  4. Travel time discrepancies
26 Posts 6 Posters 12.1k Views 4 Watching
  • Steve Jarrell Steve Jarrell
    @Martin-Wilcke It looks like MRA is using the Garmin extensions to do their track and route calculations whereas Kurviger doesn't. The strange part is that for this exact same route if I use the OSM map in MRA the calculated time shows as 3:13, with the TomTom map it's 3:11 (both are close to the actual time that it took to ride the route and the time calculated by Google and Kurviger) and with the HERE map it is 4:17.
    Gpx 1.1 files exported by all three maps show that the tracks created used the Garmin extensions, however the actual route creation calculations must be a function of the underlying map itself.
    I pointed out in another post that the HERE map consistently does not follow an imported track as well as the other two, and the route's time calculations are definitely inferior as well.
    I definitely see the disadvantages of using the HERE map over using the OSM map in MRA. Can anyone tell me the actual advantages?
    Thanks!
    @Steve-Jarrell A small note on the side. I tried Kurviger a while ago and found the ETA's, while navigating, far too conservative (the rides were taking me less time). This was when driving a car on asfalt roads. They definitely don't include live traffic data and I think they have their own algorithm to calculate the ETA's. The ETA info to the next waypoint is a very important feature for my use cases and the conservative estimates in Kurviger were the main reason for me to switch to MRA (where I found the ETAs to be very accurate).
      Thanks!
      martin-phogel.de
      martin-phogel.de
      martin-phogel.de
      @Steve-Jarrell said in Travel time discrepancies:
      To avoid confusion: Using GPX extensions (like "Garmin extensions") is a way to store additional information in a gpx file that is not part of the core gpx data model. The most popular example is the differentiation between VIA and shaping route points using the garmin:trp extension.
      For time information, however, there is no need to use an extension as this is part of the core gpx data model.
      And it's about storing information and has nothing to do with time calculation.
        Thanks!
        martin-phogel.de
        martin-phogel.de
        martin-phogel.de
        There is one I'm aware of: consideration of road closures.
          Steve Jarrell
          Steve Jarrell
          Steve Jarrell
          @Herman-Veldhuizen Thanks for your respons Herman. With the TomTom and OSM maps I'm finding the calculated route times to be very accurate. With the HERE maps I find it to be inconsistent.
          The only thing that I can surmise is that the route calculations and the calculations that create a route from a track are built into the maps themselves and MRA has very little, if any, control over them otherwise the HERE map would not be inferior to the other two in this regard.
          I also switched from Kurviger as I find the user interface to be very, very unintuitive whereas I find MRA to be extremely easy to use. I also find MRA's tech support to be excellent, and the user forum is extremely helpful as well.
          Unless someone can show me why there are important advantages to using the HERE maps as the default I'm going to make the OSM maps my default, and hopefully the MRA developers will fix the bug that causes the following dialog to appear when I switch to the OSM map or import a track into it even though I have my driving mode set to "Driving" which, according to MRA, should avoid this message:
          Steve Jarrell
          Western North Carolina US
          2025 BMW R1300GS
          2025 Can-Am Spyder
          DMD T865-X 8" Tablet
          Garmin XT3
          Herman Veldhuizen Con Hennekens 2 Replies Last reply
            @Steve-Jarrell I never really looked at the route times, only the ETAs while navigating.
            But now I did for one of my routes which goes mostly over a highway
            Route time for MRA-OSM is noticeably longer than MRA-Here! Kurviger is the slowest.
            220km, paths are very similar in all 3.
            MRA Here: 2h 52m
            MRA OSM: 3h 13m
            Kurviger: 4h 4m
              MRA Here: 2h 52m
              MRA OSM: 3h 13m
              Kurviger: 4h 4m
              Steve Jarrell
              Steve Jarrell
              Steve Jarrell
              @Herman-Veldhuizen Thanks Herman.. That's weird..... there doesn't seem to be any consistency. My "gold standard" is normally Waze or Google maps as I find them to be extremely accurate, but since you can't upload a specific route into either they're of no help. Although you can import a track into Google MyMaps it really doesn't create a Google route from it, so it uses the tracks time information so that's no help.
              I could be wrong so if I am someone please let me know. I'm here to learn.... that's half the fun! 🙂
              If I have time I'll go back and compare 5 or 6 of our group's tracks/routes and compare them in MRA using the HERE, OSM and TomTom maps.
              Thanks for your input. I really appreciate it!
              Steve Jarrell
              2025 BMW R1300GS
              2025 Can-Am Spyder
              Garmin XT3
                The biggest advantage to use HERE maps for planning is the least chance for the planner map to be different than the navigation map. The advice is to plan your route on map that is ost equal to the one you navigate with. For MRA Navigation that is HERE, as is for Garmin devices. There are many differences in maps between OSM and HERE, especially in rural mountenesque areas.
                I am not aware of a driving mode called "driving". I only get this message when I switch from HERE or TomTom to OSM while I have "Motorbike" selected as driving mode.
                Steve Jarrell 2 Replies Last reply
                  Steve Jarrell
                  Steve Jarrell
                  Steve Jarrell
                  @Martin-Wilcke Thank you for the explanation!
                  Steve Jarrell
                  2025 BMW R1300GS
                  2025 Can-Am Spyder
                  Garmin XT3
                    Steve Jarrell
                    Steve Jarrell
                    Steve Jarrell
                    @Martin-Wilcke Thank you.
                    That's one that I prefer not to use anyway as I've found (in our area at least) that often it's not accurate, or I'm creating a route that I'll be riding when they don't exist so I almost always disable it anyway.
                    Steve Jarrell
                    2025 BMW R1300GS
                    2025 Can-Am Spyder
                    Garmin XT3
                      Steve Jarrell
                      Steve Jarrell
                      Steve Jarrell
                      @Con-Hennekens You are right. My mistake. It's called "Car" so I'm not set on Motorcycle, but I still get the message every time I switch to OSM. What driving mode are you using in your profile?
                      Thanks!
                      Steve Jarrell
                      2025 BMW R1300GS
                      2025 Can-Am Spyder
                      Garmin XT3
                      BertM 1 Reply Last reply
                        Steve Jarrell
                        Steve Jarrell
                        Steve Jarrell
                        @Con-Hennekens I overlooked the first part of your post. Thanks for the detailed explanation!
                        Steve
                        Steve Jarrell
                        2025 BMW R1300GS
                        2025 Can-Am Spyder
                        Garmin XT3
                          Thanks!
                          @Steve-Jarrell
                          When i open de route you linked in a previous post the profile is set to motorcycle…
                          BertM Steve Jarrell 2 Replies Last reply
                          • BertM BertM
                            @Steve-Jarrell
                            @BertM ![alt text](IMG_0486.jpeg image url)
                            • BertM BertM
                              @Steve-Jarrell
                              Steve Jarrell
                              Steve Jarrell
                              Steve Jarrell
                              #25
                              @BertM Yes, I've changed it back and forth several time experimenting trying to figure out what's going on.
                              If you look at my previous post you'll see where I took a screenshot of my profile setting set to "Car' at the exact same time that the error message is appearing.
                              I even thought that perhaps MRA considered the routing mode when the route was created from the track and then ignored it from then on, however I created the route from scratch by importing a .gpx file with the mode set to Car, and as soon as I did I got the error message.
                              Thanks for the response!
                              Steve Jarrell
                              2025 BMW R1300GS
                              2025 Can-Am Spyder
                              Garmin XT3
                                It's specifically the road after waypoint 26 that gives way longer estimates than other map sources. It's based on the realistic travel time HERE tracks for that section and my guess is that their data on that is wrong.
                                Either incorrect speed limit or some anomalies in their realistic travel time estimation
                                Steve Jarrell
                                Steve Jarrell
                                Steve Jarrell
                                @Corjan-Meijerink After riding the route last Wednesday it is possible the HERE map is using information about the roads when they were really torn up after Hurricane Helene at the end of last year as some of them were still in pretty bad shape when we rode them and you could see where one lane the road had been washed completely out.
                                If the HERE map is using data from late last year it is likely that at that time their estimation of the time that it would take to ride this route would be accurate. Perhaps a future map update will resolve the issue. That's a very plausible explanation.
                                Thanks! I don't like mysteries, and I'll consider this one solved! 🙂
                                Steve Jarrell
                                2025 BMW R1300GS
                                2025 Can-Am Spyder
                                Garmin XT3
                                martin-phogel.de
                                martin-phogel.de
                                Steve Jarrell
                                Steve Jarrell
                                • Lock route editing
                                  47
                                • Positioning club Membership Locations every new planned route
                                  OGRIII
                                  OGRIII
                                  13
                                  27
                                  349
                                • F012 Tracklog folder / routes folder / how is it going right now?
                                • Bug with Avatar on profile
                                • F010 Display error – group jumping onto routes 0 ?
