  4. POI visible while navigating
9 Posts 5 Posters 1.4k Views 2 Watching
    It would be great if users could select standard POI categories, and uploaded personal libraries to be shown on the map while navigating. At the moment we can add POI to a route, so that we see those specifically added POI, which is useful, but it would also be very handy to activate complete categories like "streckensperrungen", mountain passes, viewpoints to be always visible while navigating.
      Jörgenundefined Offline
      @Con-Hennekens said in POI visible while navigating:
      add POI to a route
      Yes, would be nice to have.
      Do you remember where adding POI to a route was described? I can not find it, I think it was from you?
      • Jörgenundefined Jörgen
        add POI to a route
        @Jörgen, Select a POI category to show up on the planning map, click a POI symbol on the map, and choose "Add as waypoint" or "add as POI". Doing this from memory so excuse me for the details 😉
        Martin Wilckeundefined 1 Reply Last reply
          Martin Wilckeundefined Offline
          Martin Wilcke
          wrote on last edited by Martin Wilcke
          since the selection is implemented as a checkbox, "both" is supported as well 🙂
            Good suggestion 🙂
              @Jörgen @Martin-Wilcke @Con-Hennekens Only use Add as POI option as quite often the POI is off of the road and this could cause problems.
              Martin Wilckeundefined Con Hennekensundefined 2 Replies Last reply
                Martin Wilcke
                @Nick-Carthew
                Yes, I am aware of that.
                I often use "both", as I almost always want to have a Viapoint in this position as well. But of course I correct the position of the VP if necessary.
                Btw: I think it's a shame that the name is changed when Viapoints are moved - I only find this behaviour appropriate for SPs.
                • Martin Wilckeundefined Martin Wilcke
                  @Nick-Carthew
                  @Martin-Wilcke said in POI visible while navigating:
                  Yes that is quite nagging indeed. I believe I already outed that frustration on this forum not long ago 😉
                    @Nick-Carthew, True. I usually place the POI only, and add a WP manually with some information about the POI in the name and note. ON the road of course 😉
                    This combines beautifully with my other suggestion of the day, about "snapping" WPs to the road automatically.
                    Martin Wilcke
                    • App behaviour when in offline mode at a construction site
                      Peter Zehentreiterundefined
                    • Nav versus Gold subscription
                      322
                    • Ervaring met Garmin streetcross op MT-07
                      Karel Sterrenburgundefined
                      Karel Sterrenburg
                    • MRA: The Hassle-Free App
                      AWDC LAOundefined
                    • Hoeveel apparaten op 1 account ?
                      AWDC LAOundefined
                      308
                    • Verwijderen van routes in eigen bibliotheek
                      AWDC LAOundefined
                    • Finetunen van herberekenen zou fijn zijn.
                      M. Schrijverundefined
