  4. Compass Rose
Compass Rose
15 Posts 9 Posters 3.2k Views 3 Watching
  • Lenny Oundefined Offline
    Lenny O
    Hello, all!
    Can we PLAEASE, put a compass rose on the navigation screen, better yet have it as an option?
    This would help tremendously with all the confusion with North up, turning maps, etc,....
    THANK YOU!!!
    Herman Veldhuizenundefined Marinus van Deudekomundefined Nick Carthewundefined 3 Replies Last reply
    • Lenny Oundefined Lenny O
      Hello, all!
      THANK YOU!!!
      Herman Veldhuizenundefined Offline
      @Lenny-O As far as I know there is! And you can click on it to change the viewing mode.
      But there is a minor bug, which is that in North up mode the compass does not turn when I turn the map on the screen with two fingers. It does turn in the other modes. But when you select NorthUp why would you turn the map...
      Edit: reading this post again, I assume you meant a compass which turns with the phone. Yes that would be useful, then there is no need to use another app for that.
        Hello, all!
        THANK YOU!!!
        Marinus van Deudekomundefined Do not disturb
        @Lenny-O When you click on the rose the camera view will change and you get a pop up witch camera view is then active.
        It's not a compass itself. I guess that's why you are a bitt confused
          Hello, all!
          THANK YOU!!!
          Nick Carthewundefined Offline
          @Lenny-O
          David Emmettundefined 1 Reply Last reply
            @Lenny-O
            David Emmettundefined Offline
            David Emmett
            I second this from @Nick-Carthew - making the north pointing half of that dial dark/red to make it clear which way north is.
            • Brian McGundefined Offline
              If memory serves me at all, TomTom used to have compass/north pointing indicator built into the location triangle icon which I thought worked brilliantly
              (think it could be toggled to alternatively point to the destination)
              As you are constantly looking at your position location it was an very easy way to quickly know which direction you were headed
              Normally navigate "Routes as Tracks" in Offline mode with Offline Maps
              • David Emmettundefined David Emmett
                @David-Emmett said in Compass Rose:
                I hadn’t realised that I’d made a suggestion!
                I was merely pointing out the compass icon.
                David Emmettundefined Con Hennekensundefined 2 Replies Last reply
                  Lenny O
                  wrote on last edited by Lenny O
                  Actually @Nick-Carthew, I think that @David-Emmett suggestion is FANTASTIC!
                  Can we get it done?
                  Peter Zehentreiterundefined Nick Carthewundefined 2 Replies Last reply
                    Can we get it done?
                    @Lenny-O When I'm traveling in north-facing mode, north is always at the top of the map anyway, please correct me if I'm wrong.
                    That's why it's called north pointing!
                    Why then also the additional information in red on the compass?
                    BMW R 1250 GS
                    BMW Connected Ride Cradle
                    Pixel 9 "online"
                    SPC Universal mount
                    Motorola Edge 40 "offline"
                    Sena SLR 3
                    Sena 50 R
                      Can we get it done?
                      @Lenny-O The compass icon changes after you tap it to indicate which camera view is being used, so I’m not sure that suggestion would work now.
                      Personally, I know which general direction I am travelling in by knowing the direction of my route and by looking at the natural clues that surround me. The sun 🌞 being the biggest clue. So I’m not bothered about having a moving compass needle.
                      • David Emmettundefined Offline
                        David Emmett
                        95% of the time, I know which direction I am heading in too. But there are times when I am riding a relatively convoluted route (because, why not?) and I have gone left-left-right-left-left-left-right so many times that I am briefly confused. And yes, I could (and do) use the sun to orientate myself (except when it's dark, of course), but a simple differentiation of the compass rose would make it much faster and less taxing. Which means I can focus more of my attention on the road, and on riding.
                        It is a very minor change with a big impact, in my opinion.
                          David Emmett
                          @Nick-Carthew Apologies. Perhaps I should have rephrased it. But that icon is exactly the one I would like to have a clearer distinction of north on.
                            Lenny O
                            Ok, look here.
                            In this mode you can not tell looking at the compass which way is North.
                            I guess the point of the Navigation is to make my life easier and not resort to the starts, the sun and other ways to understand my position and direction 🙂
                            • JP dundefined Offline
                              JP d
                              I would like a way to turn the North view off, as I only use Dynamic and Top view. 🍻
                                @Nick-Carthew said in Compass Rose:
                                THAT are the most brilliant ones! 😉
                                Lenny Oundefined
                                Lenny O
                                JP dundefined
                                JP d
                                David Emmett
                                • Newbie from Copenhagen
                                • Pricing options
                                  Rob Verhoeffundefined
                                • Sharing Routes and Tracklogs
                                  KevN1k 0undefined
                                  KevN1k 0
                                • Route Color line option?
                                  1.7k
                                • Routepunten automatisch overspringen
                                • Editing saved route
                                  KevN1k 0undefined
                                  KevN1k 0
                                • OU peut on changer les couleurs de la route
                                  LE DIZES Freddyundefined
                                  LE DIZES Freddy
                                  M. Schrijverundefined
