  4. when will you solve this problem?...
20 Posts 9 Posters 3.8k Views 5 Watching
  • Albyus Offline
    Albyus Offline
    Albyus
    You told me months ago but still no news. When will you solve the problem that if I open Myroute from Android auto the navigation doesn't start and I have to stop and start the program on the smartphone? I'm sorry I bought the full version. Even the simplest programs like WAZE do not have these problems.
    Corjan Meijerink Mzokk 2 Replies Last reply
    • Albyus Albyus
      Corjan Meijerink Offline
      @Albyus sorry, what exactly is the issue?
      Android Auto works quite well at this moment for most users.
      Albyus 1 Reply Last reply
        Albyus Offline
        Albyus Offline
        Albyus
        @Corjan-Meijerink When I'm on my motorbike and I start MRA from Android auto on my Carpuride, the app starts but the map is completely freeze. I have to use my smartphone, restart the application and then it finally works
        • Albyus Albyus
          Marinus van Deudekom Offline
          @Albyus that is most strange. I've used MRA with Android Auto 5 times this week with no problems what do ever. Witch version do you use
            Albyus Offline
            Albyus Offline
            Albyus
            wrote on last edited by Albyus
            @Marinus-van-Deudekom 4.3.6 - 382 you use it on the tablet, I use it on Android Auto, Carpuride
            • Albyus Albyus
              @Albyus Sorry I did not mention that I used it 5 times laat week in Android Auto in my car, like I said without any problems. We use the same version
              • Albyus Albyus
                Mzokk Offline
                Mzokk Offline
                @Albyus check your app settings in Android so the the app automatically launches AA when connected to a device. I’ve used the new version of the app a few times this week wired and wirelessly in my vow car and my Honda Africa Twin. No issues for me.
                • Mzokk Mzokk
                  Albyus Offline
                  Albyus Offline
                  Albyus
                  @Mzokk You haven't understood, the problem is that when I start the application from the AA screen, MRA starts but then remains freezed, so I have to stop, use the smartphone, close the application and reopen it to make it work
                  Nick Carthew Mzokk 2 Replies Last reply
                  • Albyus Albyus
                    Nick Carthew Online
                    Nick Carthew Online
                    @Albyus said in when will you solve this problem?...:
                    Because there are no other reports of this behaviour, maybe you need to uninstall and reinstall the app. Sometimes a bug can creep in and normally a reinstall cures the problem.
                    You haven’t said what Android phone you are using.
                    You could also try to re-establish the Bluetooth connection to your AndroidAuto device
                      Albyus Offline
                      Albyus Offline
                      Albyus
                      @Nick-Carthew https://forum.myrouteapp.com/topic/8160/problemi-di-avvio-applicazione?_=1739009632905 I don't think I'm the only one with this problem, however I use Carpuride and OPPO Find 5X as my phone
                      • Albyus Albyus
                        Mzokk Offline
                        Mzokk Offline
                        @Albyus Ah! Got it. No I haven't had that problem at all.
                        • Albyus Albyus
                          Nick Carthew Online
                          Nick Carthew Online
                          @Albyus Thank you for the update.
                          Can you try to re-install the app and also delete and re-establish the Bluetooth connection between your phone and Carpuride.
                            Albyus Offline
                            Albyus Offline
                            Albyus
                            @Nick-Carthew ok, I reinstalled the application, then I disconnect and reconnect the bluetooth and I'll tell you
                            • peha Offline
                              peha Offline
                              peha
                              It might also be worth to take a look at the permissions. In my setup (smartphone + Carpuride), I started having problems someday when initializing app usage via my Carpuride device; it turned out that my smartphone had downgraded some of MyRoute-app's permissions automatically from "always" to "while the app is used" - as soon as I re-set them (and particularly the location permission) to always, the "freezing problems" disappeared immediately.
                              VOGE DS 900 X: AA with Carpuride W702 (via Samsung S22 Ultra)
                              Skoda Citigo: AA with Carpuride W903 (via Samsung S22 Ultra)
                              Marinus van Deudekom Albyus 2 Replies Last reply
                              • peha peha
                                @peha that could explain the behavior mentioned. Good tip
                                • peha peha
                                  Albyus Offline
                                  Albyus Offline
                                  Albyus
                                  @peha that's the first thing I obviously checked Screenshot_2025-02-08-12-46-33-05_ab1359306de43320f9557c797b1c4be5.jpg
                                  • peha Offline
                                    peha Offline
                                    peha
                                    Does positione (location) posess the right to "always" access location?
                                    • Gary Coates Offline
                                      Gary Coates Offline
                                      Gary Coates
                                      Hi
                                      I have a carpuride w702 and a samsung galaxy a53 running android 14.
                                      With my phone locked I powered up the carpuride, waited for android auto to connect and then started MyRouteApp. I was able to search, pick a recent destination and start to navigate.
                                      As I couldn't find this anywhere else I have started a list of things to do when setting up my phone. Maybe there is something here that might help:-
                                      Android phone:-
                                      • Text to Voice settings. Make sure it’s “Google TTS”
                                      MyRouteApp:–
                                      • Account – Offline Maps – DOWNLOAD MAPS THAT COVER YOUR EXPECTED ROUTE
                                      • Routes & Tracklogs – 3 dots menu – Sync all my routes - ON
                                      Android Settings - App Info:-
                                      • Remove app permissions if app is unused - OFF
                                      • Battery – OPTIMISED
                                      • Mobile Data – Allow background data usage - ON
                                      • Ensure pause activity is off
                                      • Permissions
                                      ◦ Location – ALLOW ALL THE TIME
                                      ◦ Pause app activity if unused - OFF
                                      General:-
                                      • Connect headset to phone.
                                      • Need to use phone handset for zoom and panning.
                                      • white.mouse Offline
                                        white.mouse Offline
                                        I suddenly had the same problem yesterday. Going to an entered address with route there was no problem at all but when I drove back, to my home address and I chose this also as route, the cursor both in MRA and in Android car indeed stayed at the place where I left. Like the map was frozen. A few hundred metres down the road I pulled over to the side of the road and stopped the route and restarted it again and then it worked as normal. I entered my home address as a favourite and when I chose this as my destination I was given three choices for the route. Selected one of these and started this route. Route was displayed and calculated nicely. Only when I started driving, the cursor in Android Auto stayed on the starting point.
                                        Ik had gisteren ineens hetzelfde probleem. Heen naar een ingevoerd adres met route was er geen enkel probleem maar toen ik terug reed, naar mijn thuis adres en ik dit ook als route koos, bleef de cursor zowel in MRA als in Android auto inderdaad op de plek staan waar ik vertrok. Net of de kaart bevroren was. Een paar honderd meter verder even aan de kant van de weg gaan staan en de route gestopt en weer opnieuw opgestart en toen werkte het weer gewoon.
                                        Ik heb mijn thuisadres als favoriet ingevoerd en toen ik dit als bestemming koos kreeg ik voor de route drie keuzes. Een van deze gekozen en deze route gestart. Route werd netjes getoond en berekend. Alleen toen ik ging rijden bleef de cursor in Android Auto op de vertrekplaats staan.
                                        • Paul Hartley Offline
                                          Paul Hartley
                                          Having the same issues with My route app and chigee A10-5 lite the map freezes but still gives info on next turning.
                                          peha
                                          peha
                                          Albyus
                                          Albyus
                                          Gary Coates
                                          Gary Coates
                                          Paul Hartley
                                          Paul Hartley
                                          • Is there a way to put a Home button in the program
                                            Mike wiruth
                                            Mike wiruth
                                            rudi 2h 0
                                            rudi 2h 0
                                            729
                                          • Google maps and Streetview
                                            Stevedo 6 0
                                            Stevedo 6 0
                                            644
                                          • Route doesn’t recalculate to my destination
                                            Stevedo 6 0
                                            Stevedo 6 0
                                          • How do i export or 'save as' a file into Garmin Camper 770 - Help
                                          • Traffic information
