  4. Navigation instruction regulary freezes
9 Posts 9 Posters 2.0k Views 2 Watching
  • Robby De Laetundefined Offline
    Robby De Laet
    I have installed the app this weekend and used it during two rides. In both rides, the navigation froze multiple times. The map, current position and speed indication continue to function, but the navigation instruction at the top doesn't change anymore. After a missed turn, I had to switch to another navigation app, because it became imposible to follow the route.
    Version: 4.0.4 219
    Samsung Galaxy S23 Ultra (up-to-date)
    Con Hennekensundefined Rob Verhoeffundefined Tommsundefined 3 Replies Last reply
    • Robby De Laetundefined Robby De Laet
      Version: 4.0.4 219
      Con Hennekensundefined Online
      @Robby-De-Laet, I have had a similar freeze this weekend, but in my case also the speed indication and moving map were frozen. I suspect it is due to something that happens while switching from online to offline or back. Especially when that happens multiple times in a row. I noticed that this crashing happens mostly when this constant switching occurs.
        Version: 4.0.4 219
        Rob Verhoeffundefined Online
        @Robby-De-Laet said in Navigation instruction regulary freezes:
        Version: 4.0.4 219
        in version 4.04 the latest build is 216 in my opinion.
        • Rob Dijkstraundefined Offline
          Rob Dijkstra
          I have the same issue. I hope It will be solved
          • Calibosundefined Offline
            Calibos
            I encountered this problem sometimes with version 4.02 ,4.03 and 4.04, the position is always updated but the indications are frozen as well as the kilometer count in the different displays.
            I only navigate in offline mode, so it is not related to the change of mode.
            -You must restart the app and the route to regain stable operation.
            -I was not able to identify the cause of the problem, I had not talked about it because there was no similar report on the forum.
            Inge Bakermansundefined 1 Reply Last reply
            • Calibosundefined Calibos
              Inge Bakermansundefined Offline
              Inge Bakermans
              @Calibos Same here I experience it as well. And for the same reason as you had not mentioned it.
              • AirmanW8undefined Offline
                AirmanW8
                I have just to opposite happen, I'll post another thread in case it's different.
                My map/position freezes and the Turn and distance update. I'm able to still use it.. more like 1996 Printed MapQuest though šŸ˜“
                • Ronny Schenkels 0undefined Offline
                  Ronny Schenkels 0
                  Same problem here, the navigation instructions freeze at the first instructions, even when restarting the navigation , same problem occurs:
                  • iOS 17.1 on iPhone 14 PRO
                  • MyRoute-app 4.0.6
                  • using Apple CarPlay on BMW
                  Both with offline maps and without offline maps, driving around Brussels area.
                  Ron
                  BMW 1250 RS '23
                  Garmin Zumo XT2 (sold)
                  Chigee AIO-5 Lite (sold)
                  Innovv N1 Pro (sold)
                  Chigee AIO-6 MAX
                    Version: 4.0.4 219
                    Tommsundefined Offline
                    Tomms
                    wrote on last edited by Tomms
                    @Robby-De-Laet ik heb dit probleem ook.
                    Bij het volgen van een route, loopt de route vast. (Eventueel door gemiste afslag, maar niet altijd daardoor).
                    Het lijkt er dan ook op of ik nog steeds het voorgeprogrammeerde parcours volg, maar dan zonder navigatie begeleiding.
                    Wanneer ik dat dan op merk, ben ik al even van het parcours verwijderd. Dan is de enige optie om te herstarten. Maar dan stuurt de app me via de kortste(denk ik) weg terug naar vertrekpunt. Hernemen lukt me dan niet ook al ben ik terug op het juiste parcours.
                    Ook deze week wou ik gewoon een a naar b rit doen. Maar ik kreeg toen enkel het startscherm maar geen kaart. Kon op geen enkele manier naar de navigatie pagina.
                    Heb dan maar de waze gebruikt.
                    PS : heb de laatste updates van zowel de app als mijn smartphone.
                    Ronny Schenkels 0
                    AirmanW8undefined
                    AirmanW8
                    Inge Bakermans
                    Calibosundefined
                    Calibos
                    Tommsundefined
                    Tomms
                    Rob Dijkstra
                    Robby De Laet
                      Herman Veldhuizenundefined
                    • wrong routing
                      ErikMatthezingundefined
                      ErikMatthezing
                    • Updated beta! 5.2.1 (486)
                      Nick Carthewundefined
                    • Veekeersinfo en omleiden
                      325
                      Yannick_van_Vugtundefined
                      Yannick_van_Vugt
                    • Request login credentials
