  4. How to save a route made by Navigation app?
5 Posts 4 Posters 1.0k Views 4 Watching
  • Jan m Offline
    Jan m Offline
    Jan m
    Big, big fan of the (curvy) route creation by the Navigation app. Set destination and 3 seconds later a great route pops up, ready to go. Spent 3 days in France last weekend and had a blast riding because of these routes.
    Wanted to save the route before we started riding so could share the gpx file with fellow riders (some use MRA, some Garmin, ...) but didnt find any way to save the route which the Navigation app created so I could share it with them.
    Is there a way to save the route that was calculated by the Navigation app?
    picture as an example: how to save this exact route from the screen shown?
    Corjan Meijerink Nick Carthew Brian McG 3 Replies Last reply
    • Jan m Jan m
      Corjan Meijerink Offline
      @Jan-m That unfortunately is not possible yet!
      Jan m 1 Reply Last reply
      • Jan m Jan m
        Nick Carthew Offline
        @Jan-m You could record the route as a tracklog while you are riding it and then save the tracklog and convert it to a route. You then have the route to use again. Not helpful for your situation but at least you’ll have a record of the route.
        • Jan m Jan m
          Brian McG Offline
          Brian McG Offline
          Hi @Jan-m as Corjan says what you are after is currently not possible but
          I just read this thread which might be a way for you to get something close
          https://forum.myrouteapp.com/topic/7495/probleme-mit-mra-beim-start-während-routen-unerträglich
          It uses the Openstreetmap curve routing algorithm so won't be exactly the same as the Here map
          You have to do a little bit of work to expand/add/save the additional points but you would end up fairly quickly with a curvy route that could be shared
            Jan m Offline
            Jan m Offline
            Jan m
            wrote on last edited by Jan m
            @Corjan-Meijerink thanks guys, good to know. Hopes set on the "yet" 🙂
            Jan m
            Jan m
            • Welke instelling
              Pim van Dongen
              Pim van Dongen
            • Steeds maar weer centreren
              Pim van Dongen
              Pim van Dongen
            • Ability to change units as your navigating
              Kev Parry
              Kev Parry
              520
            • Automatic setting for units
            • scherm bevrirzing
