  3. Distance & time along a Route
7 Posts 3 Posters 1.3k Views
  • Craig 4undefined Offline
    Craig 4
    Hi, once you have planned a route is there a way to see the distance and time to a certain point on the route? i.e. if I planned a 5 hour ride, set off at 10am and want to plan a stop for dinner say at 1pm, is there a way to see where i would roughly be at that time? Hopefully this makes sense, I've seen something like this on other route planners, you hover your cursor over a point in the route and it gives you distance and time. Thanks.
    • Craig 4undefined Craig 4
      @Craig-4 Hi Craig, In the routepoints/waypoints overview in the 'big' menu bar left of the map, you can see the distance and time up to every routepount/waypoint. If you find your target to land between two waypoints, just add another waypoint and move it until you've found the target time/distance. You need to calculate though for a certain time target:
      I.e: You start at 10:00, lets say waypoint 30 is at 100km/3h10, then with a margin you end up at that waypoint at 13:10.
      • Arno van Lochem - Senior RXundefined Offline
        In addition to Stefan: Make the restaurant poi's visible and find a nice restaurant near your chosen waypoint.
        • Arno van Lochem - Senior RXundefined Arno van Lochem - Senior RX
          @Arno-van-Lochem Yes indeed, I suggest also to turn on the cafe/pub POI since I've found that not always the restaurant or cafe is put into the correct category. I usually check the POI's with Google Hybrid overlay to confirm the intended restaurant/cafe. 🙂
            wrote on last edited by Arno van Lochem - Senior RX
            When I plan a stop somewhere, I always check in Google if the restaurant still exists. And whether it will, for example, not open until 5 pm. Those kind of things.
              @Arno-van-Lochem Yes, exactly that. I did the same thing for a trip to the Eifel coming August and found that the POI and Google Hybrid data did not match the actual restaurant based on address. Nice.
                Craig 4
                That's brilliant, thank you all for your help.
                Craig 4undefined
                Craig 4
                  Arjan de Vriesundefined
                  Arjan de Vries
                • Problema Car play
                  Jan 50undefined
                  Jan 50
                  1.8k
                • Adjusting start point surrounding routes
                  M. Schrijverundefined
                • these days very slow to calculate routes
                • 7.5t restrictions not working
                  Next Stopundefined
                  Next Stop
                • RouteLab Default Location
                  white.mouseundefined
                • Track, route als track slaat lus over
                  Hns_Brwrundefined
                  Hns_Brwr
                  1.0k
