  4. Automatic switch Distance to next Via Point / Final Destination
20 Posts 8 Posters 6.2k Views 5 Watching
  • Guzzist Guzzist
    @Con-Hennekens said in Automatic switch Distance to next Via Point / Final Destination:
    ...This is no default method is it? Did you remap buttons?
    Oh - how could be done a remap of remote controller buttons? I thought, only in settings, the correct remote controller must be selected.
    @Guzzist the controller (like the BarButtons) is sending letters (as you can type on a keyboard). For Android there is an App (sorry, forgot the name) where you can remap what the controller sends.
    This is helpful for controller that do not send the Keys you need for MRA.
    I do not know what key is needed to switch the display.
    @Nick, can you open an editor and push the button for the display change and let us know what letter is sent?
      This is all listed in the manuals 🙂
      Go to https://www.myrouteapp.com/support > "MyRoute-app" > "Bluetooth controllers".
      For SilverFox, it's an "A" 😉
      MotoCon Jörgen 2 Replies Last reply
        As much as I understand some people's wish for this automatic switch, I just want to highlight also that it might draw eyes to the screen until your desired information comes along. It could be considered dangerous.
        Rajp 1 Reply Last reply
          @Corjan-Meijerink, I get it... there is no A in BarButtons 😉
          (they could if they gave up repetitive zooming by long press).
          Jörgen 1 Reply Last reply
            Rajp
            Rajp
            Rajp
            @Con-Hennekens alternate solution could be to tap that summary panel which then switches, tap again to switch back. So you can cycle through the various summary info by simply tapping that info summary panel.
            a white mouse on the motorbike MotoCon 2 Replies Last reply
            • Rajp Rajp
              @Rajp I think this is a better idea.
              Having the constant change show is too distracting for my liking.
              And going to the menu every time to switch is also inconvenient.
              The solution is indeed what @Raip suggests. Just click on the screen in the box to switch.
                Too bad. Do you know someone who can extend the BarButtons code?
                I will ask a friend, but is not easy.
                • Rajp Rajp
                  @Rajp said in Automatic switch Distance to next Via Point / Final Destination:
                  That's already the case long time... 😉
                  • Jörgen Jörgen
                    @Jörgen, yes, Joost, the developer of BarButtons... 😉 But he has been very quiet for a long time already.
                      Rajp
                      Rajp
                      Rajp
                      @Con-Hennekens on the phone app yes, but not on CarPlay, sorry I was referring to CarPlay screen
                        #20
                        @Corjan-Meijerink said in Automatic switch Distance to next Via Point / Final Destination:
                        Hello Corjan,
                        I tried this out and compared it with the information on the support page. I first realised that all letters have to be sent as a code in lower case and not in upper case as described. (for BarButtons N=n, D=d and C=c)
                        I can not check this for Silverfox, but I think it should also be written in lower case here.
                        Assuming Joost (or someone else) changes the code and you could send an ‘a’ for the display switch, would you then add this function for BarButtons in MRA?
                        Rajp
                        Rajp
                        Dae 0
                        Dae 0
                          guenniguenzelsen
                          guenniguenzelsen
                          Emanuele 5
                          Emanuele 5
                        • Club routes public/private
                        • Bollard trouble
