  4. Openstreetmaps instead of Here maps
29 Posts 14 Posters 15.7k Views 4 Watching
    @mdj, I am pretty sure it was NOT created with the HERE map, because if I compare the exact same spots, the HERE map has totally NO roads in that area, where the OSM map does. I think that area has recently been developed?
    mdj
    mdj
    mdj
    @Con-Hennekens ah yes there are no roads there for sure. that why i set all the waypoints in that part to "skip, i dont expect any proper navigation but i expected to see on my phone the line like i set it in the browser. thats how understood the "skip" feature to work "forget the routing and just show me a line to the waypoint, i know what im doing"... obviously it seems like i dont know what im doing 🙂
    but anway, the route was still created with here because when i tried to open it after my trial expired it told me so.
    i know i can export the route as a .gpx file and reimport it as a track, and it would work. but i can do the very same with free solutions allready. i hoped MRA could give me on-road navigation together with just "straight line to waypoint" when i set the waypoint to skip
    • mdj mdj
      @mdj, Ah, that changes EVERYTHING! 😉
      You could have the HERE map activated, but in that case you had also the maplayer for OSM active, because that one shows the little trees and stuff (OSM has better TOPO support than HERE actually, so I understand why you would want to choose that layer). Fact is that where the online planner supports the Offroad function, the App actually does not (yet). So that seems to be the problem you encountered then.
      Is this a feature you use often? I guess it will get to the app in due time. Is there another reason you let your trial expire?
      mdj 1 Reply Last reply
        mdj
        mdj
        mdj
        @Con-Hennekens no that was actually the only reason.
        i really liked the webinterface for route-planing. there are some little things i would love to see improved, like the POI System or a dark-mode for the interface, but overall its great.
        but the fact that the route i make in the browser is not 100% the exact same one that i see on my phone kinda defeates the purpose for me. i ride offroad a lot and i understand that i cant have navigation along a non-existing road 😄 but i just want the "straight line to waypoint" -like i see it in the browser- also on my phone. that single feature alone is the main selling point for me.
        MotoCon Lynchy67 2 Replies Last reply
        • mdj mdj
          @mdj, that is a pitty, because the planner and navigation combo really works well, and I cannot think of any combination having a better planner-to-navigator result than the MRA combo. Know that:
          • the offroad (straight line to waypoint) function will definitely get implemented in due time. That will make offroad use possible in the navigation module too.
          • there is an overhaul of the webinterface coming up too, I think somewhere this year.
          So it will be worthwhile to check back regularly. That having said, for really frequent Offroad trips like TET, there probably are other apps better suited. I think I need to be honest about that 😉
          • mdj mdj
            Lynchy67
            Lynchy67
            Lynchy67
            @mdj
            I will presume you are aware of OsmAnd.
            It has a farely steep learning curve and at a pretty reasonable cost.
            • Lynchy67 Lynchy67
              @mdj
              mdj
              mdj
              mdj
              @Lynchy67 yes thank you. thats my current software. gpx.studio for the planing and osmand on the phone. it works perfectly but is way less elegant.
              @Con-Hennekens i will definitely keep an eye on MRA, its really 90% awesome, but the last 10% are what i need it for the most 🙂 anyway, thank you for your time and help
                @Henk-de-Wit-1 we wish to add different map layers later on 🙂
                Peter Greenacres
                Peter Greenacres
                Peter Greenacres
                @Corjan-Meijerink Hi Corjan, I'm trying hard to stick with MRA Navigation but really don't like the HERE Maps, lack of detail, blue colour. I note that you've stated another map will be available, presumably OSM. Please can you comment on timing. Thank you
                • Bouke Ent
                  i also have problems with here colors. specialy with track line that is white. my solution is sometimes that i use osmand or kurviger v1 app on my android phone. both use osm offline maps. and both you can change color of route and track line.
                  Drabslab 1 Reply Last reply
                    We will investigate the possibility of adding custom map styles to HERE 🙂
                    This is something I will take a look at around March.
                    Jay Salvo 1 Reply Last reply
                    • Bouke Ent Bouke Ent
                      #24
                      @Bouke-Ent
                      I admit, I have thought for a long time "why are all these people nagging about the HERE map colors, ain't that totally irrelevant".
                      But now I actually had a look at the here map in the planner and indeed: this is a whole new dimension of uglyness compared to Google and TomTom Default.
                      Zooming in makes it better though
                      Bouke Ent 1 Reply Last reply
                        Yes, I really wonder what their motivation was at HERE to de-detail the already detail lacking map...
                        • Drabslab Drabslab
                          @Bouke-Ent
                          @Drabslab said in Openstreetmaps instead of Here maps:
                          @Bouke-Ent
                          With sun on the phone it is harder to see. i also have my tt so i will manage but i like to see the track and it is not always easy. with alternative like osmand or kurviger it is better to see in some situation.
                            Jay Salvo
                            Jay Salvo
                            Jay Salvo
                            @Corjan-Meijerink Hello Corjan was the plan to have more contrasting colours scrapped? I love using My Route App for planning routes but struggle with the contrast when using on my Motorbike. Still hoping this is something this going to happen.
                            Dave J 0 1 Reply Last reply
                            • Jay Salvo Jay Salvo
                              #28
                              @Jay-Salvo There are options for different colours for the maps under ‘Navigation Settings’, ‘Map Layer’ and then select ‘Map Style’ at the top. Three main styles which can be changed further:
                              iPhone 18 Pro
                              • Dave J 0 Dave J 0
                                Jay Salvo
                                Jay Salvo
                                Jay Salvo
                                @Dave-J-0 Hi Dave Im referring to the track colour, in the MRA its blue, in other apps its higher contrast or you can choose an entirely different colour.IMG_8100.JPG IMG_8099.JPG
                                Henk de Wit 1
                                Henk de Wit 1
                                Jay Salvo
                                Jay Salvo
                                Peter Greenacres
                                Peter Greenacres
                                mdj
                                mdj
                                Lynchy67
                                Lynchy67
                                  Will Brooks
                                  Will Brooks
                                  3.0k
                                  1.1k
                                  Andy taylor 0
                                  Andy taylor 0
                                • The ‘Start route here’ option doesn’t seem to be working properly.
                                  Parantapa
                                  Parantapa
                                  Marcel Versluis
                                  Marcel Versluis
                                • Ordnerstruktur in der neuen Beta Version
