  4. Travel time discrepancies
26 Posts 6 Posters 12.4k Views 4 Watching
  • Steve Jarrell Steve Jarrell
    @Herman-Veldhuizen Thanks for your respons Herman. With the TomTom and OSM maps I'm finding the calculated route times to be very accurate. With the HERE maps I find it to be inconsistent.
    The only thing that I can surmise is that the route calculations and the calculations that create a route from a track are built into the maps themselves and MRA has very little, if any, control over them otherwise the HERE map would not be inferior to the other two in this regard.
    I also switched from Kurviger as I find the user interface to be very, very unintuitive whereas I find MRA to be extremely easy to use. I also find MRA's tech support to be excellent, and the user forum is extremely helpful as well.
    Unless someone can show me why there are important advantages to using the HERE maps as the default I'm going to make the OSM maps my default, and hopefully the MRA developers will fix the bug that causes the following dialog to appear when I switch to the OSM map or import a track into it even though I have my driving mode set to "Driving" which, according to MRA, should avoid this message:
    @Steve-Jarrell I never really looked at the route times, only the ETAs while navigating.
    But now I did for one of my routes which goes mostly over a highway
    Route time for MRA-OSM is noticeably longer than MRA-Here! Kurviger is the slowest.
    220km, paths are very similar in all 3.
    MRA Here: 2h 52m
    MRA OSM: 3h 13m
    Kurviger: 4h 4m
      MRA Here: 2h 52m
      MRA OSM: 3h 13m
      Kurviger: 4h 4m
      Steve Jarrell
      Steve Jarrell
      Steve Jarrell
      @Herman-Veldhuizen Thanks Herman.. That's weird..... there doesn't seem to be any consistency. My "gold standard" is normally Waze or Google maps as I find them to be extremely accurate, but since you can't upload a specific route into either they're of no help. Although you can import a track into Google MyMaps it really doesn't create a Google route from it, so it uses the tracks time information so that's no help.
      I could be wrong so if I am someone please let me know. I'm here to learn.... that's half the fun! 🙂
      If I have time I'll go back and compare 5 or 6 of our group's tracks/routes and compare them in MRA using the HERE, OSM and TomTom maps.
      Thanks for your input. I really appreciate it!
      Steve Jarrell
      Western North Carolina US
      2025 BMW R1300GS
      2025 Can-Am Spyder
      DMD T865-X 8" Tablet
      Garmin XT3
        @Steve-Jarrell said in Travel time discrepancies:
        The biggest advantage to use HERE maps for planning is the least chance for the planner map to be different than the navigation map. The advice is to plan your route on map that is ost equal to the one you navigate with. For MRA Navigation that is HERE, as is for Garmin devices. There are many differences in maps between OSM and HERE, especially in rural mountenesque areas.
        I am not aware of a driving mode called "driving". I only get this message when I switch from HERE or TomTom to OSM while I have "Motorbike" selected as driving mode.
        Steve Jarrell 2 Replies Last reply
        • MartinW MartinW
          It looks like MRA is using the Garmin extensions to do their track and route calculations whereas Kurviger doesn't.
          To avoid confusion: Using GPX extensions (like "Garmin extensions") is a way to store additional information in a gpx file that is not part of the core gpx data model. The most popular example is the differentiation between VIA and shaping route points using the garmin:trp extension.
          For time information, however, there is no need to use an extension as this is part of the core gpx data model.
          And it's about storing information and has nothing to do with time calculation.
          Steve Jarrell
          Steve Jarrell
          Steve Jarrell
          @Martin-Wilcke Thank you for the explanation!
          Steve Jarrell
          2025 BMW R1300GS
          2025 Can-Am Spyder
          Garmin XT3
          • MartinW MartinW
            I definitely see the disadvantages of using the HERE map over using the OSM map in MRA. Can anyone tell me the actual advantages?
            There is one I'm aware of: consideration of road closures.
            Steve Jarrell
            Steve Jarrell
            Steve Jarrell
            @Martin-Wilcke Thank you.
            That's one that I prefer not to use anyway as I've found (in our area at least) that often it's not accurate, or I'm creating a route that I'll be riding when they don't exist so I almost always disable it anyway.
            Steve Jarrell
            2025 BMW R1300GS
            2025 Can-Am Spyder
            Garmin XT3
              Steve Jarrell
              Steve Jarrell
              Steve Jarrell
              @Con-Hennekens You are right. My mistake. It's called "Car" so I'm not set on Motorcycle, but I still get the message every time I switch to OSM. What driving mode are you using in your profile?
              Thanks!
              Steve Jarrell
              2025 BMW R1300GS
              2025 Can-Am Spyder
              Garmin XT3
              BertM 1 Reply Last reply
                Steve Jarrell
                Steve Jarrell
                Steve Jarrell
                @Con-Hennekens I overlooked the first part of your post. Thanks for the detailed explanation!
                Steve
                Steve Jarrell
                2025 BMW R1300GS
                2025 Can-Am Spyder
                Garmin XT3
                  Thanks!
                  @Steve-Jarrell
                  When i open de route you linked in a previous post the profile is set to motorcycle…
                  BertM Steve Jarrell 2 Replies Last reply
                  • BertM BertM
                    @Steve-Jarrell
                    @BertM ![alt text](IMG_0486.jpeg image url)
                    • BertM BertM
                      @Steve-Jarrell
                      Steve Jarrell
                      Steve Jarrell
                      Steve Jarrell
                      #25
                      @BertM Yes, I've changed it back and forth several time experimenting trying to figure out what's going on.
                      If you look at my previous post you'll see where I took a screenshot of my profile setting set to "Car' at the exact same time that the error message is appearing.
                      I even thought that perhaps MRA considered the routing mode when the route was created from the track and then ignored it from then on, however I created the route from scratch by importing a .gpx file with the mode set to Car, and as soon as I did I got the error message.
                      Thanks for the response!
                      Steve Jarrell
                      2025 BMW R1300GS
                      2025 Can-Am Spyder
                      Garmin XT3
                        It's specifically the road after waypoint 26 that gives way longer estimates than other map sources. It's based on the realistic travel time HERE tracks for that section and my guess is that their data on that is wrong.
                        Either incorrect speed limit or some anomalies in their realistic travel time estimation
                        Steve Jarrell
                        Steve Jarrell
                        Steve Jarrell
                        @Corjan-Meijerink After riding the route last Wednesday it is possible the HERE map is using information about the roads when they were really torn up after Hurricane Helene at the end of last year as some of them were still in pretty bad shape when we rode them and you could see where one lane the road had been washed completely out.
                        If the HERE map is using data from late last year it is likely that at that time their estimation of the time that it would take to ride this route would be accurate. Perhaps a future map update will resolve the issue. That's a very plausible explanation.
                        Thanks! I don't like mysteries, and I'll consider this one solved! 🙂
                        Steve Jarrell
                        2025 BMW R1300GS
                        2025 Can-Am Spyder
                        Garmin XT3
                        MartinW
                        MartinW
                        Steve Jarrell
                        Steve Jarrell
                        • reis in concept kopieren
                        • Suggestion: Route Auto Name
                        • Online map settings
                          MartinW
                          MartinW
                        • Trips, interaction with Clubs
                          Andy Nicholson
                          Andy Nicholson
                        • Globale inhoud van een update en mogelijk wijzigingen.
                          Peter 12m
                          Peter 12m
                        • Move Google Maps up the list
                          JP d
                          JP d
