  4. Android Auto next instruction box not loading
11 Posts 4 Posters 1.9k Views 2 Watching
  • Laurence Nicholls Offline
    Laurence Nicholls
    Hi,
    I am connection a Samsung A23 to a new Interphone RideSync Android Auto
    All working correctly on the phone but the Android version fails to load the next direction box, just a spinning arrow as if trying to load.
    Any thoughts
    Laurence
    Con Hennekens Laurence Nicholls 2 Replies Last reply
    • Laurence Nicholls Laurence Nicholls
      Hi,
      Any thoughts
      Laurence
      @Laurence-Nicholls A picture tells a 1000 words... πŸ˜‰
        Laurence Nicholls
        7edf49a4-11ca-45c2-a177-990454500221-image.jpeg blob:null/7c9a6302-7161-4ba7-b1ad-08db0
          Hi,
          Any thoughts
          Laurence
          Laurence Nicholls
          @Laurence-Nicholls thanks for the quick replay, images now sent πŸ˜€
            @Laurence-Nicholls, strange... Does it do this consequently? Or does it happen only sometimes? I am sure the forum would be full of it, if it happened to more people. Maybe best to open a support ticket: https://www.myrouteapp.com/support
            • M. Schrijver Offline
              I recognized this from Android Auto.
              I see this also until the first turn with directions is passed. From there it works ok.
                Laurence Nicholls
                Hi Con, M makes a good point as I have only set up in the garage….due to poor weather!
                I will go for a ride tomorrow and fingers crossed it will work once on the way 🀞
                PS I tried it on an old iPhone in apple car play and it works straight away.
                Thanks for your comments
                Will report back on results
                Bouke Ent Con Hennekens 2 Replies Last reply
                  Bouke Ent Offline
                  Bouke Ent Offline
                  @Laurence-Nicholls i can not help because i did test it yesterday on my setup and it works for me. both next 2 direction i got directly on Android auto. in my case it was a2b route and totaly offline.
                    @Laurence-Nicholls, if your garage is off the road enough for the app to determine where to start, that could well explain the issue.
                      That doesn't seems to be the issue. At least not in my case.
                      When i start the route on the road. The GPS is known in this case but still this issue. It does not matter how long it takes to reach the first turn with directions.
                      I've seen it for just 500 meters but also for a few kilometers.
                      When i start the route halfway, is does not happen. That is what i remember.
                        Laurence Nicholls
                        Hi All
                        Went out for a long ride yesterday, the inductions did appear but it took quite a while approx 10 miles, then worked faultlessly for the rest of the trip, even coming straight back on after being switched of for coffee break.
                        Laurence Nicholls
                        Laurence Nicholls
                          Steve Jarrell
                          Steve Jarrell
                          10.2k
                        • Audio cuttet via Bluetooth
                          22.2k
                        • Lost all route points after repeatedly hitting Ctrl+Z (Undo)
                          398
                          1.1k
                          Hans van de Ven MR.MRA
                        • Startpagina Route Lab
