  4. Additional TTS Engines
21 Posts 7 Posters 8.4k Views 2 Watching
  • M. Schrijver Offline
    There were some negative comments in the past about the default TTS voice. I wrote some of them.
    I did a search for alternative TTS engines. There aren't that many TTS engine which can be used in MRA Next. But i found one which i like.
    It is Acapela TTS Engine for Android. The app self is free but you must pay for each voice separate. A few Euro's
    Because i'm Dutch, i bought the voice "Daan". This is a good voice.
    This voice is a lot louder than the default TTS engine. The volume is more or less the same as Spotify. Besides this. The voice is also less mechanical/robotic.
    Nick Carthew Skellum Con Hennekens Dave J 0 4 Replies Last reply
      Nick Carthew Online
      Nick Carthew Online
      @M-Schrijver Not forgetting that iOS users have several different voice options already installed on their iPhones. I use the Serena voice which is one of the premium voices.
        @M-Schrijver, If those voices are louder, I definitely must check them, thanks!
        @Nick-Carthew, I had a private discussion with @AlexvLeeuwen yesterday (because the topic was closed prematurely..) and understood that in IOS you can choose only 2 voices for Belgian Dutch. Can additional voices be installed in IOS?
          Nick Carthew Online
          Nick Carthew Online
          @Con-Hennekens I have no idea if additional voices can be installed on iOS, there are more than enough English voices so I haven’t looked to install anymore.
            Skellum Offline
            Skellum Offline
            Skellum
            wrote on last edited by Skellum
            @M-Schrijver said in Additional TTS Engines:
            Sounds good, I have an IOS phone and would be grateful to know how to add a new TTS voice of my choice to the MRA Next app for use in CarPlay? or is this only for use directly from the phone?
            Thanks Tony
            • Skellum Skellum
              Thanks Tony
              Nick Carthew Online
              Nick Carthew Online
              @Skellum On your iPhone: Settings > Accessibility > Spoken content > Voices. MRA uses your phone voice so you should hear the same on CarPlay.
              Skellum 1 Reply Last reply
                I installed Acapela, but the demo voices don't work.
                  Skellum Offline
                  Skellum Offline
                  Skellum
                  @Nick-Carthew Thank you for that Nick, I can see that I can change the voice my iPhone uses (Siri etc) but that doesn't seem to change the choice I have on the MRA Next app - there are choices within the app but they do not seem to relate to the iPhone voice I have chosen?
                  • Skellum Skellum
                    Nick Carthew Online
                    Nick Carthew Online
                    @Skellum I chose Serena (premium) from my iPhone voices. Once you have chosen your voice, go to Navigation settings > Audio > Voice and then scroll down the list and select your chosen iPhone voice.
                      Dave J 0 Offline
                      Dave J 0 Offline
                      @M-Schrijver Good call on this TTS engine. Downloaded the app and a couple of voices. So much better on my Google Pixel 6 Pro. Thank you for the suggestion.
                      iPhone 15 Pro
                        You can only use the demo voices in the Acapela app. So can listen and play a bit with some settings. If you buy a voice, you can use it in other app.
                        It is a bit of a gamble.
                        • Corjan Meijerink Offline
                          Greatly appreciate you sharing this! 🙂 @M-Schrijver
                            @M-Schrijver, The app shows me this:
                            I pressed the play button and it starts circling but not any of the voices are audible. On their website some voices are demoed:
                            https://www.acapela-group.com/demos/
                            Also I see that most voices are € 4,99 except Thijs en Merel, they go for € 11,99 but both are not in the demo. I guess they are the sexy ones... 🤣
                            Dave J 0 1 Reply Last reply
                              Dave J 0 Offline
                              Dave J 0 Offline
                              @Con-Hennekens Like you, I pressed the button in the app (Google Pixel 6 Pro) and the voices played as demo as the circle turned with no problems. That was all languages and all samples.
                              iPhone 15 Pro
                              • Dave J 0 Dave J 0
                                @Dave-J-0, good to know. Strange though
                                (yes I have the volume up 😉 )
                                  Skellum Offline
                                  Skellum Offline
                                  Skellum
                                  @Nick-Carthew Thank you Nick, all sorted now with Kate (enhanced) cheers Tony
                                  • Skellum Skellum
                                    Nick Carthew Online
                                    Nick Carthew Online
                                    @Skellum Your welcome, happy to help.
                                    Stephane 30 1 Reply Last reply
                                      Stephane 30 Offline
                                      Stephane 30 Offline
                                      Stephane 30
                                      Hi, I bought Rachel (English voice) and took her out for a ride today. Loud and clear - a huge improvement!
                                      The original MRA voice is too timid and not loud enough.
                                      Thanks for the suggestion.
                                      Moto Guzzi V85 TT. MRA on my Pixel 8 (Android 16) and occasionally a TomTom Rider.
                                      • Con Hennekens Offline
                                        On my other phone (the rugged one I actually use on the bike) I was able to play the demo voices indeed. They do seem to be a bit louder indeed, but the Dutch voices are really ugly (3 of them are childs voices). The default Google TTS is much clearer and smoother in my opinion. I never understood why some people call it "robotic". That's definitely not the case on any phone I used (quite a few).
                                          #20
                                          Did a nice ride last saturday.
                                          Filtsmeister does use the default Android voice. Sometimes Flitsmeister did give some info (it runs in the background). It was a good comparisson with the Acapela voice "Daan" which is set in MRA.
                                          What a difference in favour of "Daan" Louder and less robotic/metalic
                                          What is a robotic voice? This a typical example of a robotic voice (female):
                                          https://youtu.be/yHdemBdvRIo?si=duWDWleqc7P8b-Qs&t=84
                                          At least for me. The default google TTS voice sounds very similiar (to me)
                                          The voice synthesizer of Stephen Hawkins is probably the best known "robotic" voice.
                                          Skellum
                                          Skellum
                                          Stephane 30
                                          Stephane 30
                                            459
                                          • POI naming/text display
                                          • Stemgeluid sterker bij afspelen muziek
                                          • MRA groups
                                            Steve Standing
                                            Steve Standing
                                          • Onbegrijpelijke afslagen
                                          • GPX1.2 & Garmin Tread
                                            MTC-Zeilberg
                                            MTC-Zeilberg
                                          • Folders that can store tracks and waypoints
                                            martin-phogel.de
                                            martin-phogel.de
