  4. pop-up <Move-Save as-Delete> doesn't show (solved)
30 Posts 7 Posters 15.1k Views 2 Watching
  • Jörgen
    Maybe this will help.
    https://youtu.be/cOEGPExqgTU
    By clicking on a folder, the box just flashes and disappears.
    Con Hennekens TorqueRider 2 Replies Last reply
    • Jörgen Jörgen
      @Jörgen said in pop-up <Move-Save as-Delete> doesn't show:
      The video seems to be private, I can't watch it.
      @Jack-van-Tilburg said in pop-up <Move-Save as-Delete> doesn't show:
      It is up to the developer to make the application function browser independently. And I know that's difficult.
      It's up to the developer of a browser to make it compliant too. All software contains bugs. It's too easy pointing only at MRA, while Safari seems to be the only browser having this problem. Although of course it still may be an MRA bug, it is as easy to point it to the Safari browser.
      Jörgen TorqueRider 2 Replies Last reply
        @Con-Hennekens please try again: https://youtu.be/cOEGPExqgTU
        • TorqueRider TorqueRider
          Who recognizes this and knows the solution?
          When using the checkbox to select multiple items in the personal library for an action <Move|Save as|Delete>, a pop-up will appear to activate that action.
          On my iPad (7th gen), iPadOS 17.03 and on my MacBook (M1Pro) with MacOs Sonoma 14.0 in combination with Safari 17.0, the Pop-up flashes but disappears in a fraction of a second and cannot be used. I have set all settings in Safari for additional functions for Myrouteapp to "Allow". Without exception.
          When using Firefox I do not have this issue. But I want to use Safari exclusively.
          @Jack-van-Tilburg Same issue here (latest software versions): when selecting an item, the actions box pops up very briefly.
          I've looked into the code a bit, stepping through it in the debugger, and I've noticed the pop-up becomes visible when, on line 473 of base.js, the CSS class "in" is added to the ".explorer-selectedactions" block. However, it immediately becomes invisible again as well, when stepping over this line. I can only assume a different part of the code reacts to the addition of the "in" class and changes the CSS to make the pop-up invisible, or perhaps the z-index isn't handled correctly by Apple. The "in" class is on the box when inspecting the element.
          Just noticed it also popups very briefly when deselecting a previously selected row.
          It only happens when selecting the first (or deselecting the last) item.
          Rob Verhoeff TorqueRider 2 Replies Last reply
          • TorqueRider
            I can’n answer now. Because I am on tour with friends
              #14
              @Herko-ter-Horst perhaps Safari is more strict in the handling of those pop-ups then other browsers do?
              Herko ter Horst TorqueRider 2 Replies Last reply
                @Rob-Verhoeff If so, that has to be a very recent development (worked just fine last time I checked). And I would expect to see some error message in that case. Also, it isn't really a "pop-up" pop-up as far as I can see.
                  I didn't email Apple. It was an MRA service ticket.
                  Okay, hoping MRA solves it for us... 😉
                  A bit offtopic: I use Firefox now as a crossplatform browser with all my favorites at hand. And it has some nice plugin's. Regarding safety, I think all "major" browsers have that in order.
                  @Rob-Verhoeff said in pop-up <Move-Save as-Delete> doesn't show:
                  You think that Google spyware is safe?
                  https://www.forbes.com/sites/zakdoffman/2021/03/20/stop-using-google-chrome-on-apple-iphone-12-pro-max-ipad-and-macbook-pro/?sh=69a169514d08
                  https://www.bleepingcomputer.com/news/security/chrome-use-subject-to-restrictions-in-dutch-schools-over-data-security-concerns/
                  Con Hennekens Rob Verhoeff 2 Replies Last reply
                  • Drabslab Drabslab
                    @Drabslab, Apple warning for data gathering by Google is rather funny, don't you think? 🤣
                    Drabslab 1 Reply Last reply
                      Yes, a typical example of a kettle accusing the pot from being black.
                      But it remains a fact that the majority of concerns expressed by governments on privacy, security and spying on users are about two compnaies with Google being one of them.
                      • Drabslab Drabslab
                        @Drabslab, certainly true, but I think it's about more than 2 companies. Apple, Google, Microsoft, Meta and many many more companies are no popes in the subject.
                        Drabslab 2 Replies Last reply
                          there is a main difference:
                          • Users are clients in the case of Microsoft, and Apple,
                          • they are the product sold to other companies in case of Google and Facebook
                            and there is a difference between "not being a pope" and being fined 8.3 billion euro for slightly illegal activities 🙂 🙂 🙂
                            • Drabslab Drabslab
                              #22
                              @Drabslab, I believe Apple is still subject to a 39 billion fine... 😉
                              Oh, and do you really think Apple does NOT sell off bigdata? Users are clients indeed, AND the product at the same time. I am not downplaying the privacy problems. But don't pin them just on Google and Facebook. The other are equally evil...
                                @Con-Hennekens said in pop-up <Move-Save as-Delete> doesn't show:
                                turn to the dark side.... we have coockies 🙂
                                • Jörgen Jörgen
                                  @Jörgen
                                  Yep. That's what it actually looks like.
                                  Big thanks for this video!
                                    @Herko-ter-Horst said in pop-up <Move-Save as-Delete> doesn't show:
                                    This is beyond my knowledge 🙂
                                    But hopefully the technicians can do something with it 👍
                                      That's definitely true. But Safari also offers the option to cancel the pop-up blocker in the settings.
                                        That is absolutely correct.
                                        For that reason, beta versions are made available to developers well in advance so that they can test whether their stuff still works. If there are issues, then something must be done. And depending on the test result you can determine where that is.
                                        • Drabslab Drabslab
                                          @Drabslab said in pop-up <Move-Save as-Delete> doesn't show:
                                          Well, in that case... I'm glad I said "I think...". So I guess not 😁
                                          • New Zealand Routes
                                            484
                                          • Getal in begin logo
                                          • best format to download
                                          • Opknippen route in etappes
                                          • routeXpert
