  3. Switzerland trip
Switzerland trip
13 Posts 6 Posters 2.6k Views 1 Watching
  • Andrew Vaughanundefined Offline
    Andrew Vaughan
    Hello , sorry if I'm wrong forum first post ,
    I was seeing does anyone have some routes around the area I will be staying in Switzerland (Saint-Luc )? We are doing the 3 passes but this can be done in a day I believe . We will be there for 5 days. Any other good routes. I've had a look in the Library but they seem to be a few hours away just to join the route. Thank you.
    Nick Carthewundefined Con Hennekensundefined Kudeeundefined 3 Replies Last reply
    • Andrew Vaughanundefined Andrew Vaughan
      Nick Carthewundefined Offline
      @Andrew-Vaughan The great thing with MyRoute-app is you can take a route from the RouteXpert library, add it to your library and adjust it to suit your needs.
      • paul69undefined Offline
        hi @Andrew-Vaughan
        you could use the "create scenic route option" you would then have a rough idea of a route that suited your needs and adjust as necessary.
        i also agree with @Nick-Carthew it is quite easy to play with other routes and make them fit
        K1600 GTL
        Oukitel RT3
        iPhone 13 Pro, carpuride 702b
          @Andrew-Vaughan, Maybe you can find some inspiration here:
          https://www.myrouteapp.com/nl/info/collection/62
            Kudeeundefined Offline
            Kudee
            @Andrew-Vaughan said in Switzerland trip:
            Saint-Luc
            I stay in Switzerland, can give you some tips. Where dou you start from?
            Andrew Vaughanundefined 1 Reply Last reply
            • Kudeeundefined Kudee
              Saint-Luc
              Andrew Vaughan
              @Kudee
              Hi
              We are staying in Saint -Luc so that's our start point every day 👍🏻
              Kudeeundefined 1 Reply Last reply
                @Kudee
                Hi
                Kudee
                @Andrew-Vaughan
                Saint-Luc
                3961 Anniviers
                • Erdnaundefined Offline
                  Erdna
                  Hi Andrew,
                  Saint Luc is not the best option as "basecamp" in my opinion because of it´s location.
                  How many km would you like to ride each day? Just on road or with some off-road elements? What bike? Do you ride alone or with friends? Questions over questions... 🙂
                  For your consideration: a personal "POI list" with many passes, interesting places, etc.: https://www.google.com/maps/d/u/0/edit?mid=1wRIVqBxCOUcmLwVvuTIejBr5bh_r4pA&usp=sharing
                  Unfortunately, this cannot be done in MRA, because of too much entries.^^
                  Regards,
                  André
                  • Erdnaundefined Erdna
                    Hi Andrew,
                    Regards,
                    André
                    Andrew Vaughan
                    @Erdna Sadly its all booked for 4 of us is this not a good place ? where would be better ? there is no off road wanted all tarmac roads only . thank you
                    Andrew
                      Erdna
                      @Andrew-Vaughan It´s no bad place, but every day you will have to get out of Val d’Anniviers and after the tour back into it.
                      That means: the nearest summit in eastern direction is the Simplon pass. It´ll cost you approx. 90 minutes to get there if you use the highway. And of course you´ll have to return the exact way for another 90 minutes to get to Saint Luc.
                      The nearest summit in western direction is Col de la croix de coeur, which is also approx. 90 minutes using the highway...
                      Worst: you don´t have options to go north / south from Saint Luc because every possible route will leave you in a dead end. You´ll simply have to do that 90 minutes east or west to get anywhere else. That´s three "lost" hours every day. 😞
                      Andrew Vaughanundefined Con Hennekensundefined 2 Replies Last reply
                        Andrew Vaughan
                        @Erdna thanks for the info 👍🏻
                          @Erdna, Yes, riding/planning in Alps/Dolomites is a lot more complex then let's say Eifel, Ardennes, Vosges or other less high mountains where roads actually go OVER the mountains instead of IN BETWEEN them. The Alps are on everyone's bucket list (mine too, I am going to Austria in September), But no matter where you stay, you will always have some doubles in your routes.
                            Andrew Vaughan
                            Thank you
                            paul69undefined
                            Erdnaundefined
                            Erdna
                            Kudeeundefined
                            Kudee
                            Andrew Vaughan
                              Gianluca 0undefined
                              Gianluca 0
                              175
                              paul69undefined
                            • v5.2 (473) Feedback
                              Lenny Oundefined
                              Lenny O
                              1.2k
                              nomkoundefined
                              383
                              Leike Lodiersundefined
