  4. Navigation is not working
15 Posts 10 Posters 5.4k Views 1 Watching
  • Tony Baker
    Tony Baker
    Tony Baker
    I have exactly the same issue with the app on my phone. The map freezes but the turn by turn instructions stay up with the route. Exactly the same happens with carplay. This fault usually happens after about 30 mins.
    • Simone 11 Simone 11
      @Vosser thanks, I'll try this workaround. Up to now I was only starting the app on my mobile before starting the android auto app.
      Simone 11
      Simone 11
      Simone 11
      @Vosser Unfortunately it worked for a couple of hours, then.. again freezed and no way to make it works again, even unplugging phone and repeating the procedure.
      Android Auto sometime gives also an "unexpected error" after some time.
      I have bought a lifetime navigation app but I hope not wait a life to see it working...
      Vosser 1 Reply Last reply
        What is the temperature of the phone while using MRA.
        High temperature can cause freezes
        • Darren Sharp 0
          Darren Sharp 0
          Darren Sharp 0
          I hope you figure this out soon! Planning a week long trip in a week and now the app does not work on android auto. It worked a couple of weeks ago pn my last trip but now it does not work! Did you update it?
          Tom Cat 1 Reply Last reply
          • AirmanW8
            AirmanW8
            AirmanW8
            +1 for CarPlay issues.
            I just started using the app this week. So far so good. I'm ready to buy a lifetime subscription but this little hiccup wasn't encouraging.
            I believe I started the phone app, but I don't recall if I used CarPlay to start the route. I was getting turn-by-turn in the top left and the map was.. mostly frozen. It seemed to update to a seemingly random spot once in a while. I ended up exiting the route through CarPlay, killing the app on my phone and starting it all from CarPlay. That worked the rest of the day. (250 miles, 5 hrs)
            I then was able to open my phone app and get the extra details of the ride there. I like seeing the speed limit/my speed like Waze on the phone app. (well.. I'd like it on CarPlay, but..)
            MyRouteApp - Trial
            Route Planner - Gold
            iPhone 14 Pro
            CarPlay Honda Goldwing 2022
              Vosser
              Vosser
              Vosser
              @Simone-11 so sorry to hear it doesn't work for you. Hope they find a solution for you.
              • Darren Sharp 0 Darren Sharp 0
                Tom Cat
                Tom Cat
                Tom Cat
                @Darren-Sharp-0 I would definitely plan a backup. I just did a 3 day trip and I was to lead day 2. 350 miles over 8 hours and less than a mile into the trip, the turn-by-turn froze in the top left. I was so focused on this that I missed a turn and the app never recalculated to get back on route. After a few more miles I had to stop the whole group so my buddy could take over and lead through his GPS and the GPX files I sent him the day before. It's a good thing I sent him the route or the day would have been ruined.
                I guess I'll be digging out my TomTom and have to convert all my routes back to that platform. Very frustrating to say the least.
                I was using a Pixel 7 with the latest OS and updates through Android Auto on my 2021 Honda Goldwing.
                • ger kerkhoff
                  ger kerkhoff
                  ger kerkhoff
                  Goed dat er dit forum is. Al heel lang gebruik ik MRA eerst op de motor nu in de camper (voorzichtig erbij met Carplay). Ik maak thuis altijd de routes in MRA en zet die op een USB-stick. Ongeveer 7000 km per reis en opgedeeld in dagelijkse stukken. Die stick past dan in het navigatie systeem van de MBUX van de camper(Mercedes). Ik kies dan voor opgeslagen routes en dat werkt dan prima. Nu wil ik de routes via carplay gaan rijden, maaaaaar het scherm bevriest, dus ook van mijn kant problemen met de CARPLAY verbinding.
                  • AirmanW8
                    AirmanW8
                    AirmanW8
                    Any update to this? I'm still regularly seeing the same issue. It's been 2 months and several updates I'm sure. There doesn't seem to be any rhyme or reason. I've closed the app several times and started from the Motorcycle/CarPlay vs the phone and vis-a-versa and nothing seems to help. The next day, it worked flawlessly for 280 miles. 🤷
                    Currently running 4.0.5 228
                    Apple iPhone 15 Pro Max
                    Is there anything I can do to help? Happy to test some things or send you additional data.
                    Thanks.
                    GT JWR 1 Reply Last reply
                    • AirmanW8 AirmanW8
                      Thanks.
                      @AirmanW8 sounds exactly what has happened to my plan, a couple of days apart, for 2 different routes. Guess I got lucky in between those couple of days as it worked once...wasn't long before the excitement died out. 😧 😖
                      AirmanW8
                      AirmanW8
                      Tom Cat
                      Tom Cat
                      Tony Baker
                      Tony Baker
                      ger kerkhoff
                      ger kerkhoff
                      Vosser
                      Vosser
                      Darren Sharp 0
                      Darren Sharp 0
                      Simone 11
                      Simone 11
                        MartinW
                        MartinW
                        Tegel Werner
                        Tegel Werner
                      • Béta to no-béta
