  4. Offline maps on SD card manage too difficult
8 Posts 3 Posters 1.8k Views 2 Watching
  • Corrado Miniati
    Hi everybody,
    offline maps stored on the device's SD card often don't work and the app freezes, while if I store the offline maps on the internal memory everything works better, why?
    Best Regards
    • Corrado Miniati Corrado Miniati
      Hi everybody,
      Best Regards
      @Corrado-Miniati-0
      Maybe the reading speed of the sd-card?
      Corrado Miniati 1 Reply Last reply
        @Corrado-Miniati-0
        @Hans-van-de-Ven-MRA-Master
        Hi Hans,
        maybe, I have a Samsung SD card 128 GB, U3 until 100 MB/s.
          Hi Hans,
          @Corrado-Miniati-0
          That should work
            @Corrado-Miniati-0
            That should work
            yes it should but it isnt happend
              @Corrado-Miniati-0, SD card performance is very dependent on the device it is being used in. What phone are you using? Also the mechanical pressure on the contacts can fail easily under motorcycle vibrations if the SD card slider is a bit worn. Besides that, SD memory will never be as performant as the internal storage. If at all possible, I would try to avoid the use of an SD card. That has nothing to do with the app, but everything with the extra problem-sensitivity you add with it.
              • Rob Verhoeff Rob Verhoeff referenced this topic on
                Hi Con, thanks for the feedback.
                I'm using the Samsung Tab Active 3, now I have tranfer the maps into internal memory and the app funcions better.
                  @Corrado-Miniati-0, great! You're welcome.
                  • Hide warnings on the map
                  • Testroute segmenten
                  • Map Layers
                    Martin White
                    Martin White
                    Michael 2v
                    Michael 2v
                  • Bollard trouble
