  4. Route calculated via blocked road
offline
17 Posts 6 Posters 4.6k Views 3 Watching
  • Makro
    Makro
    Makro
    Today I was driving, following a route in the app. The road further ahead to the right was closed because of construction work. The app correctly showed that the road ahead to the right was blocked. To my surprise, the route went through the blocked road, which didn't make sense, and wasn't possible.
    Obviously, the route should have been recalculated via other roads.
    The app was set to "offline navigation", which disables "traffic aware route calculations".
    Does this mean that offline use is unable to handle blocked roads?
    Best regards, Makro
    • Makro Makro
      @Makro Unfortunatly: Yes it is... The blocked roads are stored in the mapdata. Mapsupliers are unable to store that data somewhere on your device when you're offline!
      Marinus van Deudekom Makro 2 Replies Last reply
        @Rob-Verhoeff Just to be shure. If you navigating online the problem would not have occurred?
          @Marinus-van-Deudekom That was not the question. And yes, when navigating online should direct you around.
          • Jörgen
            Shouldn't you also consider whether a waypoint is on the closed route? This can sometimes lead to you being sent on such a road.
            Makro 1 Reply Last reply
              Makro
              Makro
              Makro
              @Rob-Verhoeff said in Route calculated via blocked road:
              But when I have downloaded maps for offline use, then road closures are part of those maps, right?
              Best regards, Makro
              Peter Schiefer Rob Verhoeff 2 Replies Last reply
              • Jörgen Jörgen
                Makro
                Makro
                Makro
                @Jörgen said in Route calculated via blocked road:
                Good point, but I didn't see any road closures when creating the route, earlier the same day. It could be caused by me not zooming in sufficiently on the map, but either way, I would expect the app to recalculate during driving, as needed.
                Best regards, Makro
                Jörgen 1 Reply Last reply
                • Makro Makro
                  @Makro I guess you have the Gold subscription. Did you activate the TRAFFIC button in the web planner? It will show closures.
                  • Makro Makro
                    Peter Schiefer
                    Peter Schiefer
                    Peter Schiefer
                    @Makro said in Route calculated via blocked road:
                    Makro
                    Downloaded maps never contains road closures besides maybe those who are in constructions with no substitute over a long period of min a 1/2 year maybe longer reported with a finish date by legal offices, like e.g. collapsed bridges.
                    All other closures of short periods are only visible in traffic overlays which be be send by radio data or web online.
                    Peter
                    • Makro
                      Makro
                      Makro
                      Yes, I have Gold.
                      I cannot seem to find a traffic button in my web planner, but I see this support page has such a Screenshot.
                      Or are you referring to some other way of enabling traffic in the web planner?
                      Best regards, Makro
                      • Makro Makro
                        Yes, I have Gold.
                        @Makro you see this only here.
                        The other planner don’t has it.
                        • Jörgen Jörgen
                          Makro
                          Makro
                          Makro
                          @Jörgen
                          I just realized why we see two different things.
                          I opened https://www.myrouteapp.com/routelab where the map layers button lists no such traffic option.
                          You must have created a new route. You then get presented with a similar map and button, but now, clicking the map layers button, the optional "Traffic" can be selected (at the button of the list).
                          I have no idea why there is such a difference.
                          I did not have the traffic layer/button selected.
                          Best regards, Makro
                          • Makro Makro
                            No! Road closures can only be found on online maps. What do you think happens if you download the maps now and the map provider has included those closures? If you use them a month from now, those road closures may no longer be up to date. So that kind of information is only available online.
                            • Makro
                              Makro
                              Makro
                              I get your point. But I could say the same about offline maps in general, as any type of downloaded and offline data, can get superseded by some change, while offline. So, any road in offline maps, can get changed, like becoming one-way or changed to private use only. Luckily for folks using offline maps, road changes are rare.
                              So, my point is, that using offline data always come with the risk of its data getting obsolete. I wouldn't mind if road closures were part of the offline maps.
                              Best regards, Makro
                              Nick Carthew Peter Schiefer Rob Verhoeff 3 Replies Last reply
                              • Makro Makro
                                @Makro Sorry to jump in on your conversation with @Rob-Verhoeff
                                It is because sometimes roads change and new roads are added that the offline maps receive updates. You do not download an offline map and use it forever.
                                • Makro Makro
                                  Peter Schiefer
                                  Peter Schiefer
                                  Peter Schiefer
                                  @Makro
                                  Few weeks ago I wrote about HERE and how HERE works.
                                  Please look perhaps under my profile.
                                  in Summary again.
                                  HERE is only data collector and collect attributes of the landscape not limited by those thing you recognize when you driving. They do this and the changes in realtime worldwide when the received valid data.
                                  These datas are collected and sold in packages to NaV-Sat Hard-and (final) Usersoftware manufactuer always with a release date. The manufacturer decide now in which sequence they buy updatepackages to update their software. Usual is a sequence of 4 times a year to ones per year.
                                  Traffic infos are overlays on this maps which need no compilation into the colordesign and other manufacturer requests, like what the manufacturer do with received attribute files from HERE and can be distrubuted over network online. The same with TomTom.
                                  Peter
                                  • Makro Makro
                                    I don't completely agree with you. Data such as road closures is temporary or short-lived. Roads — especially the roads that we (motorcyclists) enjoy riding on — don't change that often. I'm not talking about new residential areas popping up like mushrooms. But we don't want to be seen there anyway 😉
                                    Peter Schiefer
                                    Peter Schiefer
                                    Makro
                                    Makro
                                      Rene van Maanen
                                      Rene van Maanen
                                    • _Tracklogs folder nearly empty?
                                    • One crash today
                                    • Tracklogs access at friends and clubs
                                    • 6.0 UI in landscape needs pollishing
                                      Mosimann
                                      Mosimann
                                    • Download club route folders
                                      136
