefined Offline
          Stanisław
          @Mathijsco I can imagine two solutions:
          • setting for the distance in meters for last beep before the turn
          • setting which beep should be done (when only one is selected) - the first, second or third one.
            Maybe @Corjan could consider it.
          Staszek
          • CD130undefined Offline
            This is exactly why I don't use the beep function either. I would also like to hear 1 beep per instruction, but not at the last second 😅
            Stanisławundefined
            Stanisław
            CD130undefined
            Mathijscoundefined
            Mathijsco
              Mzokkundefined
              3.6k
              223
            • Updated beta! 5.2.1 (486)
              481
              John S Parryundefined
              978
            • Showing Tracks with Routes on the Garmin XT3
              Carl Leeundefined
              Carl Lee
            • Move blocks of routepoints
              Yannick_van_Vugtundefined
              Yannick_van_Vugt
              620
            • Offline Track Navigation - Path Errors with Large Distance Between Points
