  4. Single beep before it's too late
5 Posts 4 Posters 1.6k Views 3 Watching
  • Mathijsco
    Mathijsco
    Mathijsco
    Hi,
    I love the feature to alert me when there is an exit I need to take, instead of speaking full instructions. But when I enable beep, it triggers 3 alerts, each at a certain distance from the exit.
    I only need one, so I set it to one.
    But now it will beep when I need to take the exit right away, that is way too late which makes the feature quite useless. It should notify me some distance ahead to check the navigation for upcoming exit.
    Is there any plan to have a feature that I can choose which single alert to get? So e.g. on the highway 2 km ahead instead 0 meters.
    Thank you!
    Mathijs
    Leike Lodiers 1 Reply Last reply
    • Mathijsco Mathijsco
      Hi,
      Thank you!
      Mathijs
      @Mathijsco When you go to you're settings and to audio you can set spoken instruction to beep and bellow that you can set the number of spoken messages to 1,2,3 or 4 mesages
      Mathijsco 1 Reply Last reply
      • Leike Lodiers Leike Lodiers
        Mathijsco
        Mathijsco
        Mathijsco
        @Leike-Lodiers Yes, I used this setting and set it to 1.
        However I get the single beep on the moment when to take the exit. So it is too late.
        Even setting it to 2 beeps are both too late as the first is 350m before the exit and then the second on the moment when to take the exit. There is too little time to change lanes if there is a bit of taffic.
        Stanisław 1 Reply Last reply
          Stanisław
          Stanisław
          Stanisław
          @Mathijsco I can imagine two solutions:
          • setting for the distance in meters for last beep before the turn
          • setting which beep should be done (when only one is selected) - the first, second or third one.
            Maybe @Corjan could consider it.
          Staszek
          • CD130
            This is exactly why I don't use the beep function either. I would also like to hear 1 beep per instruction, but not at the last second 😅
            Stanisław
            Stanisław
            Mathijsco
            Mathijsco
              430
              376
            • Statement on map spinning
              18
              26
              1.8k
            • Feature request to change colour of the route-line in My Route Web
            • MRA 6.0.0 (515) Track bar covered not displayed /// Streckenbalken überdeckt nicht angezeigt
            • Hoe offline navigatie rijden
              Barto
              Barto
            • New beta! 6.0.0 (514)
              235
