  4. How to import from Google maps?
20 Posts 7 Posters 7.5k Views 3 Watching
  • Jörgen Offline
    Jörgen Offline
    Morning,
    I got a link to a Google Maps route, how can I get this into MRA?
    https://maps.app.goo.gl/iSxPZTLCrrvMvibW6
    Rob Verhoeff Rob Veerman 3 Replies Last reply
    • Jörgen Jörgen
      Morning,
      Rob Verhoeff Offline
      @Jörgen I haven't found a way in Google yet to convert it into a .gpx file and import it. But that might also be because I don't know how to do it!
      Jörgen 1 Reply Last reply
        Jörgen Offline
        Jörgen Offline
        @Rob-Verhoeff
        I found a converter, but he refuse to take my link.
        https://mapstogpx.com/
        • Jörgen Jörgen
          @Rob-Verhoeff
          @Jörgen Same here... not so good converter I guess?
          • Jörgen Jörgen
            Morning,
            Rob Veerman Offline
            Rob Veerman Offline
            Rob Veerman
            @Jörgen kml2gpx should do the trick
            • Mzokk Offline
              Mzokk Offline
              @Peter-Schiefer It's not aparticularly complicated map. I'd use the google waypoints and recreate the route in MRA. Keep google maps and MRA open beside eash other.
              Probably the fastest way.
              • Jörgen Jörgen
                Morning,
                Rob Veerman Offline
                Rob Veerman Offline
                Rob Veerman
                @Jörgen just use kml2gpx.com
                Wirklich ganz einfach!
                Mzokk 1 Reply Last reply
                • Rob Veerman Rob Veerman
                  Mzokk Offline
                  Mzokk Offline
                  @Rob-Veerman Google maps does not create an exportable KML file. Google (my maps) does but these can be imported into myroute (or basecamp for that matter) app as KML in any case no need for convertion at all.
                  • Rob Veerman Offline
                    Rob Veerman Offline
                    Rob Veerman
                    Once the route is set in Google Maps, tap the hamburger menu.
                    Click Share, the journey link appears.
                    Tap Copy Link, go to the site MapstoGPX,
                    paste the URL and click LetsGo.
                    Does that do the trick?
                      Mzokk Offline
                      Mzokk Offline
                      @Rob-Veerman don't think that site is operational at the moment
                      FATAL ERROR
                      Not valid Goodgle maps directions data
                      Please go back and check your Maps link and retry, if this error persists then please check again in a few hours
                      Is the current message
                        Jörgen Offline
                        Jörgen Offline
                        @Rob-Veerman said in How to import from Google maps?:
                        I don’t have a kml file, just the link.
                        • M. Schrijver Online
                          M. Schrijver Online
                          The route needs to be created in Google MyMaps.
                          There you can export it into a KML/KMZ file. This files can be imported in MRA
                          • Jörgen Offline
                            Jörgen Offline
                            Thanks to Rhönschrat, for the solution.
                            With the App Scenic you can import the route from only the link.
                            If it is imported in Scenic, you can export a GPX file. DONE!
                            GT JWR 1 Reply Last reply
                            • Jörgen Jörgen
                              GT JWR Offline
                              GT JWR Offline
                              @Jörgen is that the full name of the App? I'm seeing 'Scenic Map' and 'Scenic Motorcylce Navigation', amongst others...I believe the correct one to be Scenic Map, just want to confirm.
                              Thanks,
                              • GT JWR GT JWR
                                Thanks,
                                Jörgen Offline
                                Jörgen Offline
                                @GT-JWR
                                Scenic Motorcycle Navigation
                                https://scenic.app/
                                • GT JWR Offline
                                  GT JWR Offline
                                  @Peter-Schiefer @Jörgen thanks guys.
                                  • Jörgen Jörgen
                                    @GT-JWR
                                    https://scenic.app/
                                    GT JWR Offline
                                    GT JWR Offline
                                    @Jörgen downloaded the app, it appears that premium version is reqired to convert google maps to *.gpx...is that your finding as well?
                                    • Jörgen Offline
                                      Jörgen Offline
                                      @GT-JWR Sorry, yes could be possible, I have that and not noticed.
                                      If you need something to convert, send me the link.
                                      • Jörgen Jörgen
                                        GT JWR Offline
                                        GT JWR Offline
                                        @Jörgen thanks - at the moment, I was just investigating it and how to do it....a small group of buddies and I are going on a 10 day, 4000mi (ish) bike trip this summer (from Texas to the Grand Canyon and back), and the group leader has planned a lot on google maps and I was hoping to convert them to *.gpx for MRA. Here's a couple of links to convert, if you don't mind.
                                        Appreciate it!
                                        https://www.google.com/maps/dir/2939+Carrizo+Springs+Ct,+Katy,+TX+77449,+USA/1113+W+Birch+Ave,+Lovington,+NM+88260/@31.4003842,-104.8313997,6z/data=!3m1!4b1!4m16!4m15!1m5!1m1!1s0x8640d878d5fb9ab1:0x99c3a4b06a85d364!2m2!1d-95.72737!2d29.810078!1m5!1m1!1s0x86fcd09ee395f8cf:0x166b3e4750dfaa35!2m2!1d-103.362587!2d32.9598106!2m1!1b1!3e0?entry=ttu
                                        https://www.google.com/maps/dir/11824+US-180,+Silver+City,+NM+88022/102+Hermosa+Dr,+Holbrook,+AZ+86025/@33.5659257,-109.9146107,8.84z/data=!4m41!4m40!1m30!1m1!1s0x86d8c84acf4f592d:0x661784136867608f!2m2!1d-108.1909831!2d32.7782169!3m4!1m2!1d-109.37066!2d33.0744807!3s0x8727f0a2a482324b:0xd5afe486e4f739aa!3m4!1m2!1d-109.4121148!2d33.9247499!3s0x8726236f969f013f:0xbad6470a8cfb0c44!3m4!1m2!1d-109.3502442!2d34.0427754!3s0x872617a3f32a9689:0xab8f03c36d831c78!3m4!1m2!1d-109.7537682!2d34.0536204!3s0x8728a4ce9252014f:0xc0acbc986d328c20!3m4!1m2!1d-110.0295789!2d34.286615!3s0x872f3463fa7e3369:0x108535f4c15073c9!1m5!1m1!1s0x872fa8765fe1a7e9:0x5f6eee0e695971f!2m2!1d-110.143156!2d34.9227635!2m1!1b1!3e0?entry=ttu&fbclid=IwZXh0bgNhZW0CMTAAAR3_yzuKPex6hPLY7WwCT_rezn2z_XlB5nlTuKWZqOAnNsdMtN96TxN7Vhc_aem_Ac30wCGnQL7hKC5f7hcTTx7JT5V-rbtGsJoFV-oZ5ltqkmoxszJekpqIlEyVLe_wkVpjPuHzfQ8aihq1yDDw9D8R
                                        • GT JWR GT JWR
                                          Appreciate it!
                                          Jörgen Offline
                                          Jörgen Offline
                                          @GT-JWR here you are.
                                          Oh, I can not add a gpx file or zip file here. I need you mail address, please send it via PN.
                                          Rob Veerman
                                          Rob Veerman
                                          • HERE maps updates
                                            12.2k
                                            Alfred Schrittwieser
                                            1.4k
                                            Bruno 7
                                            Bruno 7
