  4. Synchronisation - A batch of routes?
15 Posts 6 Posters 3.4k Views 2 Watching
  • BMcG BMcG
    Hi @Richard-18 thats sounds like quite a bit of work you have been doing copying & renaming
    @Richard-18 said in Synchronisation - A batch of routes?:
    I do not want to synchronise my entire library, as I’d much rather leave the library of ‘original’ routes intact and unaltered.
    My question is what do you think is going to change with your library?
    All the sync does is make the same file available on both the web site & in the mobile app
    As far as I understand there will be no change to the original file / route
    I believe the whole purpose of sync was to help stop all the copying / downloading of files / routes
    Richard 18
    Richard 18
    Richard 18
    wrote on last edited by Richard 18
    @Brian-McG said in Synchronisation - A batch of routes?:
    Not so, I’m afraid. At least as far as I can tell in my experiments, practicing to see how it all works.
    If an ‘original’ route, for instance one that I hold in my library, is synchronised with and then amended in the app (say for example by shortening or extending theroute) the changes will be synchronised back to the original.
    That is, I guess, one of the purposes behind synchronisation: That changes made elsewhere will be synchronised and made binding elsewhere.
    See example below, please.
    • Richard 18
      Richard 18
      Richard 18
      Original route in Routeplanner:
      The same original route, synchronised in the app:
      The two match, as one would expect.
      I then amended the synchronised version in the app, by extending it and mucked about with the waypoints:
      The changes were synchronised back to the original:
      Marinus van Deudekom BMcG 2 Replies Last reply
      • Richard 18 Richard 18
        @Richard-18 If you change something in a route and then want to check if that is being synced. Go online with that device and you will see that it will be synced.
        • Richard 18
          Richard 18
          Richard 18
          Marinus, thank you for your post.
          By way of reply:
          I know that if a synchronised route is altered, the changes will be synchronised through the chain, as shown in the post with the pictures above.
          I like the synchronisation tool.
          I like that I can synchronise individual routes, as opposed to synchronising the entire library. That is a very good option to have.
          I like that I can create a copy of a ‘original’ route snd synchronise the copy, leaving the ‘original’ untouched and unsynchronised.
          I like that any changes I make to the copy version of the ‘original’ route, will be synchronised with and replicated along the chain, whilst the ‘original’ still remains unaffected and unaltered.
          All of this I am happy with.
          What I really would like to know is if there is any way to select a number of routes (as opposed to just a single route or all of the library) and whether it is then possible synchronise that batch of routes all at once, rather than synchronising each route individually?
          If there is a way to do it, I would like to hear it, please.
          If there is no way to do it, I’d like to know if it could be offered as an option in the future, please?
          Thanks,
          Richard.
            BMcG
            BMcG
            BMcG
            Hi @Richard-18 I appreciate you would like to be able to select & sync a batch or folder of routes & there may be a use case for this although I cannot think of any
            It is a valid & decent suggestion to make
            but I am sorry I find your explantion for the altering of the original route as frankly a little bit daft. If you change a route of course it is altered, it is the same file.
            It is like saying I created a route, closed it, opened, amended it, & now for some reason its changed!
            If you dont want to change a route & keep that as an original, you make a copy & edit the copy
            Then in both cases the routes, the original & copy can are syncronised & available to you both in the web planner & on the mobile app
              By way of reply:
              Thanks,
              Richard.
              @Richard-18 If you could explain why you do not want to synchronise all of your routes, it would help us and the developers understand your request to be able to select a batch (individual folders) for synchronisation.
              • Richard 18
                Richard 18
                Richard 18
                Brian, I fully understand how the synchronisation works, its purpose and the why’s and wherefore’s of it all. No dispute or hard feelings there, I promise.
                Nick, I have a huge library of well over a thousand routes, which I have used and / or have gleaned up from elsewhere, simply to use perhaps at sometime or because I have shared them on another forum, to give people some possible ideas. In short, I have no need to synchronise the lot.
                What though is important to me, is that I leave the library of individual routes unaltered. That might well be just me, but (like the P in personal computer) what makes sense to one person, might not always make sense to another.
                I am perfectly happy with being able to synchronise individual routes, one at time, which I do by making a copy and then synchronising the copy. These I put into a separate sub-folder, safe in the knowledge that the ‘original’ route from which the copy was made, will remain untouched. I guess it’s just the P thing in action again? It works for me, that’s all.
                If though there is a way to select say, 10 routes and synchronise them en block (rather than individually) that would be even better. If there isn’t and there never will be, so be it; I’m still quite happy.
                Cheers,
                Richard
                Richard 18 MotoCon 2 Replies Last reply
                  Cheers,
                  Richard
                  Richard 18
                  Richard 18
                  Richard 18
                  Nick, I have a huge library of well over a thousand routes, which I have used and / or have gleaned up from elsewhere, simply to use perhaps at sometime or because I have shared them on another forum, to give people some possible ideas. Look at it rather like the library of Route experts’ routes here. In short, I have no need to synchronise the lot.
                  If though there is a way to select say, 10 routes or, for example, a sub-folder of the 10 and synchronise them en block (rather than individually) that would be even better. If there isn’t and there never will be, so be it; I’m still quite happy.
                  Cheers,
                  Richard
                    Cheers,
                    Richard
                    Although I would really appreciate folders being selectable for sync, as a go-in-between to just single routes or all routes, I think you should consider that my 300+ routes were synced completely in less then 50MB. So I am inclined to say that synced routes will not be in your way memory-wise. The idea of a complete sync is that, since there also is an in-app planner module, you can do whatever you can do online, also offline in your app.
                    This method kind of defies the purpose of syncing. If you want to change a route without overwriting the existing one, you make a copy in your online library as well. Why not use the same method in the app?
                    But again, I think the idea of enabling syncing folder-wise would be a good idea too, although not completely by your argumentation 😉
                    Richard 18 1 Reply Last reply
                      Richard 18
                      Richard 18
                      Richard 18
                      Many thanks you for your thoughtful reply.
                      Whilst we might not agree on the method I use and / or whether or not to synchronise an entire library, in other words: “What works for me, doesn’t work for you”, I can see that we agree on:
                      A. It’s good to have the ability to synchronise an entire library, for those who want to do it
                      B. It’s good to have the ability to synchronise single routes individually
                      C. It would be good to synchronise several routes, held in a folder, all at one. Rather than having to do them individually
                      Hopefully item C will become available in an update? If not, I’ll stick with my method.
                      Best wishes,
                      Richard
                        Best wishes,
                        Richard
                        @Richard-18, yes we agree on that! 😉
                        BMcG
                        BMcG
                        Richard 18
                        Richard 18
                        • Bollard trouble
                        • Testroute segmenten
                          Alderweireld Rudi 0
                          Alderweireld Rudi 0
                        • Minimap
                          LE DIZES Freddy
                          LE DIZES Freddy
                          Erdna
                          Erdna
                        • Map movement
