  4. MyRoute app does not answer (both car and MC)
16 Posts 4 Posters 3.2k Views 2 Watching
  • Tore Teigene
    Tore Teigene
    Tore Teigene
    For some strange reason it suddenly started on my MC, but it will not follow the route i have set. It shows the blue line to follow (so it knows where i am (gps = ok)) But when i start the ride nothing happens. if i stop and press the comass sign (bottom right on mobile) it repositions to new place (which is correct), but again when continuing the ride nothing happens.
    Tim Watson 1 Reply Last reply
    • Tore Teigene Tore Teigene
      Tim Watson
      Tim Watson
      Tim Watson
      @Tore-Teigene Hi. Assuming you're using Android Auto, when the navigation stops have you tried getting your phone out and clicking the Navigate button on the phone in MRA? That sometimes gets the navigation to start working again on the AA device. Or it crashes MRA completely. One of the two usually happens! 🙂
      Tore Teigene 1 Reply Last reply
      • Tim Watson Tim Watson
        Tore Teigene
        Tore Teigene
        Tore Teigene
        @Tim-Watson
        Jepp.Tried that also. No luck 🤨
          @Tim-Watson
          @Tore-Teigene are you a bêta tester. Because in the last update, 346 the problem was solved.
            Tore Teigene
            Tore Teigene
            Tore Teigene
            @Marinus-van-Deudekom
            At the bottom of the Account page it says 4.3.2 - 346
            Is that the beta version or the official ?
              @Tore-Teigene 346 is only in the beta version
              It seems strange that the problem still exists at your side because I myself and a lot of others voor it working since the update
                Tore Teigene
                Tore Teigene
                Tore Teigene
                Ok, you have any directions on how to go back to the "official" version ?
                  @Tore-Teigene If the problem still exists on your side I would put in a service ticket and get help from our Devs to solve your problem. If you want to leave the Beta program delete the app and start installing it again. My advice would be to keep the Beta version eventhough you might run into some trouble but that's why it's called a beta 🙂
                    Tore Teigene
                    Tore Teigene
                    Tore Teigene
                    Well, when the tool refuses to work it makes no sense to keep it installed.
                    I followed your suggestion buyt i still end up with the same version. There is no option to choose beta version or not from what i can see.
                    Please advice.
                      Please advice.
                      This soûl do the trick
                        Tore Teigene
                        Tore Teigene
                        Tore Teigene
                        Thanks Marinus. I'll give it some more tries before i do the uninstall option.
                        Marinus van Deudekom a white mouse on the motorbike 2 Replies Last reply
                          @Tore-Teigene That would be my idea😁
                            @Tore-Teigene
                            Jeg vet ikke om det hjelper, men prøv å tømme appens hurtigminne. Jeg hadde også noen merkelige problemer her om dagen, og de ble alle løst med det.
                            Ik weet niet of het helpt, maar probeer eens het cache geheugen van de app leeg te maken. IK had laatst ook wat vreemde problemen en die zijn daarmee allemaal opgelost.
                            Tore Teigene
                            Tore Teigene
                            Tim Watson
                            Tim Watson
                              866
                              Andy Beviere
                              Andy Beviere
                            • Trips in Commercial Clubs?
                              Mike West
                              Mike West
                            • The ‘Start route here’ option doesn’t seem to be working properly.
                              Parantapa
                              Parantapa
                              Marcel Versluis
                              Marcel Versluis
                            • Exporting GPX
                              smfollen 0
                              smfollen 0
                            • Na rit vanuit event geen tracklog
                              Hanza 0
                              Hanza 0
