  4. volume mra spotify
volume mra spotify
23 Posts 7 Posters 6.9k Views 6 Watching
  • Adrian Avram Adrian Avram
    @goos-doornewaard I think its something related to MRA. I have the same problem using Android Auto in the car, if I set the music sound level to low, so the MRA voice sound goes to low. Tried Osmand, Waze, Maps and Sygic, and navigation volume is independent from the music volume.
    @Adrian-Avram said in volume mra spotify:
    No it is something related to the OS. Android does not offer a seperate audio channel for navigation. Therefore the navigational directions are mixed into the media channel, which also hosts the music from apps like Spotify and YT Music. You cannot set the volumes independently because of this. Certain Samsung models seems to have what Samsung calls "Volume per App". I have not seen this in practice, but it seems to offer a method to set volume independent from other apps, which is a great solution that not many enjoy. I don't know exactly the situation in IOS, but I assume Apple offers a separate Navigation channel? Maybe someone can fill this in for me 😉
      Hubert Thoring Offline
      @Adrian-Avram
      @goos-doornewaard
      @Marinus-van-Deudekom
      To Appel, there it also behaves like that although I have never found it disturbing, the audio signal can be adjusted under account, navigation settings, audio via the volume down buttons, s. Audio sample.
      A hint, it helps to reduce the number of announcements per WP, then there is more time for the music ...
      • Goos Doornewaard Offline
        Goos Doornewaard
        Bedankt voor jullie feedback ik heb een app gevonden waar ik per app afzonderlijk geluids volume kan af spelen
        • Goos Doornewaard Goos Doornewaard
          @goos-doornewaard, dan ben ik wel zeer benieuwd welke app dat is 😉
            Marinus van Deudekom Offline
            @Con-Hennekens it's called sound assistant
              Goos Doornewaard
              Galaxy store sound assistent
              Goos Doornewaard 1 Reply Last reply
                Goos Doornewaard
                @goos-doornewaard werkt perfect kunt er verschillende apps in zetten
                  Adrian Avram Offline
                  @goos-doornewaard just installed it and added MRA Next. I will give it a try tomorrow.
                  Adrian
                  • M. Schrijver Online
                    M. Schrijver Online
                    In Android Auto kan je wel apart volume hebben voor je navigatie app t.o.v je media app. Dit is onafhankelijk van het merk smartphone. Alleen MRA Next ondersteunt dit niet.
                    Sound assistant lijkt een Samung only app te zijn.
                    Wat op alle Android smartphone werkt, is een andere TTS engine.
                    Ik gebruik Acapela TTS. Kost een paar euro maar je hebt dan wel stemmen die een volume hebben die overeenkomt met andere apps op je smartphone. Hierdoor heb je geen volume verschil meer tussen bijv Spotify en MRA Next.
                      @M-Schrijver said in volume mra spotify:
                      Laat mij even een Android native screenshot zien van de audio channels waarin apart Navigatie volume staat dan? Mijn Pixel heeft dat niet, meer Native Android dan dan een Pixel vind je niet.
                        M. Schrijver Online
                        Android op je telefoon inderdaad niet. Tenzij je een losse app weet.
                        Android Auto heeft deze functie wel.
                          M. Schrijver Online
                          Wellicht is dit wat voor Android gebruikers
                            Goos Doornewaard
                            ik heb deze gevonden voor android sound assistant
                            • JP d Offline
                              JP d Offline
                              JP d
                              My one plus 12 has a separate control for music. So I have MRA (phone volume) to max and YT music volume to 70%.
                                #20
                                De letterlijke tekst uit de play store:
                                Het is niet mogelijk om een ​​achtergrondapp en een voorgrondapp met
                                verschillende volumes te hebben, dit is een Android-beperking.
                                Ik heb die app in het verleden al eens geprobeerd, maar het werkt niet zoals we willen helaas.
                                @goos-doornewaard said in volume mra spotify:
                                Sound Assistant is Samsung Only helaas.
                                  M. Schrijver Online
                                  Ben even aan googlen geweest. Het lijkt erop dat dit de enige 2 opties zijn voor Android.
                                  Blijft alleen een andere TTS Engine over.
                                  Zoals gezegd gebruik ik Acapella. Deze heeft ook nog als bijkomstigheid dat de volume van de stemmen hoger is.
                                  Voor zover mijn oren het kunnen beoordelen (linker oor is niet geweldig meer), is het volume van de Acapella stem iets hoger dan die van Spotify.
                                  Gezien de regelmatige klachten van gebruikers over het volume van de aanwijzingen is het wellicht een overweging voor MRA om zelf met een betere oplossing te komen.
                                    @M-Schrijver, Ik heb Acapela een tijd geleden ook geprobeerd, maar het kan mij niet bekoren. Veel achtergrondruis bij de stemmen, die erg artificieel klinken. En dat ze duidelijk luider waren kan ik helaas ook niet zeggen.
                                    Het wordt tijd dat Android en extra Navigatie kanaal introduceert. Als het voor Android Auto kan, kan het ook in Android Native...
                                      M. Schrijver Online
                                      De ruis kan ik beamen maar hindert mij niet. Ik vind de stem die ik gekozen heb (mannelijke stem) juist veel minder artificieel dan die vervelende scherpe monotone vrouwenstem van Google.
                                      Dat scherpe van de Google stem wordt erger naarmate het volume hoger wordt. Ik rij juist met een hoog volume.
                                      Bij een Cardo headset betekent dit altijd maximaal, wat soms nog te zacht is. Bij Sena op ongeveer 75%. Die gaat merkbaar luider.
                                      Goos Doornewaard
                                      Goos Doornewaard
                                      JP d
                                      JP d
                                        13.7k
                                        1.1k
                                      • HERE maps updates
                                      • Carpuride scherm vast
                                        De Ploey Georges
                                        De Ploey Georges
                                        1.2k
                                        Philip Verbeek
                                        Philip Verbeek
                                      • Latest version of the App?
                                        1.6k
