  4. Make locking the screen easier
23 Posts 8 Posters 6.3k Views 4 Watching
  • Rob Kelley Rob Kelley
    Hi
    When riding and it starts to rain I need to lock the Next/Nav screen but this is too fiddly whilst riding.
    Can a padlock be added to the nav screen which will take a simple tap to lock the screen and have it as an optional feature under the settings so it can be removed when not wanted?
    Thanks
    @Rob-Kelley It’s only two taps to do this now.
    First tap to open navigation menu, second tap to lock the screen.
    Rob Kelley 1 Reply Last reply
      @Rob-Kelley yeah, sorry. Won't dedicate a permanent on screen button for this 😉
        Rob Kelley
        Rob Kelley
        Rob Kelley
        @Nick-Carthew I know how to it but when I'm wearing thick gloves and doing 70 on a motorway in the rain and snow (yesterday going to the NEC) it's dangerous to try and do this.
        Not everyone has a large screen and remote control, I'm using an iPhone and the text is small and almost impossible to select with big gloves on.
        GSA1250
        HD Street Glide
        XT500 x 2
          @Rob-Kelley Screen space is valuable, so as Corjan has said none will be used for a lock button.
          You could always set the lock before you leave, especially if you expect to see some of the wet stuff.
          • richtea999
            Maybe a double-tap on a non-map area of the screen?
            Like the directions area, top left, which is an easy area to aim for during a ride/drive.
            A nice bright confirmation popup saying 'Locked' could let the user know the double-tap has worked.
            It would also be wise to add a new Setting option to actively enable it just in case innocent new users starting double-tapping randomly, and lock the app.
              Rob Kelley
              Rob Kelley
              Rob Kelley
              wrote on last edited by Rob Kelley
              @Nick-Carthew Ref screen space, it depends on the device being used and as I suggested to have this as an optional object so it can be hidden or shown in the same way some of the other objects are such as Current Road, etc.
              Currently it takes 3 taps on my iPhone 14 Pro:
              1: Tap the 3 dot menu button which is often hidden so hope I'm tapping in the right place,
              2: Scroll down the menu,
              3: Tap Lock Screen (2nd from the bottom).
              This then places a padlock on the screen to be able to unlock it, why not keep this padlock on the screen when it's unlocked and simply tap it to lock/unlock? it doesn't use much space.
              Considering UK law on phone use I really feel having to take eyes off the road for the amount of time to do this is not good and risks a heafty 6 points and fine, yes this will still be the case for one tap but much less likely to be caught as it'll only take a second to do.
              GSA1250
              HD Street Glide
              XT500 x 2
                @Rob-Kelley The developer of the app has already stated that there'll be no on screen button for this.
                If you’re concerned about having your collar felt by the boys in blue,👮 lock your screen before leaving, or invest in some bar buttons.
                  Rob Kelley
                  Rob Kelley
                  Rob Kelley
                  @Nick-Carthew I'm sure he'll still be open to use case scenarios/persuasion as all good software devlopers are, or go with another idea as suggested by richtea999 above.
                  GSA1250
                  HD Street Glide
                  XT500 x 2
                  Neil q 1 Reply Last reply
                    Neil q
                    Neil q
                    Neil q
                    @Rob-Kelley On Android there's an app called Touch Lock that overlays a lock button. Just tried it and it works with MRA. Maybe something similar for iPhone??
                    I tend to agree it would be a useful feature in MRA tho, DMD2 has it.
                    Google Pixel 7 Android 16
                    Samsung Active Tab 3 Android 13
                    Lenovo TBX606X Android 10
                    • Neil q Neil q
                      Rob Kelley
                      Rob Kelley
                      Rob Kelley
                      @Neil-q
                      I've tried iOS Guided Access which kinda works but it's a bit fiddly to enable/disable by triple tapping the side button and it overlays a grey semi transparent box.
                      GSA1250
                      HD Street Glide
                      XT500 x 2
                        @Neil-q
                        @Rob-Kelley There’s a new feature on its way (now in test in beta). Just two little clicks to lock and only one click to unlock.
                          Rob Kelley
                          Rob Kelley
                          Rob Kelley
                          @Rob-Verhoeff said in Make locking the screen easier:
                          good news, thanks for the update.
                          GSA1250
                          HD Street Glide
                          XT500 x 2
                            It's already live in update 4.3.4 😉
                            The button has been moved up in the menu or long press the menu button itself (while navigating) to lock the screen.
                            Rob Kelley richtea999 2 Replies Last reply
                              Rob Kelley
                              Rob Kelley
                              Rob Kelley
                              @Corjan-Meijerink said in Make locking the screen easier:
                              fantastic, just tested and it works.
                              Thanks
                              GSA1250
                              HD Street Glide
                              XT500 x 2
                              • Bouke Ent
                                stupid question from me but how to onlock ?
                                • Bouke Ent Bouke Ent
                                  Rob Kelley
                                  Rob Kelley
                                  Rob Kelley
                                  @Bouke-Ent
                                  When locked a padlock icon will appear on the screen, tap that to unlock.
                                  GSA1250
                                  HD Street Glide
                                  XT500 x 2
                                  Bouke Ent 1 Reply Last reply
                                    @Bouke-Ent
                                    @Rob-Kelley said in Make locking the screen easier:
                                    @Bouke-Ent
                                    thanks, hope it will not effect rain. ok but i will try next spring.
                                      #19
                                      @Corjan-Meijerink Excellent work, Corjan. Thank you.
                                      I knew you could make it happen. 😀
                                      • LennyO
                                        Ok, just my 2 cents on this....
                                        I would love to be able to lock the screen with menu (3 dots) and all the other buttons above it not taking room on the screen. Is that too much to ask for? Maybe a tripple tap or whatever other means are there. There is not that much room on the phone screen to begin with.
                                        • LennyO LennyO
                                          @Lenny-O Long press the 3 dots of the navigation menu will lock the screen.
                                          LennyO 1 Reply Last reply
                                          Rob Kelley
                                          Rob Kelley
                                          Neil q
                                          Neil q
                                          • Testroute segmenten
                                            Alderweireld Rudi 0
                                            Alderweireld Rudi 0
                                            105
                                            Hanza 0
                                            Hanza 0
                                          • Weather as a service
                                            Tegel Werner
                                            Tegel Werner
                                            Andy Smith 5
                                            Andy Smith 5
                                          • Lane view in Android Auto
                                            denWINNE
                                            denWINNE
