  4. problem Zumo xt
problem Zumo xt
15 Posts 11 Posters 4.3k Views 5 Watching
  • terry durkin
    terry durkin
    terry durkin
    Im trying to send routes to a Zumo xt but all i get is device not recognized, does anyone else have this problem
    TomOnTour Mzokk Don Stauffer Marinus van Deudekom Stefan Martikke 7 Replies Last reply
    • terry durkin terry durkin
      TomOnTour
      TomOnTour
      TomOnTour
      @terry-durkin
      Hi,
      cab you pleas let us know how you want to transfer it to your XT and when exactly you get the error message?
      Greetings
      Thomas
      MyRoute-APP Navigation Next (V6.0.0 - 489) on DMD T781
      MRA Navigation Next (Lifetime Gold)
      MRA Routeplanner NEXT beta (Lifetime early access)
        @terry-durkin on my XT I download the routes to my phone and send them to the device via the Garmin Drive app.
          Don Stauffer
          Don Stauffer
          Don Stauffer
          @terry-durkin When using a PC or laptop, the most reliable method requires connecting to the XT using a USB cable. From the MRA app, use the 'export' feature. It requires a one-time installation of a connector app.
          Using the Garmin Drive app wirelessly works as well, but it can be glitchy. The USB method has worked for me every time. I use the GPX 1.1 file type.
          Good luck, MRA and the XT can be a very nice combination.
          Bouke Ent nomko 2 Replies Last reply
          • Don Stauffer Don Stauffer
            @Don-Stauffer i agree
              @terry-durkin I use the drive app. Make sure your XT is online. That way it works perfect. It shouldn't make a difference but my experience is that it works best with the XT online
                Banned
                @Don-Stauffer said in problem Zumo xt:
                I'm using the MRA app on my phone and, after opening a route, i export it to my Zumo XT using the Drive app. Never had any issues!
                I also use the 1.1 GPX file type every time.
                • nomko nomko
                  @Nomko-Nomden that is exactly what I di. In theory of is possible to do it with the XT offline but I've experienced soms trouble and found that the routes were not send to the XT when it came on line.
                  nomko 1 Reply Last reply
                    Banned
                    @Marinus-van-Deudekom said in problem Zumo xt:
                    Maybe that's the problem in your case i assume?
                    I normally do it with the XT "online" so thsat i can transfer the routes directly to my XT through the Drive app. Never had any issues working like this. And i always usie 1.1 GPX, i did 1.2 but some routes work just fine but others i had issues with when navigating. So, 1.1 for me.
                    • nomko nomko
                      @Nomko-Nomden thats what I said. My usual routine. Just indicated the other one to be complete
                      • Stefan Martikke
                        Stefan Martikke
                        Stefan Martikke
                        wrote on last edited by Stefan Martikke
                        This post is deleted!
                          Stefan Martikke
                          Stefan Martikke
                          Stefan Martikke
                          @terry-durkin
                          Hello, I have the same problem. The only thing that helps is removing the external memory card, then the XT is recognized at the Notebook and the transfer works.
                          Regards Stefan
                            Simon von Kaufmann
                            Simon von Kaufmann
                            Simon von Kaufmann
                            I also had this problem as well trying to use the Web version of MyRoute-app. Some have given a partial answer but I would like to explain a bit more as I needed to work this out too. The Zumo is designed to interact with your mobile phone. So you need to download the My-route-app onto your mobile phone from the Appstore (I am using Apple ios) and then transfer the file to your Zumo using Garmin Drive. It will then come through as a track which you can convert to a route if you want to.
                            • CD130
                              Maybe as a workable alternative: Connect the zumo with the cable to your phone (use a data cable/adaptor for this) and use the files app to copy the GPX files.
                                @terry-durkin
                                Do you use a windows PC or a Mac?
                                Don Stauffer
                                Don Stauffer
                                TomOnTour
                                TomOnTour
                                Simon von Kaufmann
                                Simon von Kaufmann
                                Stefan Martikke
                                Stefan Martikke
                                terry durkin
                                terry durkin
                                  148
                                • Route exporteren uit beta
                                  Johan 5q
                                  Johan 5q
                                  124
                                • SilverFox Controller C2
                                  Hans Lamers
                                  Hans Lamers
                                • "Please verify your email" display
                                • Layers menu: option to permanently display Favorite labels
