  3. [App] Announcements
  4. New update! (4.3.5) Very minor changes
12 Posts 5 Posters 4.9k Views 3 Watching
    Hi everyone 🙂
    A very small update is coming your way!
    The main reason for this release is to resolve a very annoying issue for Android Auto users.
    Android Auto
    Resolved issue where Android Auto would sometimes stop displaying the updated location while driving. The instructions would update but your position would remain stationary on the display. This issue should now be resolved.
    HERE version
    We update the core SDK of the app.
    Should result in some minor stability improvements that are not our direct responsability.
    That's it 😉
    Cheers,
    Corjan
      The update is already live for Android! 🎉
      peha 1 Reply Last reply
        Hi everyone 🙂
        Android Auto
        HERE version
        That's it 😉
        Cheers,
        Corjan
        @Corjan-Meijerink yes I can confirm that it works fine now. Just tested the new version !
        Adrian
        • Adrian Avram Adrian Avram
          @Adrian-Avram Great! 🙂
            peha
            peha
            peha
            wrote on last edited by peha
            @Corjan-Meijerink I have tried the updated app. For me, on the Android Auto display when just driving (no navigation ongoing), the position still doesn't update until I unlock my phone once. As soon as I do that, it updates my position on the map correctly, and it stays that way even if I then lock my phone again. But it seems that the initial unlocking is crucial, otherwise it doesn't update. I didn't have time to test while routing.
            BMW F 450 GS: AA with Carpuride W702BS Pro (via Samsung S22 Ultra)
            VOGE DS 900 X: AA with Carpuride W702 (via Samsung S22 Ultra)
            Skoda Citigo: AA with Carpuride W903 (via Samsung S22 Ultra)
            • peha peha
              @peha Interesting!
              • peha peha
                @peha, could it be that the MRA app has permission to use location services ONLY when in use? I think running no navigation with the screen locked might not qualify as "in use".
                You can check that in the Android System - Apps settings of your device.
                  peha
                  peha
                  peha
                  @Con-Hennekens Wow, you're absolutely right - this has been the problem apparently! I didn't realize it was set like this, and since I've switched the location permission to always, it works perfectly! It even handles the situation that I start a navigation on the smartphone while the Android Auto device is off, then starting the vehicle (thus turning on the Android Auto device) - and it just takes over both navigation instruction display and voice instructions (to the correct sound device rather than the smartphone's speakers. Thanks a lot! 🙏🏼😊
                    You humble me @Con-Hennekens 😉
                    Thanks for thinking along!
                    I will check if the app can check this permission and warn about potential issues like this.
                      @Corjan-Meijerink yesterday was another test dat using AA. Just to see what’s happening with the location pointer. First a drive whitout a route active. No problem. Phone wasn’t activated,Just the screen of AA.
                      Then tried a route and deviaties from the route a couple of times. No problem at all. The pointer mept the wright location all the times. Alternative was presented fast. D’urine the ride the daylight shifted to nightvidion.
                      No problems at all
                      Conclusion everything is working OK
                      Thnkx team
                      • peha peha
                        @peha, You are most welcome!
                        @Corjan-Meijerink, I know you will make up for this sooner or later... 🤣
                          No problems at all
                          Thnkx team
                          @Marinus-van-Deudekom awesome!
                          peha
                          peha
                          • Route wordt afgesneden
                            Wim Hompes
                            Wim Hompes
                            Jacob Waterweg
                            Jacob Waterweg
                          • OSM Routing with MRA
