  4. Volume too low
Volume too low
41 Posts 14 Posters 24.6k Views 7 Watching
    The old app was indeed better.
    TomTom Go is better
    Waze is better.
    They all use(d) their own voice engine.
    MRA could change this for the current app but i doubt if they would. I think (but totally not sure) they won't because a separate engine like the old app had, will not work with some functions of the current app. Like reading text which you can type in the info box.
    Maybe @Corjan-Meijerink could clarify this.
    @M-Schrijver
    The new app is much better then the old app and all the others, only the volume on some phones is low. But I’m sure it will be fixed
    • Nick Carthew
      To add my experience to this debate:
      I use an iPhone 11 with iOS 17.4.1
      I have downloaded the Serena (Premium) system voice from Settings > Accessibility > Spoken Content > Voices > English.
      And I use a Cardo Scala PackTalk Bold with the latest firmware as my headset with the correct priority setting for audio source.
      If I am riding on my own with no one connected to the intercom I hear navigation instructions loud and clear, not at top volume of the Cardo.
      As soon as I am connected to another riders intercom the navigation instruction are barely audible, I hear the first part of the first word of the instruction and then the voice fades away.
      I experience exactly the same behaviour when I am connected to my TomTom Rider 500 or Google maps on my phone.
      So for me, I don't see a problem with the phone voice or with MRA Navigation Next.
      The problem is caused by the Cardo headset.
        @Nick-Carthew
        No problems with the intercom, and the Sena SRL 2 connected to my phone and the XT2 or XT.
        Only the instructions of Next are to low, and that was much better before.
          @Nick-Carthew
          @Hans-van-de-Ven-MR-MRA
          Yes, that may be the case with your setup, I was pointing out that not all issues with the volume are related to MRA Navigation Next. The volume for turn by turn instructions a notes is very loud when I don’t have an intercom connection.
          My devices and settings are different to yours and so we have a different experience. As far as I am concerned, the app volume is fine except when I am connected to another intercom. The same happens with my TomTom or Google Maps, turn by turn instructions cannot be heard when the intercom is connected but perfectly clear when not.
          You don’t have to be Sherlock 🕵️ Holmes to work out that in my case the Cardo is at fault.
          Rob Verhoeff HABVEN aka MrMRA 2 Replies Last reply
            @Nick-Carthew said in Volume too low:
            Does your Cardo also use a meshnetwork connection, or do you connect to another Cardo user via Bluetooth?
              @Rob-Verhoeff Yes, it connects with mesh or Bluetooth and I’ve tried both. Both show the same behaviour.
                You can adjust this to some extend in the Cardo app (background volume).
                  @M-Schrijver Yes, thank you I have the app.
                    @Nick-Carthew
                    I don’t think Sena is the problem, I tried another app and that works fine, volume is loud and clear also connected to the XT2 and XT.
                      Then the "problem-solver" has a nice challenge... 😉
                      Patrick S0 1 Reply Last reply
                        Patrick S0
                        Patrick S0
                        Patrick S0
                        Regarding the volume issue, it remains quiet from the developers' side...
                        By the way, I use MRA and Android Auto in my car, I don't have a motorcycle and therefore don't have all those interfaces
                        • Patrick S0 Patrick S0
                          @Patrick-S0 said in Volume too low:
                          Holiday trip... back soon!
                          • Murat Güven
                            Murat Güven
                            Murat Güven
                            wrote on last edited by Murat Güven
                            #27
                            My (working) setup:
                            I use an Android phone (Nothing phone 2a) which is quite close to bare Android, I think.
                            With this, I can increase the volume above normal limits (for which I get a warning from the phone). With this volume level, I'm able to hear MRA and Spotify in a good level, although I'm using Earplugs.
                            The audio system is Cardo Packtalk Edge.
                            The iPhone / iOS does not allow this extended increase of the volume I think. Also separate adjustment of volumes per function is not possible on iOS.
                            Regards,
                            Murat
                            • marc van der heijden
                              idd het geluid is bijna niet verstaanbaar, het is ook geen probleem wat nog maar kort bestaat, vooralsnog lijkt het niet opgelost te worden.
                              Aan de ontwikkelaars dus de vraag: Wanneer is het eens opgelost?
                              Als ik met Google Maps navigeer heb ik voldoende geluid bij de gesproken instructies, dus het ligt niet aan de telefoon of headset, heb al vanalles geprobeerd, maar de mra navigatie blijft de instructies fluisteren
                                @marc-van-der-heijden, als ik met GMaps navigeer doet zich exact hetzelfde probleem voor met het stem volume.
                                marc van der heijden 1 Reply Last reply
                                  @Con-Hennekens said in Volume too low:
                                  Bij mij dus niet, heb het deze week nog geprobeerd nadat ik een route aan het rijden was met mra in de auto en onderweg ( ja ik weet het dat kan ook met mra ) met Google Maps een restaurant zocht en met google er naar toe navigeerde, het geluid was toen duidelijk verstaanbaar en later toen ik weer met mra navigeerde was het op fluisterniveau
                                  Bouke Ent 1 Reply Last reply
                                    afgelopen 2 weken MRA Next gebruikt op ulefone armor x10 pro en mijn backup samsung a40. ik gebruik geen headset of andere zaken, gewoon volume van de telefoon. op ulefone prima en op samsung te laag. mijn conclusie is dan het ligt aan hardware en niet aan MRA Next app.
                                      MRA Next is gebaseerd op het HereWeGo platform. Het HereWeGo platform leunt op de als standaard ingestelde TTS engine van je smartphone voor de aanwijzingen. Het heeft geen eigen stemmen.
                                      Iedere Android telefoon heeft de Google TTS engine aan boord. Met deze Engine zal MRA Next (en HereWeGo) op iedere telefoon hetzelfde klinken met hetzelfde volume.
                                      Veel Android telefoon hebben een eigen skin, zoals OneUI bij Samsung. Met deze skin kan er ook een aparte TTS engine meekomen wel dan als default ingesteld wordt. Dit zorgt ervoor dat er zoveel verschil tussen de verschillende telefoons zit.
                                      Kortom het is NIET MRA die dit verschil veroorzaakt maar je eigen telefoon.
                                        @M-Schrijver
                                        Dat denk ik niet, altijd duidelijke aanwijzingen gehad uit Next en de XT en XT2, nu hoor ik Next nog nauwelijks, de XT2 komt luid en duidelijk door.
                                        Zelfs met het volume vol open hoor ik Next nauwelijks.
                                        Nog steeds dezelfde iPhone.
                                        • Leike Lodiers
                                          wrote on last edited by Leike Lodiers
                                          #34
                                          Dit weekend nog 250km gereden op motor info was luid en duidelijk. ik gebruik een carpe iter tablet en mijn telefoon met een cardo edge samen. De gegeven route instructies zijn luid en duidelijk te verstaan en ik moet de cardo zelf minder volume laten geven. ik gebruik google tts en dan even een stem zoeken die hard genog is voor jouw.
                                          Niels Elferink
                                          Niels Elferink
                                          Thomas Keßler
                                          Thomas Keßler
                                          Paul Smith b
                                          Paul Smith b
                                          Tom Cat
                                          Tom Cat
                                          Murat Güven
                                          Murat Güven
                                          Patrick S0
                                          Patrick S0
                                            Rene van Maanen
                                            Rene van Maanen
                                          • _Tracklogs folder nearly empty?
                                          • One crash today
                                          • Tracklogs access at friends and clubs
                                          • 6.0 UI in landscape needs pollishing
                                            Mosimann
                                            Mosimann
                                          • Foutmelding bij aanmelden beta planner: klassieke account is al gebruikt voor de loyaliteitsprijs op een ander account
