  4. Carpuride 702BS
Carpuride 702BS
14 Posts 9 Posters 5.3k Views 4 Watching
  • Neil Hinkins Neil Hinkins
    Has anyone tried the Carpuride 701BS with MRA on a BMW gs
    Im trying to find out what the funtions are as in can you scroll the map in and out and clear down way points with the multi funtion wheel.
    Marius Gross
    Marius Gross
    Marius Gross
    @Neil-Hinkins: I can confirm what Brian said. I recently tested the 702 BS with MRA and found that the zoom "+" or "-" does not work on Android. This is exactly why I bought the Carpuride, but I was not aware that this function does not work. I hope that a solution will be found soon.
    Neil Hinkins bluetuz 2 Replies Last reply
    • Brian Sprott Brian Sprott
      @Neil-Hinkins I have it Neil. You can zoom in and out on Apple Carplay but NOT currently on Android. It works perfectly by scrolling through the various options. It doesnt just zoom by scrolling the wheel. You have to scroll to the "+" or "-" and select from there. It is well worth it if you have Carplay IMO
      Neil Hinkins
      Neil Hinkins
      Neil Hinkins
      @Brian-Sprott Thank you for your answer it's exactly what I wanted to know.
      • Marius Gross Marius Gross
        Neil Hinkins
        Neil Hinkins
        Neil Hinkins
        @Marius-Gross Thank you for your reply.
          bluetuz
          bluetuz
          bluetuz
          @Marius-Gross I can confirm too. It is posible to zoom in CarPlay but not in Android Auto. Tested in both OS today
          • Fridjof
            Fridjof
            Fridjof
            is there a schedule for the fix available?
            best regards
            • Jörgen Jörgen
              @Neil-Hinkins Hi, there are lot of discussions about Carpuride in this forum, try to use the search function.
              Her a starter: https://www.youtube.com/watch?v=_HX4-t5BZlM
              Leslie Barnes
              Leslie Barnes
              Leslie Barnes
              @Jörgen using google maps i have verbale directions but in MRA not? any suggestions?
              Leslie
              Jörgen 1 Reply Last reply
              • Leslie Barnes Leslie Barnes
                Leslie
                @Leslie-Barnes Oh, not directly. There are so many possibilities.
                Are announcements switched off?
                • Leslie Barnes
                  Leslie Barnes
                  Leslie Barnes
                  Zo ver als ik weet alles staat aan
                    Selecteer een TTS Engine en selecteer een stem. Probeer het dan nog eens.
                    Deze staan nu op "onbekend"
                    Leslie Barnes 1 Reply Last reply
                      Leslie Barnes
                      Leslie Barnes
                      Leslie Barnes
                      @M-Schrijver Thank you, that did the trick everything is working great now.
                        @Leslie-Barnes
                        Please show the current Fofo for setting. Thank you 👋
                        Fridjof
                        Fridjof
                        Brian Sprott
                        Brian Sprott
                        bluetuz
                        bluetuz
                        Marius Gross
                        Marius Gross
                        Leslie Barnes
                        Leslie Barnes
                        Neil Hinkins
                        Neil Hinkins
                        • test Myroute APP
                          1.8k
                        • How to plan correctly
                          Christian Feurstein
                          Christian Feurstein
                          508
                          Jörg Neudert
                          Jörg Neudert
                          654
                          LE DIZES Freddy
                          LE DIZES Freddy
                          7.9k
                        • Tour results and a question
