  4. Show elevation
Show elevation
14 Posts 9 Posters 4.3k Views 4 Watching
  • Graziano 0 Graziano 0
    I have been using the planner for quite some time in combination with a Garmin navigator, now I am starting to use the app. One thing I miss compared to the navigator is having the elevation on the screen. Agreed, it's not essential and probably not an issue in the Netherlands 😉 , but I miss not seeing the elevation as I ride from pass to pass in the Alps. Thanks for your attention!
    @Graziano-0, I( would welcome that to. The Garmin way of choosing your own data fields is quite clever.
      @Graziano-0 if it is part of a selectable menu, it sounds intriguing...if not, in my opinion (I'm sure everyone has a view 😊 ) the screen is busy enough. I'd prefer lareger roadway/POI icons - at least a size that is recognizable from the current very small, mostly indiscernable ones.
      • Jörgen
        @Graziano-0 May be this helps until it is implemented.
        https://forum.myrouteapp.com/post/33669
        Graziano 0 1 Reply Last reply
        • Jörgen Jörgen
          Graziano 0
          Graziano 0
          Graziano 0
          @Jörgen Thank you, but it seems I have no access to that link
            @Graziano-0 @Jörgen was referencing a post from the closed BETA forum, this is why you don’t have access from the link. Jörgen has found an app that works for Android phones and it will add an altimeter to your maps, including MRA. You can find it in the PlayStore and it’s called: Maps Altimeter
            Graziano 0 Jörgen 2 Replies Last reply
              Graziano 0
              Graziano 0
              Graziano 0
              @Nick-Carthew Thanks! I did not know that app, it looks to be very nice, to be seen how it works while riding (ie elevation continuosly changing), but if it works it's a very good option.
                @Nick-Carthew Thank you Nick.
                Yes this App will help until there is something in MRA.
                I made it look like it is in MRA, the setup makes it possible.
                • Ramon Cutanda Lopez
                  Ramon Cutanda Lopez
                  Ramon Cutanda Lopez
                  I too miss this option. Temperature changes linked to elevation variations are usually significant, and I like to have that information at hand. When riding mountain roads, changes in elevation are pretty obvious, but quite often it's hard to tell when riding through plateaus. I am using MyrouteApp + Carplay, so Jörgen's suggestion is not an option for me and I would appreciate the team to have this suggestion into consideration.
                  Thanks,
                    Ramon Cutanda Lopez
                    Ramon Cutanda Lopez
                    wrote on last edited by Ramon Cutanda Lopez
                    @Peter-Schiefer Thank you for your insight.
                    Personally, I see plenty of room to implement the requested feature either on the right side or at the bottom:
                    alt text
                    But even if it is not possible to add a new info widget for whichever the reasons, I would personally trade one of the current info widgets. For instance, showing the Estimated Time of Arrival AND the remaining time, at the same time, is redundant in my opinion. I would gladly swap one of those for the elevation (or any other at the choice of the user).
                    I too used a Garmin sat navigation device for years and I loved being able to choose which info blocks to have available. And elevation was definitely always on for me. I really cannot see why MyRoute-app cannot, or should not, offer the user the possibility to choose among the options most useful for each user.
                    I understand that this may not be a very popular request. But, being a "suggestion forum", I believe I am entitled to make mine. If fact, I am just supporting another user's request.
                    Thank you for your time.
                    Regards,
                    GT JWR Corjan Meijerink 2 Replies Last reply
                    • Ramon Cutanda Lopez Ramon Cutanda Lopez
                      alt text
                      Regards,
                      @Ramon-Cutanda-Lopez having a menu of options to choose from would be ideal.
                        alt text
                        Regards,
                        @Ramon-Cutanda-Lopez That is the old app 😉
                        Not that the new app supports the elevation to be displayed but you should stop using that app 🙂
                        Ramon Cutanda Lopez 1 Reply Last reply
                          Ramon Cutanda Lopez
                          Ramon Cutanda Lopez
                          Ramon Cutanda Lopez
                          Thank you Peter and Corjan. When I wrote this post I was away from my device and, just for illustration purposes, the screen capture I used was actually one taken from the YouTube channel: https://www.youtube.com/watch?v=QMCG76K3F0g
                          I had once access to the betas, but lost it at some point. I was not using the Navigation app because its lack of loading routes directly from Carplay. I am currently using 4.2.0, but now that MRA is finally my main navigation app I will ask access to the beta again to test any new features.
                          Regards,
                          alt text
                          alt text
                          alt text
                          • David Emmett
                            David Emmett
                            David Emmett
                            Just like to chip and agree that I would also like to be able to see elevation while riding. I am using the app directly, not via CarPlay. I'll give the app mentioned above a go, but I'd love to have it in the MRA app as well.
                            Graziano 0
                            Graziano 0
                            David Emmett
                            David Emmett
                            Ramon Cutanda Lopez
                            Ramon Cutanda Lopez
                            • Bollard trouble
                            • Testroute segmenten
                              Alderweireld Rudi 0
                              Alderweireld Rudi 0
                            • Minimap
                              LE DIZES Freddy
                              LE DIZES Freddy
                              Erdna
                              Erdna
                            • Map movement
