  4. ca ‘t use app offline
9 Posts 5 Posters 1.2k Views 1 Watching
  • artboneundefined Offline
    artbone
    I’m trying to use the myroute-app on a Umidigi Bison android 12 phone. I also use an iPad to plan routes then open them on the phone. My first problem is that I can’t open any routes on either device if I’m not online. If I open an app online, I can use it but if I want to change anything when I go offline, I can’t. Offline, I can’t do anything, either open routes, look at downloaded maps, or look at my account.
    I just noticed that there is a button to download routes and, if I download the route, then I can see it when I’m offline. Is that required with every route on the new system?
    Another problem is that when I try to write anything on the forum, I can’t use the “C” or the “N” key. When I press either one, the screen jumps to another screen.
    I’ve been using this app since it was Tyre-2-travel, so I’m familiar with it but I can’t figure this out.
    • artboneundefined artbone
      Rob Verhoeffundefined Offline
      @artbone To use routes offline, you indeed need to download them first on your mobile device using the download button, which you've already figured out. Additionally, you also need to have all the maps of the areas through which your route passes available offline to navigate offline.
      Modifying an existing route that is also available as download on your mobile device can only be done in online mode. You directly use Routelab (the website).
      Naturally, all of this is also included in the manual that you can find in the support section.
      artboneundefined 1 Reply Last reply
        artbone
        @Rob-Verhoeff Tha ks . A y idea about the letters I can’t use?
        Rob Verhoeffundefined Lynchy67undefined 2 Replies Last reply
          @artbone Nope, I guess that must be in your configuration. I'm no Android guy, sorry.
            Lynchy67undefined Offline
            Lynchy67
            @artbone
            Are you using any type of Bluetooth Controller.
            Your text indicates functionality akin to the use of a Bluetooth Controller.
            If you have Bluetooth on try turning it off!
            I may however, be barking up completely the wrong tree!
              @artbone, I think @Lynchy67 is on the right track... Are you using the forum through the webview in the app? 😉 Never considered that that is an option. The C and N keys have a function in navigating through the app, for use with bluetooth controllers. If you open the forum in any ordinary browser, it will work just fine.
                artbone
                @Con-Hennekens Yep, I finally figured that out. I’m on the website now and can use all the letters on the keyboard. That sort of makes the app useless to me. I guess I’ll just use the website in the future.
                Con Hennekensundefined Corjan Meijerinkundefined 2 Replies Last reply
                  @artbone, "the app useless"? The app is for tracking and navigation (since Next). It is not a forum-frontend. Anyway, not intended as such.
                    @artbone regarding the issue with some keys not working, we are looking into that. It however should only occur when using a BT keyboard.
                    Lynchy67undefined
                    Lynchy67
                    artboneundefined
                    artbone
                    • Imported POI files visible in App
                      Keith Hofgartnerundefined
                      Keith Hofgartner
                    • How to exclude short time road blocks during navigation
                      Axel Härtlundefined
                      Axel Härtl
                    • The route is planned to go the wrong way round the roundabout
                    • Geen routeberekening
                      Nick Carthewundefined
                    • Onbegrijpelijke omweg
                      Lex.Kloet.RXundefined
                      Lex.Kloet.RX
                    • Apple Carplay. MRA Navigation stops after re-calculating
                    • Truck / Camper Dimensions
                      Herman Veldhuizenundefined
                      Steve 2vundefined
                      Steve 2v
                      227
