  4. No voice prompts.
No voice prompts.
14 Posts 8 Posters 192 Views 1 Watching
  • ferrand24gmail.comundefined Offline
    ferrand24gmail.com
    I really would like make a 100% post one day, unfortunately that day hasn't come yet.
    I have no voice prompts, they are turned on and volume is turned up. I have plotted five routes in Spain and Portugal I have completed two of them with no prompts
    Another strange problem has shown up. When I click on Start to begin navigating the route it offers is not identical to the one I have plotted. Unfortunately I can't work out how to add a screen shot to this post using my phone
    I would dearly love to recommend the app to people but at the moment I can't.
    Nick Carthewundefined Con Hennekensundefined Drabslabundefined 3 Replies Last reply
    • ferrand24gmail.comundefined ferrand24gmail.com
      Nick Carthewundefined Offline
      @Roger-Doidge to add a photo or screenshot to a post you need to select the icon to the right of the emoji icon, this may mean that you need to slide the icons along to uncover it.
      ferrand24gmail.comundefined 1 Reply Last reply
        @Roger-Doidge, on rare occasion I have had no voice too, on Android. A force quit and restart always solved that. I have not been able to pinpoint under what circumstances this happens.
          ferrand24gmail.com
          Here are two screenshots. The first one is the route I plotted and the second is the route that appeared when I clicked start. As you can see it's not the exact route I wanted to follow.
          How can this happen?
          richtea999undefined 1 Reply Last reply
            richtea999undefined Offline
            @Roger-Doidge A single way point between the start and finish over 700Km gives the routing engine plenty of scope to change the route on the fly.
            The route engine has satisfied your single way point, so the rest of the route can deviate depending on traffic conditions, road closures, etc.
            If you add more waypoints, you'll have more success in keeping to the route you want.
            {EDIT: the other thing that might affect the routing is using two different routing engines. If you're using the MRA app for navigation, you want to use HERE in the planning phase too, so the two match.)
              Drabslabundefined Offline
              @Roger-Doidge @richtea999
              Richtea is right. One waypoint on a route of 720 km gives the certainty that the navigation tool will deviate. What you may try to correct that (i never tried ot but i think it should work)
              Open the route in the planner, in the menu click on toolkit, in toolkit click on expand. You will get a pop up asking how many waypoints you want to add along the road. First so you
              This will make the planner add additional waypints along the route.
              Careful: i never tried this. I would advise taking a copy of the originAl route first so can turn back if my suggestion causes problems
              • Drabslabundefined Drabslab
                @Drabslab the expand works well and places the new waypoints on the route.
                Lynchy67undefined 1 Reply Last reply
                  Lynchy67undefined Offline
                  Lynchy67
                  @Doug-Robinson said in No voice prompts.:
                  Unfortunately, that is simply not correct!
                  See my screenshot below for WP2, you need to check every single “Expanded” Waypoint for accuracy!
                  Snapshot 27-10-2023 16:05.jpeg
                  Here is the expanded route unedited, zoom to the full extent to see the number of issues.
                  https://www.myrouteapp.com/en/social/route/8343856?mode=share
                  Drabslabundefined RetiredWingManundefined 2 Replies Last reply
                  • Lynchy67undefined Lynchy67
                    @Lynchy67 indeed but for someone travelling in Portugal with no access tp a computer
                    it may help
                      @Lynchy67 if that minor variance as shown on your screen shot is going to cause problems then there is a defect in navigation. Being slightly off the route line with no other roads around can't possible be an issue. Perhaps MRA needs to implement a "snap to" feature if alignment is that critical.
                      Lynchy67undefined Con Hennekensundefined David Bonnerundefined 3 Replies Last reply
                        Lynchy67
                        @Doug-Robinson
                        I have been with MRA (and Tyre before that) from the start and all the info I have been given over these years has been that the waypoints should always be placed exactly on the Route line.
                        I do this with expanded routes a lot and have never had issues with an expanded route.
                        I will stick with ensuring that all expanded waypoint are exactly on the route line.
                        I do like your suggestion regarding a Snap-To function so I will suggest that when we switch to updating the Route Planner
                          @Doug-Robinson, That minor variance as shown in the screenshot is definitely NOT a problem. The variance caused by the expand feature can however be bigger than shown, and sometimes they can get placed at unlucky places, like the crossings a few meters to the left. Then it can definitely cause problems...
                          I never use the expand feature. I place waypoints with my own logic. That seldomly fails me 😉
                          @Lynchy67 said in No voice prompts.:
                          Yes, they need to be checked, and then you may as well put them on route, and far enough from any crossings or sideroads, in the proces.
                          To both: That snap is a great idea. If you look closely, that is already what is happening. Where the WP snaps to the route, you can see a little black dot. Problems occur at crossings, where the WP can snap to too many roads. Therefore it is important to check your waypoints.
                            David Bonnerundefined Offline
                            David Bonner
                            @Doug-Robinson If I recall correctly a while back there was function in the toolkit to align waypoints to the roads. I can’t recall what this function was called and it disappeared from the menu at some point, but it would be useful to reinstate it.
                            • David Bonnerundefined David Bonner
                              Lynchy67
                              @David-Bonner
                              I believe that functionality was in the old Navigation App where you could plot a route directly in the App and it would Snap to the Route Line.
                              richtea999undefined
                              ferrand24gmail.com
                              Drabslabundefined
                              Lynchy67undefined
                              Lynchy67
                              David Bonner
                                Jaspal Bhatti 0undefined
                                Jaspal Bhatti 0
                                148
                                Lenny Oundefined
                                Lenny O
                                276
                                Lenny Oundefined
                                Lenny O
                              • v5.2 (473) Feedback
                                M. Schrijverundefined
                                Gerard Wullinkundefined
                                Gerard Wullink
                                485
                              • Location always on, why?
                                Leike Lodiersundefined
                              • Unknown symbol
                                Travellexxieundefined
                              • exporteren naar xt2
                                Mzokkundefined
