  4. How to import from Google maps?
20 Posts 7 Posters 6.4k Views 3 Watching
  • Jörgenundefined Offline
    Morning,
    I got a link to a Google Maps route, how can I get this into MRA?
    https://maps.app.goo.gl/iSxPZTLCrrvMvibW6
    Rob Verhoeffundefined Rob Veermanundefined 3 Replies Last reply
    • Jörgenundefined Jörgen
      Morning,
      Rob Verhoeffundefined Online
      @Jörgen I haven't found a way in Google yet to convert it into a .gpx file and import it. But that might also be because I don't know how to do it!
        @Rob-Verhoeff
        I found a converter, but he refuse to take my link.
        https://mapstogpx.com/
          @Rob-Verhoeff
          @Jörgen Same here... not so good converter I guess?
            Morning,
            Rob Veermanundefined Offline
            Rob Veerman
            @Jörgen kml2gpx should do the trick
            • Mzokkundefined Offline
              @Peter-Schiefer It's not aparticularly complicated map. I'd use the google waypoints and recreate the route in MRA. Keep google maps and MRA open beside eash other.
              Probably the fastest way.
                Morning,
                Rob Veerman
                @Jörgen just use kml2gpx.com
                Wirklich ganz einfach!
                • Rob Veermanundefined Rob Veerman
                  @Rob-Veerman Google maps does not create an exportable KML file. Google (my maps) does but these can be imported into myroute (or basecamp for that matter) app as KML in any case no need for convertion at all.
                  • Rob Veermanundefined Offline
                    Rob Veerman
                    Once the route is set in Google Maps, tap the hamburger menu.
                    Click Share, the journey link appears.
                    Tap Copy Link, go to the site MapstoGPX,
                    paste the URL and click LetsGo.
                    Does that do the trick?
                      @Rob-Veerman don't think that site is operational at the moment
                      FATAL ERROR
                      Not valid Goodgle maps directions data
                      Please go back and check your Maps link and retry, if this error persists then please check again in a few hours
                      Is the current message
                        @Rob-Veerman said in How to import from Google maps?:
                        I don’t have a kml file, just the link.
                          The route needs to be created in Google MyMaps.
                          There you can export it into a KML/KMZ file. This files can be imported in MRA
                            Thanks to Rhönschrat, for the solution.
                            With the App Scenic you can import the route from only the link.
                            If it is imported in Scenic, you can export a GPX file. DONE!
                              GT JWRundefined Offline
                              @Jörgen is that the full name of the App? I'm seeing 'Scenic Map' and 'Scenic Motorcylce Navigation', amongst others...I believe the correct one to be Scenic Map, just want to confirm.
                              Thanks,
                              • GT JWRundefined GT JWR
                                Thanks,
                                @GT-JWR
                                Scenic Motorcycle Navigation
                                https://scenic.app/
                                • GT JWRundefined Offline
                                  @Peter-Schiefer @Jörgen thanks guys.
                                    @GT-JWR
                                    https://scenic.app/
                                    @Jörgen downloaded the app, it appears that premium version is reqired to convert google maps to *.gpx...is that your finding as well?
                                      @GT-JWR Sorry, yes could be possible, I have that and not noticed.
                                      If you need something to convert, send me the link.
                                        @Jörgen thanks - at the moment, I was just investigating it and how to do it....a small group of buddies and I are going on a 10 day, 4000mi (ish) bike trip this summer (from Texas to the Grand Canyon and back), and the group leader has planned a lot on google maps and I was hoping to convert them to *.gpx for MRA. Here's a couple of links to convert, if you don't mind.
                                        Appreciate it!
                                        https://www.google.com/maps/dir/2939+Carrizo+Springs+Ct,+Katy,+TX+77449,+USA/1113+W+Birch+Ave,+Lovington,+NM+88260/@31.4003842,-104.8313997,6z/data=!3m1!4b1!4m16!4m15!1m5!1m1!1s0x8640d878d5fb9ab1:0x99c3a4b06a85d364!2m2!1d-95.72737!2d29.810078!1m5!1m1!1s0x86fcd09ee395f8cf:0x166b3e4750dfaa35!2m2!1d-103.362587!2d32.9598106!2m1!1b1!3e0?entry=ttu
                                        https://www.google.com/maps/dir/11824+US-180,+Silver+City,+NM+88022/102+Hermosa+Dr,+Holbrook,+AZ+86025/@33.5659257,-109.9146107,8.84z/data=!4m41!4m40!1m30!1m1!1s0x86d8c84acf4f592d:0x661784136867608f!2m2!1d-108.1909831!2d32.7782169!3m4!1m2!1d-109.37066!2d33.0744807!3s0x8727f0a2a482324b:0xd5afe486e4f739aa!3m4!1m2!1d-109.4121148!2d33.9247499!3s0x8726236f969f013f:0xbad6470a8cfb0c44!3m4!1m2!1d-109.3502442!2d34.0427754!3s0x872617a3f32a9689:0xab8f03c36d831c78!3m4!1m2!1d-109.7537682!2d34.0536204!3s0x8728a4ce9252014f:0xc0acbc986d328c20!3m4!1m2!1d-110.0295789!2d34.286615!3s0x872f3463fa7e3369:0x108535f4c15073c9!1m5!1m1!1s0x872fa8765fe1a7e9:0x5f6eee0e695971f!2m2!1d-110.143156!2d34.9227635!2m1!1b1!3e0?entry=ttu&fbclid=IwZXh0bgNhZW0CMTAAAR3_yzuKPex6hPLY7WwCT_rezn2z_XlB5nlTuKWZqOAnNsdMtN96TxN7Vhc_aem_Ac30wCGnQL7hKC5f7hcTTx7JT5V-rbtGsJoFV-oZ5ltqkmoxszJekpqIlEyVLe_wkVpjPuHzfQ8aihq1yDDw9D8R
                                          Appreciate it!
                                          @GT-JWR here you are.
                                          Oh, I can not add a gpx file or zip file here. I need you mail address, please send it via PN.
                                          Mzokkundefined
                                          Rob Veerman
                                          GT JWRundefined
                                          • Coordinaten
                                          • Ontvangen route niet te rijden met de Myroute app
                                            siebo vd bergundefined
                                            siebo vd berg
                                          • Route name column width
                                          • birdsview android auto
                                            Alexander nundefined
                                            Alexander n
                                          • Blue haze on top of screen in free drive
                                            stuart marrittundefined
                                            stuart marritt
                                          • Blocked Account
                                            TelBoy 0undefined
                                            TelBoy 0
                                          • Layout My Routes
                                            Alida Veenstraundefined
                                            Alida Veenstra
                                          • Battery life
                                            1.3k
