  4. Kan route niet berekenen op Android telefoon
55 Posts 9 Posters 36.3k Views 4 Watching
    @Coenox to get the maps down liared, did you tty going into the app settings and deleting the data files?
    Coenox
    Coenox
    Coenox
    wrote on last edited by Coenox
    #42
    @Doug-Robinson
    Good suggestion, already did that. Does. Not solve the problem.
      I am very interested to see some footage, either a screen recording or some pictures of the happening and the resulting error messages.
      Coenox 1 Reply Last reply
        Coenox
        Coenox
        Coenox
        @Con-Hennekens !
        Here is a video. First showing that I can't download maps, then trying to navigate to a favorite location.
        https://youtube.com/shorts/TLIrLuxfsXU?si=-bzOiiXrWh7WRexH
        • Coenox Coenox
          @Con-Hennekens !
          #45
          @Coenox, Thank you. Does it also do that when you disable wifi and activate the cellphone data network? The reason for it to work when you start a walk or bicycle route, must lay in the fact that there is no Turn-by-Turn assistance based on the Here maps. I am thinking a defective SD card, or corrupted offline maps, but it is a strange case indeed.
          If you empty storage or the app through the Android system - Apps menu (effectively deleting all offline maps) does it do the same immediately after trying to download offline maps?
            Coenox
            Coenox
            Coenox
            Disabled WiFi: same result
            SD card: my Samsung S23 ultra does not have a slot, 'only' 512 Gb internal storage
            Empty app cache and storage: same result
            Corrupted offline maps: there are no offline maps since I can't download them
            • Coenox Coenox referenced this topic on
            • TorqueRider TorqueRider referenced this topic on
              @Coenox @Theo-Knarren Kan het zijn dat jullie de duckduckgo app hebben geïnstalleerd? Deze (https://duckduckgo.com/duckduckgo-help-pages/p-app-tracking-protection/what-is-app-tracking-protection/) instelling lijkt mogelijk effect te hebben op een communicatie die met HERE moet plaatsvinden 🙂
              Coenox MotoCon 2 Replies Last reply
                Coenox
                Coenox
                Coenox
                Yes, held! Dat was het. Duckduck go verwijderd en nu werkt het. Daar was ik zelf nooit achter gekomen. Wel vervelend, want ik gebruik het graag. Maar heel veel dank!
                  @Corjan-Meijerink, Goeie vondst!
                  @Coenox, er zal toch wel een whitelist in zitten?
                  • Coenox Coenox
                    @Coenox super, dank voor de terugkoppeling! 🙂
                    Nu kan ik hiermee verder.
                    Ik zal bij HERE nagaan waarom hun connecties worden geblokkeerd!
                    Coenox Lars van Herel 0 2 Replies Last reply
                      Coenox
                      Coenox
                      Coenox
                      #51
                      Nog een toevoeging: nadat het werkte, heb ik DuckDuckGo geherinstalleerd. Navigatie blijft nu werken. Het lijkt dus vooral de initiële activatie van HERE te zijn.
                      En ik ben benieuwd of het bij Theo hetzelfde probleem was.
                      Theo Knarren 1 Reply Last reply
                      • Coenox Coenox
                        Theo Knarren
                        Theo Knarren
                        Theo Knarren
                        @Coenox ik ga het uitproberen en meld me terug als het werkt
                        • Theo Knarren Theo Knarren
                          Theo Knarren
                          Theo Knarren
                          Theo Knarren
                          @Theo-Knarren is een heel goede tip. Ik had echter geen DuckDuckGo op mijn telefoon. Heb vervolgens de app DuckDuckGo geïnstalleerd. Kon daarna in MRA off line kaarten installeren, hetgeen voorheen niet mogelijk was. Maar bovenal het belangrijkste MRA navigatie WERKT zoals het moet.
                            Theo Knarren
                            Theo Knarren
                            Theo Knarren
                            @Theo-Knarren alle eer voor de tipgever👍
                              Lars van Herel 0
                              Lars van Herel 0
                              Lars van Herel 0
                              @Corjan-Meijerink Bij mij werkt het helaas niet met Duckduck 😞 foutmelding: "kan route niet berekenen" (in navigatie module) Bij offline kaarten: "kan de nieuwste kaartupdate-informatie niet ophalen ! er ging iets mis" Dus geprobeerd om met en zonder Duckduck op mijn Samsung S9+, ook met opnieuw opstart enz. Vorige motor vakanties Frankrijk Spanje werkte het nog wel hetzij met veel kuren, was altijd spannend of het weer lukte. HELP svp.
                              Lars van Herel 0
                              Lars van Herel 0
                              Theo Knarren
                              Theo Knarren
                              Coenox
                              Coenox
                                Tegel Werner
                                Tegel Werner
                              • Béta to no-béta
