  4. ca ‘t use app offline
9 Posts 5 Posters 1.8k Views 1 Watching
  • artbone Offline
    artbone Offline
    artbone
    I’m trying to use the myroute-app on a Umidigi Bison android 12 phone. I also use an iPad to plan routes then open them on the phone. My first problem is that I can’t open any routes on either device if I’m not online. If I open an app online, I can use it but if I want to change anything when I go offline, I can’t. Offline, I can’t do anything, either open routes, look at downloaded maps, or look at my account.
    I just noticed that there is a button to download routes and, if I download the route, then I can see it when I’m offline. Is that required with every route on the new system?
    Another problem is that when I try to write anything on the forum, I can’t use the “C” or the “N” key. When I press either one, the screen jumps to another screen.
    I’ve been using this app since it was Tyre-2-travel, so I’m familiar with it but I can’t figure this out.
    Rob Verhoeff Con Hennekens 2 Replies Last reply
    • artbone artbone
      Rob Verhoeff Offline
      @artbone To use routes offline, you indeed need to download them first on your mobile device using the download button, which you've already figured out. Additionally, you also need to have all the maps of the areas through which your route passes available offline to navigate offline.
      Modifying an existing route that is also available as download on your mobile device can only be done in online mode. You directly use Routelab (the website).
      Naturally, all of this is also included in the manual that you can find in the support section.
      artbone 1 Reply Last reply
        artbone Offline
        artbone Offline
        artbone
        @Rob-Verhoeff Tha ks . A y idea about the letters I can’t use?
        Rob Verhoeff Lynchy67 2 Replies Last reply
        • artbone artbone
          @artbone Nope, I guess that must be in your configuration. I'm no Android guy, sorry.
          • artbone artbone
            Lynchy67 Offline
            Lynchy67 Offline
            Lynchy67
            @artbone
            Are you using any type of Bluetooth Controller.
            Your text indicates functionality akin to the use of a Bluetooth Controller.
            If you have Bluetooth on try turning it off!
            I may however, be barking up completely the wrong tree!
            • artbone artbone
              @artbone, I think @Lynchy67 is on the right track... Are you using the forum through the webview in the app? 😉 Never considered that that is an option. The C and N keys have a function in navigating through the app, for use with bluetooth controllers. If you open the forum in any ordinary browser, it will work just fine.
                artbone Offline
                artbone Offline
                artbone
                @Con-Hennekens Yep, I finally figured that out. I’m on the website now and can use all the letters on the keyboard. That sort of makes the app useless to me. I guess I’ll just use the website in the future.
                Con Hennekens Corjan Meijerink 2 Replies Last reply
                • artbone artbone
                  @artbone, "the app useless"? The app is for tracking and navigation (since Next). It is not a forum-frontend. Anyway, not intended as such.
                  • artbone artbone
                    Corjan Meijerink Offline
                    @artbone regarding the issue with some keys not working, we are looking into that. It however should only occur when using a BT keyboard.
                    artbone
                    artbone
                    Lynchy67
                    Lynchy67
                      288
                    • Google maps and Streetview
                      Stevedo 6 0
                      Stevedo 6 0
                      806
                      siebo vd berg
                      siebo vd berg
                      533
                    • Transport modes?
                    • New Zealand Routes
