  4. gpx 1.1 vs 1.2
gpx 1.1 vs 1.2
23 Posts 10 Posters 11.8k Views 6 Watching
  • Carl Lee
    Carl Lee
    Carl Lee
    I'm also still trying to find the best way of using MRA/Tread/XT2. Tread will definitely not play nicely with gpx1.2 is the first thing - it's purely a MRA file that nails a route to your track in the Zumo. The shaping points are stripped so Tread will build its own route using whatever parameters are set within the app.
    However, you can transfer gpx1.2 via cable but now I'm finding Tread will sometimes mess with those routes after a sync. I suppose a check before departure that your MRA route and Tread agree might stop this but what a faff. A quick workaround if you're on tour and it happens is to delete the route, re-import (as it should still be there if you haven't done another cable transfer), make sure it overlays your track then start the route immediately before another potentially route destroying sync.
    gpx1.1: This is the file of choice and seems to work a lot of the time. Enough Shaping and/or Via points need to be used so that Tread builds exactly the same route as MRA otherwise your XT2 may refuse to calculate the route, though sometimes it will! I'm not over keen on Via points as if you don't go to them, the Zumo will try to route you back there. There is a 'skip' option but that can totally destroy the rest of your route. With both the above files, you will also be sent your track. As others have mentioned in previous posts, it's a really good idea to widen the track and put it in a visible collection where you can see any route deviations. Bright red for the track seems to show well in the XT2.
    You can simply follow the Track or even create a route from it which will be accurate but you then lose any Via points you may have added. Fine a lot of the time.
    I would like to be able to export my MRA routes in gpx1.1 via both cable when at home and Tread whilst away without Tread destroying all the good work. It would be great if you could only sync what and when you want. Disabling Tread means you lose everything else it provides. It's a Garmin problem, I know .By the way, if you haven't read elsewhere, you can now leave auto-recalculate switched on with gpx1.1 and it will bring you back to your route if you deviate. gpx1.2 will do similar but seems to prefer turning you around and sending you miles back to a previous point.
    Apologies if this is all stuff you know but I'd love to hear any other suggestions anyone has to make MRA (or any other imported pre-built GPX route) and Tread play nicely all the time.
    Hubert Thoring 2 Replies Last reply
    • Carl Lee Carl Lee
      @Carl-Lee
      Hey, try copying it from your phone to the XT2 with a cable when you're on the go. It works with the BMW N6 navigation system, (iPhone Xr) see picture.
      File on the N6 on the Garmin internal memory in the /GPX folder
      File on the additional memory card in the /Garmin / GPX folder
      Hey versuche das doch mal für unterwegs, vom Handy mit Kable an den XT2 zu kopieren, beim BMW-Navi N6 geht es mit einem (iPhone Xr) s. Bild.
      Datei beim N6 auf dem Garmin internen Speicher in Ordner /GPX
      Datei auf die zusätzliche Speicherkarte unter Ordner /Garmin / GPX
      s. Bild !
      Carl Lee 1 Reply Last reply
      • Carl Lee Carl Lee
        @Carl-Lee :
        MRA - Drive - XT geht gut
        MRA - Tread - XT2 ..? maybe also works MRA - Drive - XT2
        Garmin Drive App !!
          @Carl-Lee :
          Garmin Drive App !!
          @Hubert-Thoring Nope Drive only works with the XT
          • Alasdair Denton-Miller Alasdair Denton-Miller
            I have a question regarding exporting gps files from MRA to Garmin XT2....and how the XT2 reshapes routes differently with the two file types.
            My workflow is to create my routes using MRA on my laptop, then export them from the MRA app on my iPhone to Garmin Tread. This then automatically syncs the routes with the Garmin XT2 (which is a pretty cool feature).
            I use named Via points, and quite a few additional shaping points to define the routes.
            If I export to Tread using the gps 1.2 formate, then it appears that all shaping points are lost and the XT2 simply routes directly between the Via points - which basically loses all the lovely twisty roads I have lovingly crafted the route around.
            The workaround is to turn all shaping points into Vias - but this is not a good solution as you then end up with loads of confusingly named Via points.
            However, if I export to Tread as gps 1.1, then the routes come across normally with all the shaping points intact and the XT routes perfectly.
            I have read somewhere on a Zumo users forum, that in the case of the gps 1.2 format, MRA actually does not export the shaping points, but instead sends many (hundreds?) "ghost points", (route extensions?). It appears that the Zumo XT2 ignores these completely.
            Does anyone know if this is correct - and why it works this way?
            I am currently just exporting using px 1.1 which works just fine, but I am intrigued as to why gpx 1.2 works this way and doesn't include shaping points?
            Hans van de Ven MR.MRA
            @Alasdair-Denton-Miller
            See this blog: https://info.myrouteapp.com/blog-routes-loading-garmin-zumo-xt/
            In short: gpx 1.1 is a route with shaping and via points
            gpx 1.2 is a route-track with via points
            In the XT2 you have to link the track to a collection
            See all the options in the Explore icon on the XT2
            There are indeed some issues regarding a Mac and the XT(2). See also: https://forum.myrouteapp.com/topic/1396/garmin-zumo-xt-mac?_=1722582031290
            There are 2 ways to put the route in your XT(2):
            1. Save the route as gpx 1.1 (this will be placed in the download folder) move the gpx file using Android File Transfer to the GPX folder on the XT(2)
            2. Download the MRA App "My-Route-app" from the app store.
              Download the Garmind Drive-App (XT) or the Garmin Tread (XT2)
              Log in with your MRA account
              Go to routes in the app, open the route, choose download, choose export, then choose the Garmin Drive App (XT) or Tread (XT2).
            If you have connected the App to your XT with your Garmin account, the route will be transferred to the XT(2)
            In both cases, restart the XT(2) and you will receive a message that there is a new route that you can import. Choose Yes.
              @Carl-Lee
              s. Bild !
              Carl Lee
              Carl Lee
              Carl Lee
              @Hubert-Thoring yes, I'd seen your phone cable which is certainly an option to put gpx1.2 to the XT2. And as you've seen, it has to be Tread otherwise. I'm actually happy with gpx1.1 if I can manage to get it right all the time.
              The issue most of us seem to be having is Tread getting hold of our pre-built routes and changing them should we not have enough shaping points. I've tried using the MRA 'expand' option but yet again, not usually compatible with Tread, I think due to the random nature of where it places the points. So it's a case of manual input of a limited amount of shaping points in order to try to stop Tread thinking better. I think any more than 50 per route and it also goes tilt and will not calculate.
              It's a different beast this XT2 but I love MRA and want to keep using it. The Tread planning function is a half decent compromise on the move to plot a diversion etc. but definitely nowhere near as good.
              • Andy Beviere
                Andy Beviere
                Andy Beviere
                wrote on last edited by Andy Beviere
                #17
                All,
                Forgive me for coming to the party late!
                I have wasted hours of my life on this sh*t show that Garmin think is acceptable to release to paying customers!! Please see my findings below…
                The unit itself (XT2) is generally flawless if used itself to get from A to B, if however like me you tour a lot and want to share and plan routes around certain points/locations with MRA (best route software out there) All the options below are for OTA file transfer using the MRA app and the Tread app.
                GPX 1.0 route will work but no shaping points shown on the map but works!
                GPX 1.1 Track/POI convert to route on the unit, works!
                GPX 1.1 Route/Track/POI works but you have to check and if necessary adjust the route on the unit.
                GPX 1.2 Drops the shaping points and adjusts the route between the via points… I have absolutely no idea why…? This option is definitely no good!
                Thanks for an amazing piece of software MRA!
                Andy.
                • Andy Beviere Andy Beviere
                  All,
                  Andy.
                  @Andy-Beviere
                  gpx 1.2 is a route-track with via points, works fine in de XT and XT2, but it needs via points in a route (max 28)
                  Andy Beviere 1 Reply Last reply
                    @Andy-Beviere
                    Andy Beviere
                    Andy Beviere
                    Andy Beviere
                    @Hans-van-de-Ven-MR-MRA
                    Hi Hans,
                    Many thanks for your reply but unfortunately in my-case this is incorrect, if I send a route from MRA to Tread and onto the XT2 over the air only the via points are shown and the unit changes the route between the via points, obviously this could be my error but believe me I’ve tried and tried…
                    Just to reiterate this is file transfer over the air and my issues are when the route is viewed on the unit not on MRA or Tread.
                    Thanks again,
                    Andy.
                    • Skellum
                      Skellum
                      Skellum
                      @Andy-Beviere said in gpx 1.1 vs 1.2:
                      Hi Hans,
                      Thanks again,
                      Andy.
                      Hi Andy,
                      Not sure if you have seen this earlier post from Steve Jarrell that really explains how 1.2 works and why he feels it is better to use than 1.1
                      https://forum.myrouteapp.com/topic/2734/gpx-1-1-vs-1-2-simple-explanation
                      Hope it helps
                      Tony
                        Hi Hans,
                        Thanks again,
                        Andy.
                        martin-phogel.de
                        martin-phogel.de
                        martin-phogel.de
                        It's not the unit (XT2); the Tread app causes the problem.
                        GPX 1.2 is similar to the basecamp format: You have your VIA points, and the route segments in between are shaped with a lot of "hidden shaping points" (gpxx:rpt extensions):
                        When transferring a GPX 1.2 with USB to your XT2, these hidden points are preserved, but when using the Tread App, these points are filtered out.
                        So, for your case (XT2, transfer with Tread), GPX 1.1 is the only useful choice.
                        (By the way, it's not an issue with an XT(!), as the Drive App (not Tread) transfers the GPX to the unit, which preserves the hidden points).
                          Andy Beviere
                          Andy Beviere
                          Andy Beviere
                          @Martin-Wilcke
                          Hi Martin yes totally agree, its when the route goes from the Tread app to the XT2…
                          Many thanks,
                          Andy.
                          • Skellum Skellum
                            Hi Hans,
                            Thanks again,
                            Andy.
                            Hi Andy,
                            Hope it helps
                            Tony
                            Andy Beviere
                            Andy Beviere
                            Andy Beviere
                            @Skellum
                            Ooooh Thanks Tony… will have a read!
                            Thanks,
                            Andy.
                            martin-phogel.de
                            martin-phogel.de
                            Carl Lee
                            Carl Lee
                            Skellum
                            Skellum
                            Sam Ellis
                            Sam Ellis
                            Andy Beviere
                            Andy Beviere
                              2.5k
                              2.6k
                            • Elektrisch voertuig
                              778
                            • Altitude numbers size
                            • Eerste keer MRA met Android auto, een wat mindere ervaring
                            • Seizoensafsluitingen
                            • Hoe kan ik in één route een stuk met en een stuk zonder snelwegen plannen
