  4. Waypoint automatic renaming when moved
18 Posts 9 Posters 4.8k Views 5 Watching
  • Wallace Shackletonundefined Offline
    Wallace Shackleton
    One suggestion would be to disable the automatic renaming of a waypoint if it is moved.
    It is annoying to give a waypoint a special name only to have it automatically renamed if that waypoint is moved, say to slightly fine tune a route.
    EG. If I create a names waypoint such as "Cumnock" moving it to fine tune a route changes it to "22 Mossmark, Cumnock, KA18 4NF, United Kingdom."
    As an aside. One thing that I will have to get better at is not allowing waypoints with names like "22 Mossmark, Cumnock, KA18 4NF, United Kingdom" as it comes out in its entirety when the Garmin XT announces it as part of a route.
    Garry Davisundefined Con Hennekensundefined 2 Replies Last reply
    • Wallace Shackletonundefined Wallace Shackleton
      Garry Davisundefined Offline
      Garry Davis
      @Wallace-Shackleton If I'm not wrong, when you've named your waypoint, and you need to move it slightly, when the new name comes up, just press cancel, and your original name stays the same as you put it in, in the first place, well mine does anyway.
      Guzzistundefined nomkoundefined 2 Replies Last reply
      • Garry Davisundefined Garry Davis
        Guzzistundefined Offline
        @Garry-Davis you are right ๐Ÿ˜Š
          This only happend when you have the option enabled. I've diabled that option. Then it will be renamed anyway.
          You can find it under "Toolkit" almost at the bottom of the list.
          Wallace Shackletonundefined 1 Reply Last reply
            @Wallace-Shackleton, Usually the name reflects an address. It is quite logical that the address changes along with the movement of the waypoint. However when you chose to give the waypoint a "sensible" name manually, it would be great if that name could be kept despite any movement.
              That would be nice, indeed
                Wallace Shackleton
                Removing the tick against "Ask for waypoint Name" does work but it only does that. Moving the waypoint will automatically rename it.
                Using Cancel is the best solution thanks for that but it is counter intuitive.
                Who would ever think of selecting Cancel to retain the original waypoint name?
                Thanks for the info but this needs to be addressed by the developers.
                  @Wallace-Shackleton why? It works exactly as intended and the work around is simple.
                    nomkoundefined Offline
                    wrote on last edited by nomko
                    @Garry-Davis said in Waypoint automatic renaming when moved:
                    This does the trick! Just move the waypoint to a new location and instead of pressing Accept, press Cancel! The waypoint is moved to its new location and you keep the name/description you gave that waypoint.
                    | MRA Gold Member |
                    | MRA Next + Kawasaki Z650 |
                      @RetiredWingMan said in Waypoint automatic renaming when moved:
                      Because with that workaround ANY movement triggers an extra click. I tend to move waypoints A LOT to find optimum placement. And only a few of the waypoints are interesting enough for a changed name. Having to click on cancel or accept is NOT what I would want. I'd rather copy the name before moving a waypoint to be able to paste it back after moving it, for the few waypoints for which this is a thing....
                        @Con-Hennekens yes I agrรฉe. For the most shapingpoints itโ€™s no issue at all and for The viapoints I tend to copy the name before moving it
                          Wallace Shackleton
                          I'd agree with you on that count, I used "road" on more than one occasion while editing a 300 mile route that I'm going to post sometime soon.
                          MRA is a good program but it has some insider tricks that seldom show up on the webinars and tips like those mentioned above deserve better recognition.
                            martin-phogel.deundefined Offline
                            martin-phogel.de
                            @Con-Hennekens said in Waypoint automatic renaming when moved:
                            100% agree. I can't imagine a use case where I want a name automatically changed once I've edited it.
                            • martin-phogel.deundefined martin-phogel.de
                              @Martin-Wilcke said in Waypoint automatic renaming when moved:
                              ...I can't imagine a use case where I want a name automatically changed once I've edited it.
                              Use case is: if you set a Waypoint in first planning (to estimate distance) in the middle of a village/city. Later, if you know exactly the restaurant/camping/hotel - if you move the Waypoint - it's good to get automatically the new address in name. If not needed, simply click on button [cancel].
                              I don't understand the long discussion here ๐Ÿ˜‰
                              martin-phogel.deundefined Wallace Shackletonundefined Con Hennekensundefined 3 Replies Last reply
                              • Guzzistundefined Guzzist
                                martin-phogel.de
                                @Guzzist said in Waypoint automatic renaming when moved:
                                The example you mentioned is a different use case: you did not change the name manually.
                                  Wallace Shackleton
                                  @Guzzist There are times when the actual address of the waypoint is irrelevant, there are times when the location of the waypoint itself that matters more, say to mark a turn or a point on the route.
                                  To be really objective, the given address for waypoints generated by MRA are at times useless as they do not include the actual name of the Village or Town the waypoint is located in.
                                  For example This waypoint was generated from a route that I am working on
                                  "7 High Main Street, Ayr, KA6 7QN, United Kingdom" The town mentioned here is actually Dalmellington roughly 20 miles or 40 km away from Ayr.
                                  For reference this is the lat/long of a nearby waypoint located in Dalmellington
                                  55.323021, -4.401105
                                    martin-phogel.de
                                    @Wallace-Shackleton said in Waypoint automatic renaming when moved:
                                    That's exactly my thoughts. I've never understood what an address as a route point name is good for. I prefer LAT/LON as the default name as it's the most simple, versatile and valuable information.
                                      Me neither, but obviously for different reasons ๐Ÿ˜‰
                                      nomkoundefined
                                      Garry Davis
                                      martin-phogel.de
                                      Wallace Shackleton
                                        Carl Leeundefined
                                        Carl Lee
                                        7.4k
                                        haweboundefined
                                        hawebo
                                      • Track vs Route
                                        Roger Needham 0undefined
                                        Roger Needham 0
                                        Travellexxieundefined
                                        589
                                      • Camperroutes
                                        Rob Verhoeffundefined
                                        stuart marrittundefined
                                        stuart marritt
                                        646
