  4. How to import from Google maps?
20 Posts 7 Posters 8.7k Views 3 Watching
  • Jörgen Jörgen
    @Rob-Verhoeff
    I found a converter, but he refuse to take my link.
    https://mapstogpx.com/
    @Jörgen Same here... not so good converter I guess?
    • Jörgen Jörgen
      Morning,
      I got a link to a Google Maps route, how can I get this into MRA?
      https://maps.app.goo.gl/iSxPZTLCrrvMvibW6
      Rob Veerman
      Rob Veerman
      Rob Veerman
      @Jörgen kml2gpx should do the trick
      Jörgen 1 Reply Last reply
      • Mzokk
        @Peter-Schiefer It's not aparticularly complicated map. I'd use the google waypoints and recreate the route in MRA. Keep google maps and MRA open beside eash other.
        Probably the fastest way.
        • Jörgen Jörgen
          Morning,
          Rob Veerman
          Rob Veerman
          Rob Veerman
          @Jörgen just use kml2gpx.com
          Wirklich ganz einfach!
          Mzokk 1 Reply Last reply
          • Rob Veerman Rob Veerman
            @Rob-Veerman Google maps does not create an exportable KML file. Google (my maps) does but these can be imported into myroute (or basecamp for that matter) app as KML in any case no need for convertion at all.
            • Rob Veerman
              Rob Veerman
              Rob Veerman
              Once the route is set in Google Maps, tap the hamburger menu.
              Click Share, the journey link appears.
              Tap Copy Link, go to the site MapstoGPX,
              paste the URL and click LetsGo.
              Does that do the trick?
                @Rob-Veerman don't think that site is operational at the moment
                FATAL ERROR
                Not valid Goodgle maps directions data
                Please go back and check your Maps link and retry, if this error persists then please check again in a few hours
                Is the current message
                  @Rob-Veerman said in How to import from Google maps?:
                  I don’t have a kml file, just the link.
                    The route needs to be created in Google MyMaps.
                    There you can export it into a KML/KMZ file. This files can be imported in MRA
                    • Jörgen
                      Thanks to Rhönschrat, for the solution.
                      With the App Scenic you can import the route from only the link.
                      If it is imported in Scenic, you can export a GPX file. DONE!
                      GT JWR 1 Reply Last reply
                      • Jörgen Jörgen
                        @Jörgen is that the full name of the App? I'm seeing 'Scenic Map' and 'Scenic Motorcylce Navigation', amongst others...I believe the correct one to be Scenic Map, just want to confirm.
                        Thanks,
                        • GT JWR GT JWR
                          Thanks,
                          @GT-JWR
                          Scenic Motorcycle Navigation
                          https://scenic.app/
                          • GT JWR
                            @Peter-Schiefer @Jörgen thanks guys.
                            • Jörgen Jörgen
                              @GT-JWR
                              https://scenic.app/
                              @Jörgen downloaded the app, it appears that premium version is reqired to convert google maps to *.gpx...is that your finding as well?
                              • Jörgen
                                @GT-JWR Sorry, yes could be possible, I have that and not noticed.
                                If you need something to convert, send me the link.
                                • Jörgen Jörgen
                                  @Jörgen thanks - at the moment, I was just investigating it and how to do it....a small group of buddies and I are going on a 10 day, 4000mi (ish) bike trip this summer (from Texas to the Grand Canyon and back), and the group leader has planned a lot on google maps and I was hoping to convert them to *.gpx for MRA. Here's a couple of links to convert, if you don't mind.
                                  Appreciate it!
                                  https://www.google.com/maps/dir/2939+Carrizo+Springs+Ct,+Katy,+TX+77449,+USA/1113+W+Birch+Ave,+Lovington,+NM+88260/@31.4003842,-104.8313997,6z/data=!3m1!4b1!4m16!4m15!1m5!1m1!1s0x8640d878d5fb9ab1:0x99c3a4b06a85d364!2m2!1d-95.72737!2d29.810078!1m5!1m1!1s0x86fcd09ee395f8cf:0x166b3e4750dfaa35!2m2!1d-103.362587!2d32.9598106!2m1!1b1!3e0?entry=ttu
                                  https://www.google.com/maps/dir/11824+US-180,+Silver+City,+NM+88022/102+Hermosa+Dr,+Holbrook,+AZ+86025/@33.5659257,-109.9146107,8.84z/data=!4m41!4m40!1m30!1m1!1s0x86d8c84acf4f592d:0x661784136867608f!2m2!1d-108.1909831!2d32.7782169!3m4!1m2!1d-109.37066!2d33.0744807!3s0x8727f0a2a482324b:0xd5afe486e4f739aa!3m4!1m2!1d-109.4121148!2d33.9247499!3s0x8726236f969f013f:0xbad6470a8cfb0c44!3m4!1m2!1d-109.3502442!2d34.0427754!3s0x872617a3f32a9689:0xab8f03c36d831c78!3m4!1m2!1d-109.7537682!2d34.0536204!3s0x8728a4ce9252014f:0xc0acbc986d328c20!3m4!1m2!1d-110.0295789!2d34.286615!3s0x872f3463fa7e3369:0x108535f4c15073c9!1m5!1m1!1s0x872fa8765fe1a7e9:0x5f6eee0e695971f!2m2!1d-110.143156!2d34.9227635!2m1!1b1!3e0?entry=ttu&fbclid=IwZXh0bgNhZW0CMTAAAR3_yzuKPex6hPLY7WwCT_rezn2z_XlB5nlTuKWZqOAnNsdMtN96TxN7Vhc_aem_Ac30wCGnQL7hKC5f7hcTTx7JT5V-rbtGsJoFV-oZ5ltqkmoxszJekpqIlEyVLe_wkVpjPuHzfQ8aihq1yDDw9D8R
                                  • GT JWR GT JWR
                                    Appreciate it!
                                    @GT-JWR here you are.
                                    Oh, I can not add a gpx file or zip file here. I need you mail address, please send it via PN.
                                    Rob Veerman
                                    Rob Veerman
                                    • MRA Studio export speed
                                    • Map colours and side roads
                                    • Control screen font size
                                    • MyRoute-app offline
                                      BlauweFJR
                                      BlauweFJR
                                      55.3k
                                    • route bug
